Don't know how to match up the wires - Computers & Internet
    Problem Solver:
  • 6 Answers
As long as you buy the wiring kit made for your car, the wires themselves will be color coded and actually labled to what it controls.
The book that comes with the wiring kit is pretty self explanitory.
Posted on Dec 06, 2012
I bought a metra wiring harness for my 93 mustang to put in an aftermarket stereo..stereo powers up but can not get sound to speakers..i triple checked all wires i spliced..all colors match..any...
Don't know the model. Be aware that Ford is whimsical when it comes to color codes and even varies from model to model. Whichever pair the adapter uses for the left door speaker, connect the + wire to the ORG/LT GRN wire and the - wire to the LT BLU/WHT wire. For the right door speaker, connect the + wire to the WHT/LT GRN wire and the - wire to the DK GRN/ORG wire. For the left rear speaker, connect the + wire to the PINK/LT GRN wire and the - wire to the PNK/LT BLU or TA/YEL wire (same wire). For the right rear speaker, connect the + wire to the PINK/LT BLU wire and the - wire to the DK GRN/ORG or BRN/PNK wire (same wire). REMEMBER, the colors of the Metra adapter may not match what's in your car
Sep 27, 2012 | Car Audio & Video
Wires under hood chewed by rats
Don't know what you need
Open up the wire harness enough to be able to make a repair
You slide heat shrink tubing over the wire,add wire, any color
but the same wire size or gauge & solder them & then heat shrink
If only the plastic is chewed & no copper wire ,then seal with clear
nail polish & tape real tight with 3M hi temp electrical tape,home
depot has that
Then use the stretchy rubber tape to cover all repaired wires,
unless you like you heat shrink job.
You just match the wire colors & strips that isn't the question
Have the battery disconnected
Sep 14, 2012 | 2003 Buick Century
Ii'm trying to figure out which fuse is for the air conditioner/heat. when i try to turn it on, i don't hear of feel anything at all. i don't know which fuse to check for this problem. i d
okay, look at the fuse box and look for ones that are black or the little wire is broken. You can remove then to check them, just make sure you put the m back where you got them. the voltage should match the one burnt out when replacing it
May 07, 2012 | 2003 Mercury Sable
Wiring diagram for trane g26f032sa furnace
was the answer I gave not helpful? did you get it figured out??
Nov 05, 2017 | Heating & Cooling
Request the wiring diagram directly from Trane.
I have a ceiling fan switch (Westinghouse 77075) that was broken, so I do not know where the wires (black, gray, yellow and purple) went. The speeds are black+gray+yellow, black+gray+purple, and...
I can offer resources:
1) Test switch that was removed, and test for hot connection to narrow down options.
What speed was fan stuck in when switch was removed? Let's say medium speed.
Which connection at fan is hot? Use voltage tester to find hot connection at fan, and match that up with wire-color on switch that was removed.
One and only one wire on 3-speed fan switch connects to hot. And the hot wire is the only wire that connects to each other wire as switch cycles through pull-chain sequence. All pull chain switches follow same sequence: off, low, medium, high.
Let's say old switch was stuck in medium, and you know which color wire connects to hot.
Test switch with continuity tester to see which wire(s) have continuity with hot wire: some switches, it will be 2 wires, and other switches it will be 1 wire. Match where wire(s) were connected, and map that to tests on new switch.
2) Open following link for illustrations and some other links.
http://waterheatertimer.org/How-to-wire-Cooper-277-pilot-light-switch.html#3-speed
Sep 16, 2011 | Speed Ceiling Fan 3-speed Switch By...
Very bad am radio reception, how do i fix?
If it's interference from the high tension wires,you probably need new spark plug wires with good resistor type plugs.
Now,also a bad antenna or a poor match of frequency to the antenna from the rec eiver can cause weak reception.Anyone who knows electronics can match the antenna to the receiver. don-ohio
Sep 14, 2011 | 2005 Dodge Magnum
I cant get in to my pay pal account can you help me
You can click the word Problem with login? just below the login button. then choose any of these three
I don't know my passwordI
don't know what email address I used
I don't know either one
After that you need to input details that will match your details on paypal.
Sep 01, 2011 | PayPal Accounts
Im trying to install this product in my 2000 saville but the colors dont match and there are a whole bunch more wires left on the caddies harness
If you don't know what you're doing, you're much better off taking it to a shop. You can do untold damage to the car, even setting off the air bag, if you don't know what to do in there, particularly if you don't have the right tools.
Jun 25, 2011 | Kenwood KDC-MP242
Need wiring diagram from alpinecde 9852 to 98 gmc sierra
The simplest solution to this is to use an after market harness like this. They're available at most big box electronics stores like BestBuy. The colors on this should match the colors on the Alpine so it's as simple as matching them up and soldering them together. The important colors are those for the constant and switched power (usually yellow and red), ground (black), and the speakers pairs (purple, green, white and grey). The dimmer (orange) and remote (blue) or not necessary to normal operation.
The factory wiring colors are shown here in case you don't want to use the harness. All you need to do is match the descriptions and connect the wires.
Hope this helps. Let me know if you have any questions.
Ray
Apr 12, 2011 | Alpine CDA-9852 CD Player
Computers & Internet Logo
20 people viewed this question
David Payne
David Payne
