Question about Pioneer VSX-D606S Receiver
Right outputs are not working
When I hook my speakers up to the Right on both Channels A & B my speakers will not work. What could be Causing this? Is it ok to hook the speakers up to both Left outputs & turn both A & B channels on?
    Sergeant:
  • 256 Answers
The right side output transisters are probally fried, End if you hook up both speakers to the left A&B channel you will do worse damage to it buy over loading it, Over it,s (OHM) Capacity, That mostly causes them to over heat end go up in smoke,
Posted on Dec 06, 2012
bobhifi
  • 635 Answers
SOURCE: I have a Pioneer VSX-305 receiver. I blew channel
There are independent relays for the speaker A and B switching.Best place to start would be from the relay. When you select A do you hear a click, if not relay is not switching. The circuit involved is a small transistor , a low value resistor ( could be the culprit ) and a shunt diode.
Posted on Aug 16, 2011
Testimonial: "Thanks. I knew there had to be something like this. I'll follow your advice."
techman
  • 3130 Answers
SOURCE: Left Channel not working
Not unless youve had solid state trouble shooting experience and experience soldering and unsoldering. If you havent, you should take the unit to a repair shop, as there are no user replaceable parts inside this unit. Your problem is probably the output IC or associated componet. Good Luck
Posted on Jun 26, 2006
techman
  • 3130 Answers
SOURCE: Left Speakers not working on A or B channel
Have you tryed yet to switch the right speaker where the left one is? If it works then you know the speaker is bad. If you move the left speaker over to the right channel and it works and sound now comes out of the left speaker, you know there is a fault in the amp somehwre. If your not a tech and have not had any solid state equipment repair experience, then your going to have to have the amp serviced by a trained tech.. Good Luck
Posted on Oct 30, 2006
djnick989
  • 1067 Answers
SOURCE: Pioneer VSX-D903S
just try prologic mode no tv uses 3 ch nomore ok and turn on ch a speakers only
Posted on Jan 29, 2008
SOURCE: reciever only allows 2 channels(speakers) at a time.
Two solutions:
1. make sure you are sending a 5.1 signal to the receiver (my DVD player was configured to only send stereo even if I picked the 5.1 soundtrack, i had to fix that). Read the manual to see the indicator lights that would light up if you are sending a DTS signal or Dolby Digital.
2. Use the 'surround modes' to at least get pseudo surround
Posted on Feb 18, 2009
RIght speaker not working in speaker system. Switching the left with right speaker make the right speaker work (not speaker) Plugging the 2 RCA into a different input changes nothing. 2 rear speakers...
Let's name the product and use FM for troubleshooting. Are you saying you have the Right Front and both rear amp channels/speakers not working? What DOES work?
Jan 17, 2011 | JVC Audio Players & Recorders
Yamaha rx-v2500 receiver how to hook up speakers
HI,
Follow these steps to connect a powered sub woofer to your receiver: You typically have two options when connecting a powered sub woofer. Input (1) on the rear of the sub woofer would be used when connecting the sub woofer to the receiver using speaker wires. You would then connect the main speakers to the opposite end, or output or the sub woofer to the main speakers. Option (2) would be using RCA line level output jacks, input (2) on the rear panel of the sub woofer directly to the single sub woofer output on the back of an AV receiver. blank.gif
Oct 06, 2008 | Yamaha RX-V659 Receiver
@I got a bose acoustmass 7 it has three inputs left right center,and three outputs left right center dont have paper work I need like a diagram or instructions on hooking it up please help.
you need to run the left speaker output from the amp to the left speaker input on the Bose, the right speaker output on the amp to the right speaker input on the Bose, the center channel output on the amp(assuming it has one), to the center channel input on the Bose...then the right output on the Bose , to the right Speaker..the Left output on the Bose to the left speaker...and finally the center channel output on the Bose to the center speaker
Jan 07, 2011 | Bose Acoustimass 5 III System
I have a Denon AVR587 running in 7.1. I have an unusual problem as the rear channels seem to play all sounds at a higher pitch and lower volume than all the other speakers on the system. I am using a voice...
Hey ajn1n1 we need to fine where the tinnyness is coming from Lets do a test shall we,
hook up your voice matched polks to your front left and right speaker outputs on your amp to see how they sound as mains. if you hear tinny then its the speakers. sometimes speaker need to be broken in a bit.
hook up your main front left and right speakers to your rear outputs. if you hear the tinnyness then its the output of that channel on the amp or a setting. Newer amps let you change speaker sizes in the menu so that it can change over the crossover for that channel.
