Question about Canon MultiPASS MP730 All-In-One InkJet Printer
Wont send fax but will receive fax and cannot scan
When it is in scan mode there is a small icon on the left of screen on printer, it says the printer is not connected but it is. I can not locate my book so I am at a loss of what steps to try.
  • 47 Answers
Try to replace the cable or the printer port. The other step would be trying to replace Your computer's printer port (but it would be better if this would not be needed).
Posted on Jan 12, 2009
Answ/fax do not work
Maybe it's not set to answer?
Press (fax icon) > (Menu icon) > Fax Setup > Receiving > Receive Mode
Make sure it's set to Fax mode.
Press (fax icon) > (Menu icon) > Fax Setup > Receiving > Ring To Answer
Pick the number of rings you want before the fax picks up.
Save and exit.
Apr 22, 2015 | Samsung C460FW Multifunction Printer...
Tip
HP All-In-One can send but cannot receive fax or can receive but cannot send
One of the most common problems with HP All-in-One Printers is that they can send out fax but cannot receive or they can receive fax but cannot send. Now, what more could possibly be the problem if you are sure that your connection cables are correct and properly setup? Well, most people don't know that this is more often than not, caused by the ECM feature of the fax.
ECM or Error Correction Mode is used by fax machines during transmission. This feature is used to eliminate transmission problems especially when you have a "dirty" or noisy telephone line or a very poor signal can result to fax failures. ECM mode, when is turned ON is supposed to check for errors and glitches and is supposed to make the reception or transmission of faxes come out successfully.
However, for some reasons, the ECM mode is not supposed to be performing well with its feature. Especially if the user has a problem with the telephone line, the more that they cannot receive or transmit a fax. It is then recommended that your HP All-In-One printer's ECM fax settings be turned OFF. To do this, follow the steps below:
1. On your printers front control panel, press the button with the wrench symbol; this is the Setup button.
2. Press the right > or left < arrow until you see Advanced Fax Setup then press OK.
3. Press the right > or left < arrow until you see Error Correction Mode; again press OK.
4. Press the right > or left < arrow until to select Error Correction Mode OFF. Press OK to confirm.
That's it! You may now try to send out a fax or ask a friend to send you one.
on Mar 07, 2010 | Office Equipment & Supplies
Tip
on Dec 02, 2009 | Office Equipment & Supplies
How can I send and receive a fax from Lexmark x4270.?
You can send faxes via the operator panel, the All-In-One Center, or the fax driver.
Using the Operator Panel:
  1. Make sure your All-In-One is switched on.
  2. Load up to 30 sheets of your original document face down in the ADF (Automatic Document Feeder). Note: When you load small paper sizes, place your document in the center of the tray and adjust the paper guides to the edges of the paper.
  3. On the operator panel, press Fax.
Using the keypad you can:
  • Enter the fax number, and then press Black or Color.
  • Press Speed Dial, and then:
- Use the arrow keys to scroll through the list to find the number you want, and then press Black or Color. - Use the keypad to enter a two-digit number (viewable in the upper left of the display), and then press Black or Color.
The All-In-One scans your document and sends your fax to the number you entered.
Using the All-In-One Center:
  1. Make sure your All-In-One is attached to a computer.
  3. From your desktop, double-click the Lexmark 4200 Series All-In-One Center icon. The All-In-One Main Page appears.
  4. Under Productivity Tools, click Fax an image or document.
  5. Follow the instructions on your screen to complete the task.
For a more comprehensive guide on how to send and receive faxes using your Lexmark X4270 printer, please refer to the Lexmark X4270 User's Guide.
Aug 17, 2011 | Lexmark X4270 All-In-One InkJet Printer
I have a Lexmark mode lX3550. What do I have to do to make it fax?
Make sure: • The printer is connected to a computer that is equipped with a fax modem. • The computer is connected to a working phone line. • Both the printer and the computer are turned on. • The Lexmark Fax Software is installed on your computer.
