Question about Radio Communications
Looking for cobra 89xlr transistor. 176-048-9-002 (2SC458-6)TR14, and a diode 151-088-9-001(IS2473)D14
Parts
  • Frank Lenhard
    Frank Lenhard Dec 06, 2012
    these are cobra part numbers for D14 AND TR14
    Top Expert:
  • 14,553 Answers
Try some one like MCM electronics, you have the generic numbers right here for those parts.
Posted on Dec 06, 2012
Testimonial: "thank you"
Where is the modulation diode in a cobra 89xlr
the modulation limiter is d12 and d13.If you intend on cutting it to give more modulation don't because all you greate is a radio that splashes every channel.
Feb 08, 2014 | Galaxy Radios DX-44V 40-Channels Base CB...
Best modulation for PC68XL
Most Cobra / Unidens are easy by clipping D9. On this one D9 and L19. Just turn up L19 to top. Clip D9 diode. spread coils 1/16" inch. Also use 100uf capacitor (-) toward final across JUMPER staple near Final Transistor in back. Use meter(adjust to best swing) spread back coils,remove L10,L20 slugs or adjust them to top. The only radio that clips different than D9 is Cobra 29Ltd (D11) or Uniden pro510xl(D14).
Oct 08, 2010 | Uniden PC68XL (40 Channels) 2-Way Radio
MY COBRA 29 LTD CLASSIC WILL NOT TX BUT RX VERY WELL. CAN'T SEEM TO CALIBRATE CORRECTLY.
Hi and welcome to FixYa,
Initially, check the final and driver, TR14 and TR15 using a transistor tester or ohmmeter..
Postback results.
Good luck and thank you for asking FixYa.
Oct 30, 2009 | Cobra 29 LTD CB Radio
I have a cobra 29 thats not puting out any power. Where should i start?
Postback results.
Oct 27, 2009 | Cobra 29 LTD CB Radio
Cobra 29 Ltd Classic
In most cases just turning up VR4 is more then enough. Replacing the final, tr14 with another transistor requires changing many more parts to get it to work.
With a new 29, there is no need to change the final. Just turn vr4 all the way up and you will see around 20 - 25 watts. L13 won't gain you a single watt. L12 will raise the dead key, and usually you want a lower dead key for good swing. L14 will gain you a few watts, but don't adjust this unless you have a watt meter. You turn it out to increase wattage, but too much will over bias the final and shorten its life.
You hook it to a watt meter with a dummy load. Then say a steady AHHHH into the mic while keyed. Turn the slug out until the needle stops going up, then back it down to where it stopped.
The easy thing to do, and you will be pleased is just to turn VR4 up. Now, Up is counter clockwise. Its a variable resistor, so the less resistance, the more modulation. So you want to turn the VR down.
that will be more then enough.
Sep 06, 2008 | Cobra 29 LTD CB Radio
New power chip
To my knowledge on a Cobra 29 board, replacing TR14 (2SC2029) with a 2SC1969 is supposed to improve/increase the TX power output. Additionally however, L12, 13 & 14 must also be adjusted while the 29 is hooked up to a dummy load/watt meter. Should you wish to try for experimental purposes only:
  • Modulation improvement - adjust VR4 to desired level or cut D11or max talkpower remove TR18 .
  • replace TR14 with 2SC1307 (or 2SC1969).
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Jul 08, 2008 | Cobra 29 LTD CB Radio
1987 uniden pro 510 xl
Wow, from what you are saying, you should not be messing with the insides of the radio. Finals, are not resistors, that are TRANSISTORS, and they do not have resistance values at all.
The final is the little black transistor attached to the heat sink at the back of the radio. You can't just change the final. there are other parts that need to be changed if you want to do a high power mod. Don't even mess with it. you don't need too.
Next, D14 is not the uniden model. thats what you mess with in a cobra. Don't cut d14 in that radio or you will prolly blow it up. The diode you want to cut out is D203. DON'T CUT IT!!, Just un solder one leg of the diode. You won't be over modulated. That will bring you modulation up and your peak watts. it will swing to maybe 15-20 watts peak. That alone with make the radio louder.
You really don't need to raise the dead key. With a lower dead key you have higher swing. Its all about the audio. 2 watts for dead key is fine. Thats what I run.
You cannot do any other peaking with out a meter. If you have a meter you can spread the 2 coils behind the large transformer a tiny bit until you have peak wattage. L201 and L202. but from reading what you said, you should probably leave them alone, you will gain only a watt or 2, and its not worth it if you mess it up.
To be honest with you, all you really need to do is unsolder one leg of D203. Make sure you pull the leg out, and make sure it is not touching anything so it will not short.
Now if you do this, and it splatters, you can always solder it back in, and then turn RT201 all the way to the right, I think. If you turn it all the way to the right, and there is not modulation, you just turn it all the way to the left.
Please don't mess with anything else or you will screw the radio up.
Mar 19, 2008 | Uniden PRO510XL 40-Channels Base CB Radio
Fuse
There are only a couple of components that could cause the fuse to blow. They are:
1. Reverse protection diode (D23)
2. filter capacitor (C123)
3. Outputs (TR14 & 15)
4. Audio Amp (IC4)
5. Zener Diodes (D22 & 19)
6. the fuse itself (it should be 2 Amps
Hope this be of help/idea. Pls post back how things turned up or should you need additional information.
Thank you for using FIXYA.
Feb 12, 2008 | Cobra 25 LTD 40-Channels Base CB Radio
Cobra 29ltd classic : no rx / tx
D23 is the reverse protection diode and it shorting is the primary reason your fuse blew. As you posted, power was applied in reverse, hence other components would also fail. Pls check:
1. D22 - 9.1V Zener Diode
2. TR23 (2SC1096) 9 Volts regulator
3. D19 - 5.1 Zener Diode
4. IC4 (TA7222) - Audio Amp
5. TR14 (2SC2029B/10) - Finals
6. TR15 (2SC2028B/20) - Driver
7. Most capacitors over 220uF (like C123, C114 & C112)
Hope that this be of help/idea. Pls post back how things turned up or should you need additional information.
Feb 04, 2008 | Radio Communications
Radio Communications Logo
53 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a Radio Communication Expert? Answer questions, earn points and help others
