Question about Polaroid TDA-03211C 32 in. LCD HDTV
After i power my polaroid tv on the screen shows for about 3 seconds then goes black what causes that
There is no sound or anything the dvd part still works but nothing else works?
    Top Expert:
  • Polaroid Master
  • 14,553 Answers
Its a Lcd so if it stays on turn off all the lights (we want a dark room) and with flashlight look carefully at the screen to see if you see a faint image of a picture there or not.
Posted on Dec 06, 2012
SOURCE: TV Has Sound but no picture
Change or move yellow one, of the cables, or component. if not then something you need from expert..
Posted on Jan 02, 2010
  • 6 Answers
SOURCE: Screen goes black after couple seconds on my Polaroid 42" LCD
I had a TLX-4240B 42" Polaroid LCD TV and the screen would go black after about 10 minutes. There was still sound. I removed the two covers exposing the circuit boards behind the TV. I powered up the TV and waited for the screen to go black (I was going to start trying to pinpoint where the issue was with my trusting meter) then noticed a red light would come on when the screen would go black. there were 4 mini switches right above the red light. I switched the one that said burn and the TV has been working great since. good luck and let me know!
Posted on Aug 05, 2009
romsky79
  • 822 Answers
SOURCE: screen goes dark after few minutes
check your LCD inverter maybe there is loss connection or some parts damage from inverter.
Posted on May 05, 2009
  • 192 Answers
SOURCE: I turn the TV and nothing. A black screen. The
I suspect you may have 2 capacitors in your control module that need to be replaced. When these caps start to go bad it will often show up as a problem with the sound. However, when they get really bad they can prevent the TV from turning on. Please see the link below, posted by stiv0. It gives detailed instructions on how to replace these caps and to tell if they're getting bad. If you follow these instructions you can take the back off the TV and check out the caps. If the tops of the caps are bulging they need to be replaced. Just be sure to replace them with the correct value (1000uf) and use caps that are rated at a higher voltage than the originals. I replace the 10v caps in my FLM 373B with 30V caps just to be on the safe side. If you know how to solder this is an easy and inexpensive fix. If you don't know how to solder find a friend who does. These caps have positive and negative terminals. It's important you solder the new caps in with the correct polarity. Stiv0 gives instructions on this. Even if the caps aren't bulging this fix is so inexpensive, less than 10$, that you may want to try it anyway. I hope this helps you out.
http://www.fixya.com/support/r741402-polaroid_flm_373b_lcd_tv_black_screen
Posted on Feb 09, 2010
  • 5 Answers
SOURCE: I have a polaroid 32
There are 2 capacitors located on a circuit board that have gone bad. They are located inside the TV. It is very easy to take apart and inexpensive to fix. If you know how to soldier you can do it or sent it away like I did to fix mine. On the back of the TV there are 3 screws holding on the cover. One is big in the middle and the other 2 are small on the ends. Remove them and slide the cover off. Remove the screws holding the metal cover and take it off.
The top circuit board has the blown capacitors. Located on the left top 2 small round tubes located at E17 & E18. Unplug the 3 or 4 connections carefully on the board and remove the 6 screw holding it in place. Take out the board and replace with new capacitors. I sent mine to JD Electronics in Poland Me. and he fixed it. I put it back in and it is fine now. I ordered the capacitors from DigiKey.com Part # 493-2069-ND. They were $1.09 a piece.
Hope this helps...........
Posted on Oct 25, 2010
Rca tv/dvd combo L32HD32D powers on and for 2 seconds shows, Please Wait, on the screen then goes black. What do i do?
After the screen goes black, do you still have sound or you have none but a blank screen? If you have no picture and sound does the power LED in front of the tv indicate that the set is on, or does it go into standby? Please provide this info so that I can help you with your problem.
Sai.
Aug 15, 2011 | RCA L32HD32D 32 in. LCD HDTV
I have a TDA-03211C Polaroid TV. It powers on, shows the logo for less then a second, goes black, then flashes the cable channel and goes black again. No response from the control panel, and the power...
The power supply board have more than just two capacitors problems,could be anythings else like a diode,transistor or those transformers on the power suuply board,u have no trouble shooting skills or tv repair experience,will never figure it out.Tries websites like Shopjimmy.con,Ebay.com to buy a whole refurbish power suply board for the replacement.
Dec 29, 2010 | Polaroid TDA-03211C 32 in. LCD HDTV
I have the Polaroid dvd player PDV-0700, it will not power on or anything
The PDV0701A will not power on and screen is black . If you turn switch off white lines appear on screen as it turnes off . No sound and dics does not move . Please advise .
Aug 08, 2010 | Polaroid PDV-0700 Portable DVD Player
Flat screen with DVD player... Polaroid TV.. Pic comes on for a couple seconds then screen goes black but I still have the sound???!?!?!?!?! it is about 2 yrs old.. Paid about 900 bucks...
I am thinking power supply or inverter board here. Look for swelled capacitors in the power supply first......if they all look normal,then price and inverter at shopjimmy.com or ebay..........if you do not have technical ability,a reputable shop may be able to fix for less than $200
Jun 03, 2010 | Polaroid TDA-03211C 32 in. LCD HDTV
Tv blacked out no sound either, but power light comes on and off
just talked to polaroid because mine did the same thing......... power light is on and when you first power it on..... the polaroid screen appears for a second and then goes out............. they told me it sound like the control box and would cost me 225.00 to have it fixed............. does anyone know how to get a control box from some one other than polaroid....
my tv is TDA-03211C 32 inch with built in DVD
Mar 22, 2010 | Insignia IS-LCDTV32 32 in. Television
Picture screen goes black, but can still hear the program.
bad capacitors blown in the power supply the can like devices will be puffed up on the tops ewplace thme and your good to go
Sep 24, 2009 | Polaroid TLA-04011C 40 in. LCD TV
Looking to buy a Polaroid TDA-03211C the needs repair
I have a 3 year old TV with the same problem as shema_ross.
Aug 16, 2009 | Polaroid TDA-03211C 32 in. LCD HDTV
Screen black. polaroid tv 32". have sound TV/DVD Combo TDA-03211C
sounds like inverter board. What it sounds like is happing is your LCD is working ut the backligkt board that allows you to see is kicking off. (as you still have sound) Which could be the (most likely) inverter board, or the power supply board. You can take apart and check for voltage at your power supply. The power supply has a pigtail with large white wires and a connector. Power up with the center back cover off and check your voltage at the white connector on the power supply before and after the screen gos out. If there is no large voltage loss it is your inverter board.
You can used boards on e-bay or
www.rns-systems.com
Jun 20, 2009 | Polaroid TDA-03211C 32 in. LCD HDTV
42 IN CH POLAROID HDMI BLACK SCREEN
i had the same problem. i opened the panel in the back of the tv (3 screws) and opened the aluminum panel (3 screws). there's a red led light located at the bottom left corner of the top board. to the right of the led light, you will find this thing with 4 switches. i turned the two bottom switches "burn" and "epmw" to on. so far tv have been working.
Jun 12, 2009 | Polaroid FLM-2632 Television
Polaroid TDA-03211C 32 in. LCD HDTV Logo
160 people viewed this question
Top Polaroid Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
