Question about Sta Rite STA-RITE IGNITION CONTROL MODULE - 42001-0052S
Where is ignition control module on 89 cougar 3.8
Car stalls sporadically while driving, wont start after driving for awhle, starts again after 10 or 15 minutes
Pasenger side in front of front brace, behind the passenger headlight, mounted to bottom radiator support.
Posted on Dec 09, 2012
2 Suggested Answers
SOURCE: cant locate ignition module
I think its on right front side fender.
Posted on Nov 28, 2011
89 cougar 3'.8 car stalls. no spark. starts again after 10 to 20 minutes
It sounds like your crank sensor or cam sensor are failing. When either of those two sensors overheat they will shut down the engine until they cool down
Dec 09, 2012 | Sta Rite STA-RITE IGNITION CONTROL MODULE...
Engine is stalling
Hi Chris, and the usual suspects are:
1. Spark plugs in bad condition or partially fouled.
2. Spark plug cables in bad condition or leaking.
3. Spark plug gap to close or to wide.
4. Faulty ignition coil, module and or sensor.
5. Battery nearly discharged.
6. Damaged wire or loose connections at battery terminals,
ignition coil, or plug between ignition sensor and module.
7. Intermittent short circuit due to damaged wire insulation.
8. Water or dirt in fuel system, carburetor or filter.
9. Fuel tank vent system plugged or carburetor vent line closed off.
10. Carburetor controls misadjusted.
11. Damaged carburetor.
12. Loose or dirty ignition module connector at crankcase.
13. Faulty MAP, CKP, and or CMP sensors.
14. Incorrect valve timing.
15. Weak or broken valve springs.
16. Damage intake or exhaust vale.
For a prime suspect please visit website below and good luck:
Harley Diagnostic Codes 04 to Present
Sep 04, 2012 | 2005 Harley Davidson FLHTCUI Electra Glide...
1995 Buick regal sputter stalls in hot weather
how do I change a fuel pump on a Buick electra park avenue?
Jun 12, 2017 | 1995 Buick Regal
2.8 engine Would start when cool, but stall after
89 cierra? It should be DIS ignition so you can't have the timing too high. You said it has fuel and spark. Fuel pressure and injection pulse. Does it try to start if you spray carb cleaner into it?
Jun 03, 2010 | 1989 Oldsmobile Cutlass Ciera
Mercury Topaz loses power while driving, and stalls out
Check fuel pressure. Sounds like a bad pump or plugged fuel filter.
Mar 19, 2009 | 1989 Mercury Topaz
Stalling issue
If your car has high miles and you haven't changed the coil packs, that may be your problem. Bad coil paks will cause hard starting, rough idle and stalling.
Jan 17, 2009 | 1989 Oldsmobile Cutlass Supreme
Weak spark + 1988 ford bronco
check the voltage of the b+ terminal of the ignition coil (primary side) with a cheap multimeter while cranking. low voltage to the primary will cause low voltage on the secondary. also recheck all ground paths from the ignition module. ensure good connection from coil to module. note: new parts are not "known good parts" until it runs.--> IG.MOD.
Dec 17, 2008 | 1994 Ford Bronco
Sta Rite STA-RITE IGNITION CONTROL MODULE - 42001-0052S Logo
29 people viewed this question
Top Sta Rite Pool & Spa Experts
Jay Finke
Jay Finke
john h
Jim Goldsmith
Jim Goldsmith
Are you a Sta Rite Pool and Spa Expert? Answer questions, earn points and help others
