Question about Iolo Technologies System Mechanic: Windows
Install C:\Program Files\iolo\System Mechanic\unins000.msg
  • 909 Answers
SOURCE: need manual,users manual ,instructions
All the info for this program is available by clicking the help tab. I have the same program so if you need some advice feel free to post on here.
Posted on May 11, 2009
ashieshbk
  • 153 Answers
SOURCE: what is the serial key for iolo system mechanic
FixYa is not the place to find serials. Fixya is against piracy , please read the TERMS before posting queries.
Take Care.
Posted on Dec 17, 2009
  • 10406 Answers
SOURCE: the component
Uninstall the software.
Reboot.
Reinstall the software.
Reboot.
It should now work correctly.
Posted on Dec 27, 2009
  • 2340 Answers
SOURCE: I have uninstalled and reinstalled many times per
These problem usually occur when you are using a trial versions that have expired or a "half-cracked" version of a software. In order to reinstall the program you have to do some Registry editing. If you are a "novice" don't try to edit the registry, any errors you may make might render your system unbootable. (Do at your own risk)
Alternatively you can use a commercial uninstaller like 'final installer' or 'perfect uninstaller', etc...an many more in the market. Reinstall the program and use the uninstallers to remove the program and its remnats from the registry.
Posted on Jun 13, 2010
ccamstelveen
  • 201 Answers
SOURCE: How do I fix problems created by iolo System
Normally with these programs you can set back time within the program. If this option is not provided go back in time with windows.
Start> all programms > desk accessories > systemset > System repair
Posted on Jan 13, 2011
System mechanic pro won't start error message
I went through the registry and searching for 'iolo', I deleted all references. Then deleted the files under program files. This worked. I tried going to the hex keys by themselves and that did not work. But I was deleting System Mechanic and Not "PRO".
Aug 28, 2012 | Iolo Technologies System Mechanic: Windows
Tip
"the component IoloSystemService" Error on Iolo System Mechanic Pro
The "the component IoloSystemService" Error message shows up due improper installation of the System Mechanic Pro. Some of the Iolo dependencies failed to get activated and that is the problem.
Now the only solution to fix it is to follow a thorough uninstallation of the System Mechanic Pro.
For WinXP, you can uninstall it from the "Add or Remove Programs".
Next, once its unistalled do not RESTART the PC.
Now, go to the Registry (press "windows" + R to open the run command and type "regedit").
OR
Click the Windows start button and select RUN. Type REGEDIT on the openfield.
On the left-hand side, expand HKEY_CURRENT_USER by clicking the + symbol next to the entry.
Expand Software.
Expand the iolo folder.
Navigate to the System Mechanic Professional folder.
Right-click on the System Mechanic Professional folder and select Delete.
Click Yes to confirm the deletion.
On the left-hand side, expand HKEY_LOCAL_MACHINE by clicking the + symbol next to the entry.
Expand Software.
Close the Registry Editor.
Click Start>My Computer and then navigate to your Local Disk (usually the C: drive) then Program Files\iolo\System Mechanic Professional.
Click Yes to confirm.
on Jun 16, 2010 | Computers & Internet
I purchased iolo system mechanic while online with dell i unistalled and now need to reinstall and dont know how please help
Search your system for files with 'Iolo' in them; e.g. the invoice and the install package.
Try doubleclicking the install package.
How about reading the invoice if that's not good enough?
Try that website again to see if it remembers and wants to let you pull down the installer again.
Mar 12, 2011 | Iolo Technologies System Mechanic...
Can't start iolo system mechanic because iolosystemservice is missing.
Have you tried re installing the software.
Uninstall, run a program like CCleaner, run its registry cleanup.
install the program, i would run the setup file as administrator.
If you still have problems, get back in touch and we will try something else
Aug 12, 2010 | Iolo Technologies System Mechanic: Windows
The iolo system shield would not update
This is gonna be Lengthy process.
First
Uninstall System Mechanic Professional
Open the Control Panel by clicking:
Start>Control Panel
or
Start>Settings>Control Panel
Open Add or Remove Programs.
Locate and select the entry entitled iolo technologies System Mechanic Professional
Click the entry’s corresponding Change/Remove button.
Follow the on-screen instructions to uninstall, restarting the computer as prompted.
Remove the System Mechanic Professional registry entries
WARNING: Using the Windows Registry Editor incorrectly can cause serious problems and may result in an inoperable operating system. Use Registry Editor at your own risk and discretion.
Click the Windows Start button.
Select Run.
Type regedit in the Open field.
Click OK.
Expand Software.
Expand Software.
