Question about Lexmark X6570 InkJet Printer
The msg area on the control panel does not light up
  • Official Brand Answer
  • 3,344 Answers
Are you still able to print/scan/copy? If so, the LCD could be defective. Try to unplug the power of the printer for about 30 seconds then plug it back in.
If it doesn't help, them the LCD could be defective.
Posted on Dec 10, 2012
8 solder ic number for tcl falt tv
Can you please check for any jammed buttons on the remote and/or control panel? Try switching on the TV manually, while removing the batteries from the remote. If you notice same problem, the area to be looked into is around the system control area: like dry solder, leaky/dry capacitors and this should be done only by a qualified service technician.
Aug 25, 2012 | Televison & Video
My flat screen LG tv prompts a warning msg saying
Check the settings - if the internal speaker is turned off, for example, and you try to raise or lower the volume, you'll get that message. I would restore the factory defaults and see what happens. If you still get that msg after that, you have a more serious issue.
Jul 23, 2012 | LG 42LC2D 42 in. LCD HDTV
I have a wm2016cw washer and can't find the manual. It is giving me an OE msg. I know that means drain error but how do I fix it?
Here is the knowledge base information. http://lgknowledgebase.com/kb/index.php?View=entry&EntryID=6273
If you check all these, and still getting the error, you'll need to get the drain motor replaced. This is not a simple task, as the entire front of the unit must be removed to access the drain pump area.
Top must come off, control panel detached, door gasket outer ring needs to be removed, door lock also much be unplugged. The front panel of the unit also needs to be removed as well.
Mar 13, 2011 | LG WM2016C
No picture
Put new batteries in remote control.
Sep 14, 2009 | ViewSonic N2750w 27 in. HD-Ready LCD...
ISSUES WITH MONITOR,WITH ERROR MSG AS CONTROLL LOKED AND CONTROLL UNLOCKED and contrast,brightness msg appear often even though i dint press those butttons in monitor
d problem is in a transistor costing little, situated near d monitor's osd control ic (microprocessor), it is probably short....[refer the connection n area around the front panel cn connector and crystal clock generator]..beware u must b a professional
Aug 24, 2009 | SAMTRON 55V 15" CRT Monitor
Kenmore Elite Trio - Error msg control panel Er dH -
yOU DON'T SAY WHAT THE MESSAGE IS. EITHER WAY IF THERE IS A ERROR CODE USUALLY ONE OF THE FANS ARE NOT RUNNING OR THERE IS A DEFROST PROBLEM.
Dec 02, 2008 | Kenmore 73503 Stainless Steel Bottom...
Computer Clock Speed Message
Go to control panel then add hardware then once that is don't click on ive connect the hardware then see witch hardware isn't connected then press search from the software\are
Jul 08, 2008 | Intel (RK80532PG0881M) Pentium 4, 3 GHz...
Lexmark X6570 InkJet Printer Logo
20 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
