Question about Woods Hardware & Accessories
Woods spotlight timer won't come on
My woods spotlight timer came on and I moved the stake and can't get it to come back on. Power is going to the light because I can scroll thru the hour meter. I shook the bulb and it seems okay. Somewhere it said you may have to wait 18hours!?
  • Woods Master
  • 5,245 Answers
Copy following links to identify timer:
http://waterheatertimer.org/Woods-timers-and-manuals.html#N1502
http://www.amazon.com/ACE-TRADING-COLEMAN-Spotlight-Digital/dp/B005PZIOVM
2) Woods spotlight timer appears to have mixed reviews on Amazon.
3) Cheap outdoor timers with photoeye are subject to frequent failure. Might be better to get ordinary spotlight yard stake, and plug that into analog wall timer like Woods 59204, or plug into outdoor remote control like Woods 32555.
4) I do not have instruction manual for this product. When you buy product, it probably has instruction sheet that will show operational parameters, and 1 year limited warranty.
5) This timer has 1 year limited warranty.
6) Try timer on different outlet.
Test outlet for at least 80% rated voltage.
Use circuit analyzer and test outlet for correct polarity and grounding.
7) I suggest buying timers at local store for easier returns. Simply buy another timer and return defect in new package. This action will give consumer warranty that extends beyond 1-year shown on package.
Posted on Dec 06, 2012
SOURCE: Woods Digital Timer TD 2200
See this website for links to instruction sheets in PDF format for Woods US timers:
http://www.woods.com/us-timer-instructions.asp
Posted on Nov 30, 2008
fgainer
  • 54 Answers
SOURCE: setting woods 1600 timer
you can get your instructions here and print them off.
http://www.woods.com/canada-timer-instructions.asp
There is a complete list just choose the one that you have. Please don't forget to rate me on this.
Thank you
Posted on Feb 02, 2009
SOURCE: how do i program the
You posted under Woods indoor plug-in 24-hour mechanical timer.
This particular timer:
Rotate dial until current time lines up with words: 'time now' located on inner dial
To set on-off times, look carefully at dial that rotates.
There are tiny pins that stick up on the dial.
Each pin represents 1/2 hour.
Use fingernail and click pin outward for each half hour you want timer ON
Leave pins inward for each half hour you want timer OFF
Next, plug table lamp into side of timer.
Last step, plug timer into wall outlet.
If this is not your timer, see all Woods timers and manuals:
Or add a comment and I will help.
Posted on Nov 18, 2010
SOURCE: I'm trying to install this
Sure George.
These in-wall timers have extra wire to operate the electronics located inside timer.
You said your old switch has 3 wires.
The new timer can only replace on-off switch that has 2 brass screws and a green screw.
If old switch has 2 brass screws and a dark screw, that is a 3-way switch.
Typically a 3-way switch is found at both ends of hallway.
The Woods 95008 countdown timer is not made to replace 3-way:
http://waterheatertimer.org/Woods-timers-and-manuals.html#59000
Here's what to do:
1) Switch has 2 wires (plus bare ground wire). Take switch wires and connect them to timer-black-wire and timer-red-wire. Choose either one for now.
2) In back of electric box are white wires twisted together and covered with wire nut. Connect timer-white to these wires. This wire will power timer electronics.
3) If electric box does not have white wires described above, then connect timer-white to bare ground, along with timer-green wire.
4) Turn on electricity, and push override button located below the OFF button. If lights come on, timer is wired correctly. If lights do not come on, then reverse timer-red and timer-black wires.
Add a comment if your need more assistance.
Posted on Dec 22, 2010
Testimonial: "Geno, Thank you so very much. I finally got around to install one of the two fan switches and your advice was awesome. "
SOURCE: Instructions on how to set the timer for my Woods
Open following link to identify timer and download manual
TD2200 is older version of 59377
http://waterheatertimer.org/Woods-timers-and-manuals.html#59377
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Posted on Feb 12, 2011
Woods timer #17321 not on - does it have an override?
Copy following link to identify timer and download possible manual:
http://waterheatertimer.org/Woods-timers-and-manuals.html#outdoor
Woods 17321 yard stake has selector dial on top.
Move selector to ON or OFF for override.
Unknown if override turns timer ON during daytime when photoeye is receiving light.
Nov 19, 2012 | Hardware & Accessories
WOODS TIMER - Woods 17321 Dusk-to-Dawn 3 plug yard stake timer
These household-type timers have 1 year limited warranty. Sometimes they last for a few months, or stop after 1 year, and occasionally they last longer 3-4 years.
