Question about Samsung WA5451ANW 4.7 cu. ft. Top-Load Washer
8E error code - Samsung WA5451ANW 4.7 cu. ft. Top-Load Washer
Fault error code 8E
an 8E or 8E2 means - Sensor problem.
Feb 19, 2014 | Samsung WA5451ANW 4.7 cu. ft. Top-Load...
Samsung refrigerator error code 8E
8E = OVER CURRENT ERROR
IPM fault signal (this is caused by the overload of the MICOM INTO during motor action).
IPM: Integrated power module. The IPM controls the motor.
If the fault (low signal) happens to be sensed even once during the washing/rinsing stage, the motor stops immediately. However, during the dehydrating stage the signal is to be sensed, when the number of signals reads more than 6 per 500ms during the Washing or Rinsing cycle action.
If the motor stops working, in one direction ten times, "8E" Error is displayed.
During dehydrating, when the overload is sensed, the motor stops working at once and then feeds back to the initial stage of the dehydration unbalance sensing. When the feed back has occcurred twice, Error "8E" is displayed during the dehydrating unbalance sensing, No error happens by overload sensing. When it happens at more than 800rpm, the process is stopped compulsorily. Power Switch OFF can clear the overload error.
Nov 23, 2012 | Samsung RS265TDRS Side by Side...
E8 front loader washing machines
OVER CURRENT ERROR - Display shows 8E.IPM fault signal (this is caused by the overload of the MICOM INTO during motor action).
HOWEVER, the UK White goods website says:
E8
Temp too high on low temp washesNormally this will be the wash temperature thermistor or NTC that's faulty, please contact us if you need the thermistor with the model and serial number.
You can find more about your Samsung Washing Machine error codes at:
http://www.keepingupappliances.com/repair-help/appliance-repair/washing-machine-help/samsung-washing-machine-error-codes/
or
http://www.ukwhitegoods.co.uk/help/fix-it-yourself/fault-codes/laundry-fault-codes/3069-samsung-washing-machine-fault-codes.html
Jun 21, 2011 | Samsung Washing Machines
My samsung washing machine model WA13513 13.5kg load had 8E error message popping out from the screen. Is the computer board damaged?
OVER CURRENT ERROR – Display shows 8E. IPM fault signal (this is caused by the overload of the MICOM INTO during motor action).
If the motor stops working, in one direction ten times, “8E” Error is displayed.
During dehydrating, when the overload is sensed, the motor stops working at once and then feeds back to the initial stage of the dehydration unbalance sensing. When the feed back has occcurred twice, Error “8E” is displayed during the dehydrating unbalance sensing, No error happens by overload sensing. When it happens at more than 800rpm, the process is stopped compulsorily. Power SIW OFF can clear the overload error.
would advise calling a tech... hope this helps.
Oct 25, 2009 | Washing Machines
Telewest codes sept '09 please
C2 B5 BE 41 0D 9B C5 7C+8E 80 D7 EF 44 93 02 2B
Sep 04, 2009 | StarTech.com StarView SV211K 2-port KVM...
Eurovox codes
aa b7 d1 d9 ce 8e 83 af
8e 80 d7 ef 44 93 02 2b
These codes are working fine for 5A 01 on Friday 17th July 2009
Jul 06, 2009 | Televison & Video
E8 error code
8E - OVER CURRENT ERROR
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
May 02, 2009 | Washing Machines
Need new codes for eurovoxmax need new codes dublin
codes for eurovox 5a01 6/5/09 aa b7 d1 d9 ce 8e 83 af a1 38 06 29 24 29 8d 2b should work ok bristol area
Jan 02, 2009 | Televison & Video
Starview codes for telewest for today plez
telepest codes-
00-AA B7 D1 D9 CE 8E 83 AF
01-8E 80 D7 EF 44 93 02 2B
for 7/05/09
Dec 20, 2008 | Televison & Video
Error code 8E shows up just into the wash programme
8E is an overload or over current error code.. try unplugging it for a few seconds and plug it back in.. if it continues you could have s short in power distribution block on the board.. I would recommend if it continues for you to call a tech im sorry to say.. Good luck
May 26, 2008 | Samsung Washing Machines
Samsung WA5451ANW 4.7 cu. ft. Top-Load Washer Logo
434 people viewed this question
Top Samsung Washing Machines Experts
Jaime Hernandez
shaun taylor
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