Remove residual antivirus files
Close all open windows and restart the computer
Follow the same process to uninstall the System Shield also.
Reboot the PC after everything is over.
Then install System Shield First, reboot the PC after the installation and check if the update it working or not. Once its confirmed that System Shield's update is working, install the System Shield.
May 30, 2010 | ACDSystems System Mechanic with Bonus Iolo...
My System Mechanic Professional not is too good: "the component"iolosystenservice" is required for System Mechanic Professional to operate properly and could not be started please let me know some...
OR
Expand Software.
Expand Software.
May 19, 2010 | Iolo Technologies System Mechanic: Windows
SysMech.exe Access violation
Please follow the steps below to perform a thorough uninstall and reinstall of your iolo product. Depending on which iolo product(s) you had, some of these items may not be present.
1. First uninstall anything from iolo from your system and restart the computer.
2. Right-click on the Windows Start button and select Explore.
3. Navigate to C:\Program Files and delete the iolo folder.
**If any of these folders state a file is in use, open your Windows Task Manager and end any iolo processes that are running and try again. Ultimately, Windows Safe Mode will allow all of the folders to be removed.
- Starting Windows in Safe Mode
http://www.iolo.com/customercare/kbarticle.aspx?ID=KBA-01932
4. Once the folders are removed, click on the Windows Start button, select Run, in the Open field type REGEDIT and click OK. This will open the registry editor.
5. Navigate to HKEY_CURRENT_USER, Software and delete the iolo key.
6. Navigate to HKEY_LOCAL_MACHINE, Software and delete the iolo key, should it exist.
7. Navigate to HKEY_LOCAL_MACHINE, Software, Microsoft, Windows, CurrentVersion and double-click on Uninstall.
8a. When it expands, look for any of the following items and delete them should they exist:
{BBD3F66B-1180-4785-B679-3F91572CD3B4}_is1
{78E33B36-2103-49FC-B058-8CF44B6E75FD}
System Mechanic_is1
System Mechanic Professional_is1
System Mechanic 6_is1
System Mechanic Professional 6_is1
System Mechanic 7_is1
System Mechanic Professional 7_is1
System Mechanic 8_is1
System Mechanic Professional 8_is1
DriveScrubber 3_is1
8b. Please also delete these two keys:
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\ioloSystemService
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\ioloFileInfoList
9. Remove residual antivirus files
a. Right-click the task bar located at the bottom of your desktop and select Task Manager.
b. From the Windows Task Manager select the Processes tab.
c. Locate and click on the process named Dvpapi.exe to highlight it.
d. Click the End Process button, then click Yes to confirm.
e. Navigate to C:\program files\common files and right-click the folder named Authentium.
f. Click Delete, then click Yes to confirm.
g. Download and install the Microsoft cleanup utility. You can download this file from Microsoft’s web site at: http://download.microsoft.com/download/e/9/d/e9d80355-7ab4-45b8-80e8-983a48d5e1bd/msicuu2.exe
h. Run the utility by clicking Start>All Programs>Windows Installer Clean Up.
i. Highlight Authentium Antivirus SDK and click Remove. Click OK to confirm.
10. Close all open windows, restart the computer & re-download.
Regards
Apr 22, 2010 | Iolo Technologies System Mechanic: Windows
Program won't start. Get message "the component IoloSystemService" is required for system mechanic to operate properly and could not be found. System Mech 9.5.6 is installed and looks good. Running XP,...
OR
Expand Software.
Expand Software.
Reinstall the System Mechanic Pro
Mar 06, 2010 | Iolo Technologies System Mechanic: Windows
Cannot uninstall ''IOLO system mechanic pro 7''
   sounds awkward I would try burning all your important files to CDs or DVDs to keep them safe and then rolling back changes using system restore- start - all programs-- accessories -- system tools - system restore
from there hopefully you can restore your p.c. to a time before you installed all these programs you wish to remove. Alternatively if you have your Windows install disc (probably not) but if you do then you can install windows again and put your files but from CD/DVD storage. Alternatively you might have a "restore disc" which does a similar state and will restore your laptop to how you bought it.
However I van only advice these "solutions" when you get really desperate, starting over it may take days to get your system how it was before. 1st I would try "system restore" as not all of your documents are affected and you can easily undo the changes you make.
GOOD LUCK xD
Nov 17, 2008 | Microsoft Windows XP Professional
Iolo Technologies System Mechanic: Windows Logo
99 people viewed this question
Top Iolo Technologies Computers & Internet Experts
Stan Ford
IDM Serial Software
Level 1 Expert
Are you an Iolo Technologies Computer and Internet Expert? Answer questions, earn points and help others
