Question about ASUS Eee Pad Transformer TF101A1 Tablet Computer
How to solve touch screen problem in Asus Eee Pad Transformer TF101A1
Touch screen in Asus Eee Pad Transformer TF101A1 not functioning
How do i reset my asus transformer tablet tf101 i have a blank screen will not turn on
Perform a soft or hard reset on your Asus Eee Pad Transformer Android tablet if it is not functioning correctly. Here's how.
Soft Reset
You would want to soft reset the device in the event that it has become frozen or unresponsive. To do so, press and hold the Power button on the top-left side of the device for about 10 seconds until the device powers off.
Hard Reset
A hard reset (also known as a factory reset) will clear all data and settings from the memory of the device and set it back to factory default settings. You can perform hard reset on the Asus Eee Pad using the Android OS menus or the hardware buttons.
Method 1 1. Power the Eee Pad off.
2. Press and hold the Volume Down button on the left side of the device, then press and hold the Power button.
3. Continue to hold both buttons until a bootloader screen appears.
4. Wait for the prompt that says to "Press <VOL_UP>" then press the Volume Up button to start the process.
The Asus Eee Pad will complete the hard reset process and reboot into a factory default state.
Method 2 1. Open the Settings app.
2. Select Privacy.
3. Choose Factory data reset.
4. Select Erase tablet.
5. Select Erase everything.
Dec 31, 2014 | ASUS Eee Pad Transformer TF101A1 Tablet...
No sound on my asus transformer eee pad
I have an Asus Transformer EeePad also. I have a sound control button on the outside edge, upper left. Press the top part of it for up, and the bottom end of the button for down.
Otherwise, go to "settings" "sound" "volumes" . There should be a list of 3 items, "Music,video games etc" "Notifications" "Alarms". Each one has a sliding scale of sound. You can slide the volume of each one individually with your finger, then touch "OK". I hope this is of some use to you.
Mar 14, 2014 | ASUS Eee Pad Transformer TF101A1 Tablet...
Need Asus EEE Pad Transformer Manual in English
Here is a link to ASUS support for you pad. you will need to put in the OS, and then scroll down and you will see manual. In my case 43 were available. Eglish was the second one down. Follow the instruction on the page, it looks like you have to do this via your phone.
http://support.asus.com/download.aspx?SLanguage=en&p=20&m=Eee+Pad+Transformer+TF101&hashedid=gHh4q7I8dvWJzhdV
Hope this helps
Mar 21, 2012 | ASUS Eee Pad Transformer TF101A1 Tablet...
ASUS Eee Pad Transformer TF101A1 Tablet Computer Logo
411 people viewed this question
Top ASUS Tablets & eReaders Experts
k24674
Are you an ASUS Tablet and eReader Expert? Answer questions, earn points and help others