Sending a fax using the software You can scan a document to the computer and then fax it to someone using the software. 1 Load an original document facedown on the scanner glass. 2 From the desktop, double-click the Lexmark Imaging Studio icon. 3 From the left pane of the Welcome screen, click Fax. 4 Select the Document option. 5 Click Start. 6 Enter the recipient information, and then click Next. Note: A fax number can include up to 64 numbers, commas, periods, and/or these symbols: * # + - ( ). 7 Enter the cover page information, and then click Next. 8 If there are any additional documents that you want to send with your fax, add these now, and then click Next. 9 To send your fax: • Immediately-Select the Send now option. • At a scheduled time: a Select the "Delay sending until" option. b Set a time and date. 10 If you want a paper copy of your fax, select Print a copy of your fax. 11 Click Send.
Aug 11, 2011 | Lexmark X3550 All-In-One Printer
Manual on how to fax on the canon MX340
set up for fax reception the following four modes are available for receiving faxes. select a receive mode according to your needs. you can change the receive mode any time. refer to the on screen manual basic guide. A CALL RING PATTERN DETECTIVE SERVICE (DRPD/NETWORK SWICH) MAY NOT BE AVAILABLE DEPENING ON THE COUNTRY OR REGION OF USE. TEL priority mode- FAX priorty mode- FAX only mode- DRPD/network swich.
press the FAX button then press the MENU button ( the fax setting screen is displayed) use the left or right button to select RECEIVE MODE SET., then press the OK button ( the receive mode set . screen is displayed ) select a receive mode then press the OK button ( the select receive mode is sdisplayed )
Jul 12, 2011 | Canon PIXMA MX340 Wireless Office...
HOW TO EMAIL SCANNED DOCUMENTS FROM HP J4580 DIRECTLY?
It is not possible to email the scanned file directly through the printer. However, you may send fax over the Internet
You may subscribe to a low cost phone service that allows you to send and receive faxes with your device by using the Internet. This method is called Fax over Internet Protocol (FoIP). You probably use a FoIP service (provided by your telephone company) if you:
• Dial a special access code along with the fax number, or
• Have an IP converter box that connects to the Internet and provides analog phone ports for the fax connection.
NOTE: You can only send and receive faxes by connecting a phone cord to the port labeled "1-LINE" on the device. This means that your connection to the Internet must be done either through a converter box (which supplies regular analog phone jacks for fax connections) or your telephone company.
Some Internet faxing services do not work properly when the device is sending and receiving faxes at high speed (33600bps). If you experience problems sending and receiving faxes while using an Internet fax service, use a slower fax speed. You can do this by changing the Fax Speed setting from High (the default) to Medium. For information on changing this setting, see Set the fax speed. If you have questions about internet faxing, contact your internet faxing services
support department.
(Ref from the manual of the printer.)
Hope this helps.
Jan 23, 2010 | HP OfficeJet J4580 All-In-One Laser...
Using a Lexmark 3400 series to fax
Yes your printer will send and receive faxes. 1. Make sure: • The printer is connected to a computer that is equipped with a fax modem. • The computer is connected to a working phone line. • Both the printer and the computer are turned on. 2 Load an original document facedown on the scanner glass.
Here is the manual, in case you don't have one http://www.retrevo.com/d/ds/progress?doc=7d2128cd89431b0e3d4c2a1c31fa8fc4
3 From the desktop, double-click the Imaging Studio icon. 4 Click Fax. 5 Click Scan and send a fax. 6 Click Preview Now. 7 Click and drag the dotted line box to select a specific area of the preview image to fax. 8 Adjust the settings as needed. 9 Click Next. 10 Follow the instructions on the computer screen to complete the task. Receiving a fax using the software 1 Make sure: • The printer is connected to a computer that is equipped with a fax modem. • The computer is connected to a working phone line. • Both the printer and the computer are turned on. 2 From the desktop, double-click the Imaging Studio icon. 3 Click Fax.