Solution:
Buy another yard stake, or plug-in timer:
Example in-wall timer: Woods 49650-59204 at my house.
http://waterheatertimer.org/images/IMG_2060-woods-59204.jpg
Another handy thing is the Woods 32555 remote control. Let's you turn on outdoor lights from inside the car, or inside the home.
http://waterheatertimer.org/images/Woods-3255-image-500.jpg
Each item above is sold at Amazon, or local home center or hardware, or box store Sears-Target-etc
How do I reset Jasco Ge 24HR Timer 6 Outlet Grounded Yard Stake? It was working fine then shorted out and now won't receive power
Open link below to confirm this is your yard stake.
http://waterheatertimer.org/Woods-timers-and-manuals.html#59730
1) I tested this timer, and there is no reset.
2) Check that circuit has power. Plug timer into another outlet and see if there is problem with outlet.
3) Buy another GE yard stake at Home Depot and then return defective one.
4) This timer is for 'temporary' outdoor use like seasonal lights.
If timer was buried in snow or got real wet, it might not perform
5) Maximum load for all outlets is 1200 watts.
This timer is not heavy enough for motor loads because motor draw a lot of amps when starting.
For pumps up to 1/4HP use GE15117, or Intermatic HB88RC
http://waterheatertimer.org/Woods-timers-and-manuals.html#6-24
For pumps over 1/4HP, use box timer like GE15207, or Intermatic T101.
http://waterheatertimer.org/GE-timers-and-manuals.html#15207
http://waterheatertimer.org/How-to-wire-T104-Intermatic-timer.html#T101
Dec 27, 2010 | Jasco Ge 24HR Timer 6 Outlet Grounded Yard...
I've lost the instructions for my Holiday Living #10243 6-outlet outdoor yard sake with digital easy set timer. How do I program the yard stake? thanks!
I think the Holiday Living yard stake is made by Woods.
GE sells identical 6-outlet yard stake for which I have a manual with clear instructions and images:
http://waterheatertimer.org/pdf/GE-15107-outdoor-timer-manual.pdf
Add a comment to help me identify your timer so others will be helped also.
If manual shown above is incorrect, open link below to view general list of yard stakes with manuals:
http://waterheatertimer.org/Woods-timers-and-manuals.html#yard-stake
Dec 11, 2010 | Solar Noma 7 Day, 6 Event Outdoor Timer -...
How do I set the woods outdoor timer model #59730
Woods 59730 is24-hour 6-outlet yard stake with dial located on top
This timer is identical to GE15107 yard stake
Manual.
If this is not your timer, look at following page to identify your timer
Add a comment any time
Timer instructions.
Set current time by rotating dial until time lines up with arrowhead located on inner dial
There are segments located around dial.
Look at inner dial > segments are located just outside the inner dial.
Timer comes with segments pushed inward.
To set timer to turn ON, pull segments outward for hours you want timer ON.
All 6 outlets are controlled by timer.
Last step:
There is override switch located on inner dial.
Move switch to TIMER for timer to operate.
Dec 09, 2010 | Woods Outdoor Lighting Timer
I HAVE MODEL #83643B POWER STAKE AND 15 FT DIGITAL TIMER AND HAVE LOST THE INSTRUCTIONS ON HOW TO SET THE TIMER CAN YOU PLEASE TELL ME HOW TO SET THE TIMER
That sounds like the Woods 17321 Dusk-to-Dawn yard stake
Product image:
http://www.amazon.com/Woods-17321-Outdoor-3-Outlets-6-Foot/dp/B000BHN4H8
Manual
http://waterheatertimer.org/pdf/Woods-17321.pdf
If this is not your timer, check following page:
Instructions:
Yard stake control outlets, and turns ON automatically at Dusk
Rotate dial to set options:
Rotate to OFF > outlets OFF
Rotate to ON > outlets ON
Rotate to Dusk-dawn > outlets on at dusk and off at dawn
Rotate to 2 4 6 8 > outlets on at dusk and off 2 4 6 8 hours later
Dec 05, 2010 | Woods Outdoor Lighting Timer
I need instructions on how to use my outdoor timer for the model59733 the other number is 23uld/3ao
59733 appears to be Woods timer number, but Coleman Cable CCI does not have 59733 manual.
Internet search turns up no Woods 59733 number.
There is a Woods 59730 outdoor timer stake, but I can't find manual for 59730 either.
http://www.acehardware.com/product/index.jsp?productId=4433644&CAWELAID=604875525
I do not have 59733 timer photo or manual.
But some Woods timers go by more than 1 number.
Check if your timer appears on following page:
Woods also has promotional line of timers sold in retail stores, and many of these timers carry Woods name but nobody has on-line information.
If I find manual or more information I will post on this thread.
Nov 29, 2010 | Woods INDUSTRIES 59204 OUTDOOR MECHANICAL...
Hardware & Accessories Logo
296 people viewed this question
Top Woods Hardware & Accessories Experts
Gene Haynes
Colin Stickland
Colin Stickland
Are you a Woods Hardware and Accessory Expert? Answer questions, earn points and help others
