Question about Kodak ESP 7250 All-in-One InkJet Printer
Printhead carriage is stuck at the left. - Kodak ESP 7250 All-in-One InkJet Printer
2 Suggested Answers
skywavebe
  • 1258 Answers
SOURCE: printhead carriage jam
It all depends on who made the product. There are often times simple solutions but they need to be found by searching on the web and talking to service people about the unit. Some print head motors were known to fail or develop bearing noise over time in the HP line. Many of these things are really not prone to be fixed as the repair cost is sometimes the same as a new unit.
I would contact the warranty center- even if out of warranty and see if you could talk to a technician to start.
Posted on Aug 31, 2012
Error 0x 19a0027
Hi Norman,
The Error message usually relates to Printer Failure. However you can try few steps to fix it. ( Hopefully )
Turn off the Printer.
1. Open the Carriage access door.
2. Remove the Cartridges and Printhead ( Printhead is the part on which you install the cartridges )
3. Lift the latch to remove the Printhead.
4. Move the carriage from left to right 6 times and it should move freely
5. Clean the contacts on the printhead with lint free cloth. ( Golden dots at back of Printhead )
6. Turn on the printer and it should say " Printhead missing or not installed/Damaged "
7. Install the Printhead and Cartridges and close the latch and close the Carriage door
8. the printer should go through alignment process
If this step does not fix, You may try calling HP customer support to check for better options/solutions
HP Customer Care : 1-800-474-6836
Regards,
Sean
Feb 10, 2013 | HP PhotoSmart Office Equipment & Supplies
Empty carriage stuck in my HP 7500A printer
Hello,Lester Makang
Your carriage got stuck in service station,is there any noise coming from the right side of printer then there will be broken gear.
Power on your printer,after you got carriage jam error open cartridge access door and wait 5 second when you see that gears trying to move,use your hand to pull your carriage to left side.Don't use much force.If your carriage got free then install your print head and cartridges.If this will happen again then take it to service center they will change the service station or broken gear but the cost goes much high.
Nov 06, 2012 | HP Officejet 7500a E910 Multifunction...
My problem is after claibration i receive a message POWER OFF AND CHECK PRINTHEAD CLEANER PATH
Something is blocking the printhead cleaner assembly from moving forward and backward.
Turn the plotter off, open the printhead cleaner access cover (RH side) and see if you can move the cleaners to the front of the machine.
If you can move them fairly easily, then try (with the plotter still off) to move the carriage assembly (holds the printheads) to the left of the machine.
Check the condition of the carriage belt for frayed areas or missing belt teeth.
(I suspect a worn out carriage belt is causing the problem)
With the cleaner assembly to the front, and the carriage to the left, turn the plotter back on and see if the error continues.
May 03, 2011 | HP DesignJet 5500PS InkJet Printer
Kodak printer states printhead loose or missing, this error message came on when I replaced the introductory color cartridge, which occured 1 week after taking out of box.
To resolve this error:
  1. Open the printer access door.
    Disconnect the power cord
  2. Remove the color and black ink cartridges.
  3. Remove, then reinstall the printhead.
    • Unlatch the printhead:
      press the button in the upper-left corner of the carriage.
    • Lift the printhead out of the carriage.
    • Place the printhead in the carriage.
    • Press firmly against the target label on the printhead until it clicks into place.
  4. Install the color and black ink cartridges.
  5. Close the printer access door.
  6. Connect the power cord.
  7. Then follow the instructions on the LCD screen
Jan 23, 2011 | Kodak EASYSHARE 5100 All-In-One Printer
Replace print heads. How?
REPLACING HP PRINTER, PRINTHEADS
Follow these steps to replace the printheads in your printer.
  1. Press the Power button (c00636182.gif ) to turn on the printer.
  2. Open the top cover.
  3. Press and hold the Resume button (c01219285.bmp ) until the carriage moves to the left. CAUTION: Be careful not to proceed until the carriage is on the left side of the printer. If the carriage does not move to the left automatically, turn the printer off and back on and then try holding down the Resume button (c01219285.bmp ) again. The printhead can be damaged if the carriage is not all the way to the left for installation.
  4. Lift the printhead latch. Figure 3: Lifting the printhead latchc01290070.gif
  5. Lift the handle of a printhead and use it to pull the printhead out of its slot. Figure 4: Removing the old printheadc01295543.gif
  6. Shake the new printhead at least six times while the printhead is still in its packaging. Figure 5: Shaking the new printheadc01134519.gif
  7. Remove the new printhead from its package, and then remove its orange protective caps. Figure 6: Removing the protective capsc01134520.gif CAUTION: Do not shake the printheads after removing the orange protective caps.