Dec 05, 2009 | Cars & Trucks
Setting up fax machine to receive
Receive Mode Setting
On the operation panel, press the following buttons to select the appropriate receive mode.
  1. Press <Fax>.
  2. Press <Menu>.
  3. Press the right or left arrow button to select [Receive mode set], then press <OK>.
  4. Press the right or left arrow button to select the receive mode that best suits your needs, then press <OK>.
    FAX ONLY MODE: When you want to receive only faxes automatically with your machine, or have a dedicated telephone line for FAX use only.
    MANUAL MODE: When you receive mainly voice calls and sometimes faxes, or want to receive faxes manually.
    ANS MACHINE MODE: When you want to receive voice messages on your answering machine and receive faxes automatically.
    FAX/TEL AUTO SW: When you want to receive faxes automatically as well as voice calls.
    DRPD: When you have subscribed to a DRPD service with your telephone company.
  5. Press <Stop/Reset> repeatedly to return to fax standby mode.
Sending Methods Sending From Your Machine (Memory Sending)
  1. Load the document on the Platen Glass or the ADF.
    Sending from the platen
    Important: When sending a double-sided document, set the document on the Platen Glass. You cannot scan double-sided documents from the ADF.
    Sending from the ADF
    *MP830 shown
  2. Press <FAX>.
  3. Adjust the settings for your document as necessary.
  4. Dial the recipient's number using the numeric keys or speed dialing.
  5. Press <Color> for color sending, or <Black> for black & white sending.
    • When the document was loaded on the Platen Glass:
      1. When the following message is displayed, load the next page on the Platen Glass.
        If you have only one sheet to scan, press <OK>..
      2. Press <Color> to send in color, or <Black> to send in black and white.
        IMPORTANT: If you do not press the same button you pressed in step 5, the machine does not start scanning.
      3. Repeat steps 5a and 5b to scan in all pages of the document.
      4. Press <OK>.
    • When the document was loaded in the ADF:
      The machine starts sending automatically after the document is scanned in.
      Note: Color sending is available only when the recipient's fax machine supports color faxing.
  • To cancel sending before sending a fax, press <Stop/Reset>.
  • To cancel memory sending while sending a fax, follow any instructions on the LCD after pressing <Stop/Reset>.
  • If the document remains in the ADF after pressing <Stop/Reset> during sending a fax, press <OK>. The remaining document is automatically fed out.
Sending From Your Machine (Manual Sending)
Use manual sending when you want to talk to the recipient before sending a document, or if the recipient does not have a fax machine that can receive automatically.
Caution:
  • With manual sending, you cannot use the Platen Glass to send documents.
  • You will need to connect a telephone to your machine if you want to talk to the recipient before sending a document.
Follow this procedure:
  1. Connect a telephone to your machine if you want to talk to the recipient before sending a document
  2. Load the document in the ADF.
  3. Press <FAX>.
  4. Adjust the settings for your document as necessary.
  5. You can lift the handset if one is connected to the machine.
  6. Dial the recipient's number using the numeric keys or coded speed dialing.
  7. Talk through the handset to the recipient. (If you hear a high-pitched signal instead of the
    recipient's voice, go to step 9.)
  8. Ask the recipient to set recipient's fax machine to receive faxes.
  9. When you hear a high-pitched signal, press <Color> for color sending, or <Black> for black & white sending. Then hang up the handset.
Jan 07, 2008 | Canon PIXMA MP530 All-In-One InkJet...
Black vertical line appears on faxes i send and receive
Small slit of glass "scanner glass" needs to be spotlessly cleaned, open lid to left 2cm wide runs width of lid.
G'day from Oz
Dec 03, 2007 | Samsung CLX 3160fn All-In-One Printer
Canon MultiPASS MP730 All-In-One InkJet Printer Logo
old marine
old marine