Dec 11, 2009 | Denon AVR-587
I am trying to install my xtant 604x after i just had it sent out and repaired. I have 4 rca's coming from the head unit wired to the amp as FL, FR,RR,RL. The front speakers connected to the front output...
CLICK HERE for your Owners manual in PDF format
CLICK HERE for your Installation Guide in PDF format
As we agreed in chat - you are going to run your 4 channel amplifier as follows...
Front Channels of amplifier will run left and right independently.
Wire up the left speakers in parallel all + together and all - together.
This will yield a 2 Ohm load.
To the Same with the Right Side speakers - on the FRONT Right channel of the amplifier.
Now you have a 2ohm stereo load on the FRONT channels of your amplifier.
And using the BRIDGED nomenclature on the REAR channels of your amplifier - wire up your 4ohm sub mono.
Here is a crude drawing for a visual
Thanks for using FixYa - a 4 THUMB rating is appreciated.
Sep 05, 2009 | Car Audio & Video
I have all the wires running right but for some reason my amp is not picking up or pushing my subs. could the rca jacks be messed up on the stereo?
According to the specs for the xo 1945- the output is; 50W x 4 Max Power Output , and I do not see a pre amp output listed. So I think to connect subs, you will need a separate AMP.
The way this works; the rear speaker wires from the xo 1945 hook into the Add-on amp, for example a 4 channel amp. In a 4 channel amp, the rear speakers come off two of the channels of the add-on, and the subs come off the other two channels. There is also the option of bridging two channels for more output power to ONE sub.
You did not mention what size sub(s) you were thinking of adding, but keep in mind that the ox 1945 puts 50 watts MAX per channel. So, if you add two 12" subs and a 1500 watt amp to drive them, your total sound is going to be very uneven.
If you go on line and look up auto audio or amps, you'll get a good idea of all the Sub and amp options that are available.... Hope this helps.
May 02, 2009 | Car Audio & Video
What wire do i hook the remote wire to coming from the amp?
Hello cjfatback,
You want the blue/white wire.
Here's what the manual shows:
Red - Power (to ACC in vehicle)
Black - Ground
Yellow - 12V positive (battery lead)
Blue/White - External Amplifier Control Lead
White - Left Front Spkr +
White/Black - Left Front Spkr -
Gray - Right Front Spkr +
Gray/Black - Right Front Spkr -
Green - Left Rear Spkr +
Green/Black - Left Rear Spkr -
Violet - Right Rear Spkr +
Violet/Black - Right Rear Spkr -
The red and white RCA pigtail leads is for AUX input
Left set of Preamp Outputs - Rear Channels
Right set of Preamp Outputs - Front Channels
Only Models C3433U, C3304U, and C3333U have a 2nd set of RCA pigtail leads for subwoofer output.
Hope this helps.
Apr 14, 2009 | Car Audio & Video
How many speakers can I use?
This should work if channel 3 & 4 are bridged at 4 ohm.
channel 1 should be stable at 2ohm
channel 2 should be stable at 2 ohm
You can hook up the right side speakers together ( + with + and - with - ) . same thing with the left side. this will give you 2 ohm each channel. this will cause your amp to run hot (this might be tuff on the amp). It will give you right (2 speakers) and left ( 2 speakers ), no front and rear adjustement if you need to balance your sound. I think you should be better buying another amp for your sub and take your 4 channels for your 4 car speakers. this amp as a rca output that can feed the other amp ( sub amp ). it is possible to do it.
Good luck
Nov 11, 2008 | Alpine MRP-F250 Car Audio Amplifier
Right audio channel not working
Most likely it's due to bad solder for the Blue Relays.It can be fixed by re-soldering.
Apr 04, 2008 | Sony STR-DE545 Receiver
2 channels not working on 4 channel amp
Well firstly are you using a parametric crossover with your radio and how much rca cables do you have coming you head unit (car radio) if you going to bridge the front up with you rear speakers u wont be able 2 hear the rear speakers try hookinking it up 2 your head unit's front speaker output and have ur rca cable connected to your amp running on your rear output of your head unit by doing this you can use your fader on your head unit to control your front and rear speakers
Nov 07, 2007 | Rockford Fosgate Punch 300X Car Audio...
Pioneer VSX-D606S Receiver Logo
158 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
T-Comtech Repairs
T-Comtech Repairs
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