  8. Insert the printhead into its color-coded slot (the label on the printhead must match the label on the printhead latch). Press down firmly on the printhead until it snaps into place. Figure 7: Inserting the new printheadc01290071.gif
  9. Pull the printhead latch all the way forward, and then press down until the latch engages. Figure 8: Closing the printhead latchc01290072.gif
  10. Close the cover. Figure 9: Closing the coverc01290073.gif
  11. The printer should align the printheads automatically in a few minutes, printing an alignment page. If it does not, go to the next section to align manually.
Align the printheadsIf you installed the HP software, use the instructions in the left column below. If you installed a Plug and Play driver or other driver, use the instructions in the right column.
Mar 05, 2010 | HP Office Equipment & Supplies
Hello, My Canon MP830 suddenly shut off when I told it to print a sheet. It will not turn on, and the print head is stuck to the right, and I can't move it. I left it unplugged for several days, but still...
When the carriage is stuck on the right there's not much you can do, When the printhead goes bad it keeps your printer from powering up. You need to either remove the printhead, or unplug the light color ribbon cables from the circuit board on the right side of the machine inorder to power up, and then change the printhead. QY6-0061-000 around $60.00
Sep 30, 2009 | Canon PIXMA MP830 All-In-One InkJet...
How do I replace the carriage belt?
From the service manual:
1. Remove the Left Hand Cover
2. Remove the Right Rear Cover
3. Remove the Right Hand Cover
4. Remove the Tensioner Assembly
5. Pull out Printhead Cleaner Carriage
6. Slide Carriage Assembly to position shown.
7. Lift up the Carriage Cover and remove ALL the Printheads and close the Carriage Cover.
8. Slide the Carriage along the Printer to the position shown.
9. Push in the 2 retaining clips either side of the Printhead Tube Connector.
10. Pull the Printhead Tube Connector towards you.
11. Push the button to release the Printhead Tubes in the Carriage.
12. Release the retaining clip by pulling it away from the holding brackets.
13. Pull the Printhead Tube Connector up between the two Tube Guides.
14. Slide the Carriage to the left side of the Printer.
15. Unclip and remove the Carriage Cover to access the Trailing Cable in the Carriage.
16. Carefully disconnect the Trailing Cable from the connectors in the Carriage PCA. NOTE Remove Trailing Cable
Ferrites if they fall into the Carriage.
17. Remove the Trailing Cables from the Trailing Cable Holder.
TIP Press the Trailing Cables firmly in the center to release.
18. Slide the Trailing Cable Guide out of the Carriage.
19. Slide the Carriage (including the Belt) to the left and out of the Printer.
20. Remove the Belt from the Carriage by releasing it from the retaining clips underneath the Carriage.
As you can see it looks to be a long process. I have the reinstallation instructions as well. If you still want to carry through with this, let me know and I'll send you the service manual....it will be easier than posting the text and the pictures that go along with each step.
Thanks and please take a moment to rate this solution as fixya.
Mar 16, 2009 | HP Designjet 5500 (42 in.) InkJet Printer
How do I change the printhead of my kodak printer
29af6c3.jpg The release button of kodak AiO printer 5000 series is located at the left side or (where you put the black ink) of the carriage under the carriage lead. While the ESP series is on the top middle part of the carriage
Jan 12, 2009 | Kodak EASYSHARE 5300 All-In-One InkJet...
Error code
I think you've got something stuck inside the paper feed section. This could be any where from where you feed the paper in all the way to the paper exiting the printer. Something might be stuck there. Or your printhead carriage is stuck or not moving properly. Try this:
1. Turn on your printer and let the cartridges center in the middle.
2. Remove the cartridges and the printhead.
3. Check the insides to see if anything is stuck, or any left over pcs of paper.
4. If there is none, unplug the power cord. The carriage should move easily. If it does then put everything back. If it doesn't you'll have to find out what is getting it stuck. Always be gentle w/ your printer.
5. Put everything back and try it again. This procedure is not guaranteed. It just works most of the time but not all of the time.
Let me know if this helps. If it doesn't I'll see what i can do.
Aug 05, 2008 | Canon PIXMA MP830 All-In-One InkJet...
Okidata 320/420 printhead not printing aligned.
Clean the large silver rod that runs through the carriage. It is dirty and not allowing the carriage to move as freely as it should. Ideally it should be left dry. Also change the ribbon. The same motor drives the carriage and the ribbon. If it has a bind, the same thing can happen. Hope it helps Ed
May 18, 2007 | OKI MICROLINE 520 Matrix Printer
Kodak ESP 7250 All-in-One InkJet Printer Logo
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
