Question about GE Ovens
Ge jgb295der1bb gas oven willnot light - GE Ovens
  • 4 more comments
  • scott smith Dec 11, 2012
    ok replaced the igniter. still not glowing. by looking at the wiring diag. a relay feeds the bake glow bar.
    could i swap the wire to the broil relay and turn the broil setting on to check if it is in the control panel?
    swaped the bake and broil wires on the back of the control panel. the broil works off the bake control, but the bake igniter still not working. so is the only thing left would be the control valve not allowing the ground path?
    the igniter didnt fix the issue. from the wiring diagram the bake and broil igniters run off different relays in the control panel. i swaped the bake and broil wires on the board. the bake relay and circuit works. so is the only thing left in the system is the oven control valve not allowing a ground path?
  • Richard Roth
    Richard Roth Dec 12, 2012
    Sounds like a wiring issue then.
  • scott smith Dec 12, 2012
    yes it was. found yellow wire from the control panel to the igniter broken near the bottom of the oven.
    Top Expert:
  • GE Master
  • 9,472 Answers
Does the igniter glow white hot?
Posted on Dec 06, 2012
  • scott smith Dec 06, 2012
    The bottom glow bar does not glow at all.
  • Richard Roth
    Richard Roth Dec 06, 2012
    OK, that is the problem. You will need to replace the igniter. Here is the part to order.http://bit.ly/WKuBNF
2 Suggested Answers
ngafm
  • 166 Answers
SOURCE: double oven willnot light
Peace,
ngafm at your service,
It sounds like a bad igniter in that oven or a bad gas valve restricting the gas flow in that particular oven.
Unfortunately this will require hands on service!
How old is this wall oven?
ngafm
Please give me a good rating before you sign of!
If the appliance is 10 years old or more you may not be advisable to put good money into bad! New appliances are so much more efficient today that they can save you a lot of money in energy!!!!
You need a hands on tech for this repair!
Posted on Sep 07, 2008
I have an older (1997) GE XL144 Gas oven. The burners light but the oven won't heat. Any suggestions?
IF THE PILOT LIGHT IS LIT BUT THE BURNERS DONT FIRE IT IS PROBABLY THE THERMOSTAT. FREEZE A LARGE OVEN PROOF BOWL FULL OF WATER PLACE IT IN THE OVEN FOR TEN MINS TO COOL THE OVEN TO BELOW ROOM TEMP AND THEN TRY THE OVEN IF IT WORKS FOR A SHORT TIME THEN STOPS CHANGE THE THERMOSTAT
Oct 01, 2010 | GE JGRP17 Gas Single Oven
Oven won't light.
Make sure your oven timer is not set for automatic cooking
Dec 06, 2009 | GE Ovens
My GE Single Gas Oven won't light, the broiler works. My husband can put in the part, what part do I need.
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
oyuou
Nov 09, 2009 | GE JGRP17 Gas Single Oven
Oven wont light
Check the amp draw on the ignitor. If 2.9 amps or less, replace the ignitor. If 2.9 amps or more, replace the gas safety valve.
Aug 02, 2009 | GE Ovens
Oven will not light
Hi!!! Even if your ignitor glows just change it it has a weak charge..Also if you change glow ignitor and it does not come on then your gas safety gas valve if shorted good luck..
Jan 04, 2009 | Kenmore 30464 / 30465 / 30469 Gas Single...
Gas stove the oven pilot lights but not burner
I HAVE THE SAME PROBLEM WITH MY GE GAS RANGE. THE PILOT LIGHT IS ON BUT WILL NOT IGNITE THE BURNER. WHAT IS THE PROBLEM. LINDA jolin49@yahoo.com
Oct 01, 2008 | Whirlpool SB160PEE Gas Single Oven
Double oven willnot light
Peace,
ngafm
Sep 06, 2008 | Amana AOGD2750 Stainless Steel Gas Double...
How do i light my burner
GE jgrs14bew5bb gas wall oven temp button will not go higher than 360 degrees???
Jul 14, 2008 | GE JGRP17 Gas Single Oven
GE XL44 gas oven
hi thanks for the question just because the igniter lights up doesn't mean its good, the gas will not light, if igniter isn,t hot enough. and a very common problem is that the igniter does come on, but not hot enough to ignite the gas . replace the igniter thanks the appliance doc
Jun 25, 2008 | GE JGRP17 Gas Single Oven
Ovens Logo
43 people viewed this question
Top GE Ovens Experts
William Miller
William Miller
Oloyede Monsuru
Are you a GE Oven Expert? Answer questions, earn points and help others
