Please how do I adjust d controls to get the coolest cooling effect from my portable Air condition?
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 38 Answers
Hi.
From the left to the right way the first under the first simbol(fan) is one low line and one high line. This means low line when the button is pushed down and the high line when the button is up. I guess to make yhe coolest cooling you should push down the first and the third button after take some gripping tools and the thermometer in the middle turn right as much as you can. After turn on whit the button on the right side. The second button if you push in then i think you get wet air. Just put your hand front of the fan and feel test it. Which type is it?
Posted on Dec 06, 2012
SOURCE: DPAC 13009 portable air conditioning problem
Remove your remote control on the unit, follow the manual step by step. First, do the emergency on/off button, then operate the air conditioning using the remote control, follow the procedure of your manual.You may notice a clicking sound of your remote control. The yellow/green color of your emegency on/off button will turn to blue. Do not put it back your remote control on the unit because he may sense the temperature of the vent, and your air conditioning will not stay on, it will shut off every five minutes. Your problem is solve.
Regards,
Cesar
Posted on May 28, 2009
SOURCE: wiring diagram for portable air conditioner
I think the wiring diagram is on a printed sticker on the side of the water collector, just pull it out of the right side as you look at it. There should be one on there hope this helps as i have the same unit in the other room. regards Richard
Posted on May 29, 2009
  • 15 Answers
SOURCE: I have a portable air conditioning unit...now it
its out of gas bring it two ur nearest refrigeration company
Posted on Feb 24, 2010
SOURCE: WA 903 and WA 10000 Portable Air Conditioning Units
http://docs.google.com/fileview?id=0B_eH0pjdeVdkYjE4ZTI1NTAtN2NhMS00NjVmLWEyZjYtZWQyNDQ3NmNiNjUw&hl=en_GB
Here's a link to the manual.
Hope this helps.
Regards, Davy
www.SidelightPhoto.co.uk Wedding | Event | Lifestyle
Posted on Feb 26, 2010
heatman101
  • 43501 Answers
SOURCE: portable air conditioner not collecting water
Here is a tip about trouble shooting your air conditioner...
Air Conditioner Trouble -Review the Possibilities
http://www.fixya.com/support/r3571569-air_conditioner_trouble_review_the_possi
heatman101
Posted on Jul 22, 2010
Tip
Portable Air Conditioning great portable air cooling
Portable air conditioning offers you the convenience of mobility. All you have to do is roll the portable air conditioner to the room in which it's needed. Install an exhaust hose out a window or other opening (everything you need is provided) and turn it on. The installation process for these units is very simple. These portable air conditioning units are built small enough to be very mobile and are supplied with wheels for easy movement. A portable air conditioner will also work very well in apartment situations where you will often find a window unit is unacceptable.
Portable air conditioners are very unique in that they are portable and can be easily moved to different locations in your home or business. They can be a highly effective way to either help out an existing HVAC system in one room or cool a single room entirely. They are also one of the best ways to cool a room or area without having to install a window mounted unit.
These air conditioners use a compressor and Freon to cool just like normal air conditioning. They are very effective in cooling rooms and to keep the humidity low. Like normal air conditioners portable units extract hot air that must be vented. That is why they need to have the exhaust hose to the outside. These units can cool air as well as air conditioning done with window air conditioners. However they do not require installation like conventional window air conditioners this makes them very convenient for seniors or physically challenged people. Most portable air conditioners are supplied with a window kit. This kit contains exhaust hoses that will work in any window: double-hung, casement, awning or slider. Because they vent through an opening like a window they require no permanent mounting like window air conditioning.
Portable air conditioners are a very good cooling option for those who can't use the more conventional air conditioning methods. Remember though that this type of unit is not as efficient as most window units or conventional air. So while they may make your environment cooler, it won’t turn your tent into a room at the local hotel.
So as you can see these air conditioning units have some great advantages over other types of air conditioning. They are a great alternative for unique applications where central air or conventional window units are either unfeasible or too expensive. During special events, portable air conditioning can also be a great way to keep guests or equipment cool and comfortable. Always be aware though that because portable air conditioning will remove moisture from the air, they will also need to be drained occasionally similar to a dehumidifier.
Does your application warrant a permanent air conditioner of some form or should you just use a portable one? There are some interesting things to consider when making that choice. Weigh out all of the different options and make that decision based on what will best suit your needs.
on Dec 13, 2009 | Heating & Cooling
I have too much coolest in the air condition how do i relief it
Year??? Make??? Model??? Engine Size??? Computer controlled Air???
Jul 30, 2012 | 2007 GMC Canyon Crew
Portable air conditioner not cooling
Ensure your Portable Air Conditioner is sized properly for the room it is in.
A good rule of thumb is 12,000 BTUs for 400 square feet. If the room you are attempting to cool is too large, then the cooling effectiveness will change.
Also ensure that the air conditioner is properly vented outside of the room.
May 21, 2011 | Heating & Cooling
My climate control starts blowing hot air while a/c is on
Make sure you have fully charged AC sytem first, if so Im sorry to tell you this but this is a difficult deal.you may not be able to correct this without taking it to a repair shop with gm scan tool. Reason being the actuators for the hvac that most likely are malfunctioning from either them or another component being bad , require recalibration.The other reason would be the body control module related.It would have to be scanned for U codes which can effect the hvac control.Sorry but thats what I know.
Sep 06, 2009 | 2003 GMC Sierra 2500HD
Regards,
Cesar
May 24, 2009 | Danby DPAC12031 Air Conditioner
Air conditioner not cooling
You can't tell if you have a refrigerant leak unless you put gauges on. You may not have any sign of a leak and still be out.
Mar 31, 2009 | Goldstar Heating & Cooling
Danby dpac7008 portable air conditioner
I want to know how these portable air conditioners are supposed to be set up. Do they have to be on the same as the window out of which the hose goes? If the window is 4.5 feet off the ground, does the air conditioning unit need to be put on a table to make it and the window on the same level?
To the best of my knowledge the unit can stay on the floor and included the product features listed below and it does have a dehumidifier reservoir with direct drain and to make sure if you use the drain hose that the hose is higher than the item that you are draining the water into or you can elevate the unit so that the hose can drain outside and out the window - but you can also drain the water into a bucket or some thing that will hold water. I hope this will help you…..
Product Features
picexporterror From our expanded online assortment; not available in all Best Buy stores
picexporterror 7,000-BTU cooling capacity lets you cool rooms up to 250 sq. ft.
picexporterror Electronic temperature controls let you adjust the temperature in 1° increments for precision cooling; 3 fan speeds
picexporterror Dehumidifier mode removes up to 45 pints of moisture in up to 24 hours; 6.3-pint dehumidifier reservoir with direct drain
picexporterror Auto on and auto off timer
picexporterror Overload protection helps protect the air conditioner from power drains and surges
picexporterror Mesh filter is removable for quick and easy cleaning
picexporterror Includes remote
Apr 06, 2008 | Danby DPAC9030 Air Conditioner
Heating & Cooling Logo
46 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
