Question about PANDIGITAL Novel 7
Pandidital will open to B&N states network error
    Master:
  • 368 Answers
First Option:
Phone in the Other Sim and check the Phone Network Signal If Network Signal Problem not Solved So
Secend Option:
Your Phone Network IC Fault So Please change Network IC
And Network Signal Problem will Solved
if it is there isn't much you can do on this side of the network.
Contact your phone company.
Posted on Dec 06, 2012
I can't open my thomson gateway
What's the error message?Have you tried to go to the exact modem page?
1. open internet explorer2. type the numbers 192.168.1.254 on the address bar then press enter3. you will be routed to thomson page settings if you received any message stating error like can not display page then you need to check if the cables are properly connected.4. if still can not connect, go to the start menu icon5. select the run icon or search bar6. type cmd then press enter7. you should received a black screen8. from the black screen type ipconfig then press enter9. you should received the info like IP ADDRESS, SUBNET MASK and DEFAULT GATEWAY.10. copy the default gateway and type it in the address bar of your internet explorer then press enter11. if you have not received these information (ip address, subnet mask and default gateway) on the black screen after typing the ipconfig then check the error "media state disconnected" which means that your pc and your thompson is not communicating, here you need to try different network cable to isolate issues for the problem might be the cable, network cable port at the back of your pc or the network cable port at the back of the thomson.
kindly rate rate this post, thanks
Dec 31, 2011 | Computers & Internet
Hi - I recently set the security on my router but am having trouble connecting to wireless on my home laptop. All other devices seem to be ok (2 work laptops, IPad, Ipod) and I get a message saying that...
This error message usually occurs in windows vista & win7 if the settings saved on the computer doesnt matches with the settings in the router...
You can get rid of this message by deleting the list of preferred networks from your computer...
To delete the preferred networks, follow the method given below...
Open control panel > open Network & Internet(double click) > open Network & Sharing center(double click)
On the far hand side left you will have an option called "Manage wireless networks" If you click that, you will see the list of preferred networks that are already saved in your computer... Now select your network, make a right click and select "Remove network" Select "ok" for all the warnings...
Thats it..! you are done..! Now search for the list of available wireless networks in range, you must be able to see your network name without any error mesages... Select your network and click connect, it will ask for the network key(if you have setup one)... Enter the key and get connected...! You must be able to go online now..!
Jan 04, 2011 | Gateway Belkin 54g Wireless DSL/Cable...
Settings saved on other computer for the network do not match the requirements of the network now
Dec 14, 2010 | NetGear WNR2000 Wireless Router
How to sign up for yahoomessenger?
here is a link to the signup form:
https://na.edit.yahoo.com/registration?intl=us&origIntl=&done=&src=&last=&partner=yahoo_default&domain=&yahooid=
Have a nice day.
Jul 18, 2010 | Yahoo Messenger
The traingle is flashing orange the rest not flashing. the printer does not print
In the Attention state, the Attention light is blinking and the Go and Ready lights are off. This state can be reached in the following circumstances:
● Paper tray is empty
● Door open
● Toner Cartridge Missing
● Paper jam/ Tray Misfeed
Pressing Go attempts to reset after a jam is cleared or is ignored in the other error cases. It may be necessary to clear the error manually and press Go or close the top cover. If the error still persists, the device will return to the Attention state.
Note
The LJ1010 product series does not have paper out sensors. When the printer is in an Attention state because the paper tray is empty, the user must reload paper and press Go.
Nov 13, 2009 | HP LaserJet 1010 Printer
Runtime error 2147467259 (80004005) in VB
either the database is in the wrong directory or it doesnt exist
Aug 05, 2009 | Microsoft Visual Basic Enterprise Edition...
Itunes & Quick Time won't open.Unknow error (-69)
You need to run iTunes as Administrator.
The default shortcut doesn't allow this so you will need to create a new shortcut.
Also make sure ther is no CD in your CD drive when starting.
Aug 02, 2009 | Microsoft Windows Vista Home Premium with...
WMI Error
I'm pretty sure you have a failing hard drive. Try dowlnloading diskeeper 2009 trial & see what it shows for fragmentation of the drive. Run the program & defrag the drive. If that doesn't help you can look for a program called tuff test & check the drive that way. That's the sure fire way to find out. If the drive passes tuff test then back up your important stuff & reformat & re-install the os. Use google to find tuff test. Good luck!
May 03, 2009 | Computers & Internet
PANDIGITAL Novel 7 Logo
Top PANDIGITAL Computers & Internet Experts
brian soufane
Josh Whitehead
Josh Whitehead
Are you a PANDIGITAL Computer and Internet Expert? Answer questions, earn points and help others
