Question about Arris SURFboard SBG900 Wireless Router (DHSBG900)
SBG900 Wireless not detected
HI there,
I've recently set up my SBG900 (thanks Papa Chan!). I can connect now to the internet with the ethernet cable and it works fine. But: Even though the wireless light on the modem is on, my computer can't see the wireless network. I have a netgear wireless USB thing, that I have installed, but still no wireless network visible. Can anyone help me? Thanks in advance! Tom
  • Yoshiza Jan 14, 2009
    I have the same problem. I can connect using the ethernet cable but my HP DV6000 does not pick up the wireless signal.
See the other post. Change the "channel" on the online settings and that should work.
Posted on Jan 16, 2009
Just want to secure my internet sight
You want to secure the wireless network.
Is there any computer connected to the router with the Ethernet cable?
If not then you will need to connect the computer to the router with the cable.
Check the IP address on the computer. Open the router set up page.
Once you open the set up page, you will find the option to make it secured
Click Here
for step by step instructions
Jan 06, 2010 | Arris SURFboard SBG900 Wireless Router...
We just tried to secure our wireless motorola sbg900 and now the wireless portion doesn't work. We have to use an ethernet cable. How do we reverse this and still make it secure?
To change any wireless settings on the router, you will need to make wired connections to the router.
If you change the wireless settings on the wireless laptop it will drop the connection because you are changing a wireless setting.
Click Here for more info about networking
Oct 17, 2009 | Arris SURFboard SBG900 Wireless Router...
Hi. just got cable internet (Comcast) and am
that's normal, wireless is normally between 1/4 and 1/2 the speed of your wired connection. normally the router gives priority to wired devices, but this should not cause you any further slow down unless you have wired devices plugged in at the same time you are using wireless. this can be changed from your router's admin page.
Aug 14, 2009 | Arris SURFboard SBG900 Wireless Router...
Cannot connect 2 computers to Motorola SBG900 wireless cablemodem
mac and pc security keys are not interchangable. I suggest not using a a key for both units. You can reset the router by unplugging it for 1 minute. or you gain access to the router through the web address. 192.168.1.1 Type this into the address bar to gain access to the router.
Jul 10, 2009 | Arris SURFboard SBG900 802.11g/b...
Wireless light does not come on
are u able to detect your wireless network in view wireless networks
if not login the modem setting and check whether the modem wireless is enabled.
if still having problem contact 9444482052..........jammy
May 17, 2009 | Arris SURFboard SBG900 (49402201900) Modem
Bridging a Motorola SBG900 to a Speedstream 4200
You can't use the Motorola SBG900 for that. The only way it might work is if the Motorola SBG900 had a 4-port Ethernet switch built into it.
Sep 16, 2017 | Arris SURFboard SBG900 Wireless Router...
Motorola SBG900 - network cannot see hardwired computer
Try to logon to the configuration page of your router and from there you can able to setup the Local Domain Name on it for your network.
Mar 08, 2009 | Arris SURFboard SBG900 Wireless Router...
Wireless Doesn't Work - No light.
If someone else setup the router for you they may have turned off the wireless. If you can connect via ethernet use the web based configuration utility to turn it back on.
The intial setup is as follows in the manual:
To provide an initial wireless connection to your network and the Internet:
1 Connect the SBG900 to the cable TV system as described in Section A.
2 On each wireless client computer, install the wireless adapter hardware and
driver software according to the manufacturer's instructions.
3 On each wireless client computer, set up a wireless adapter profile to
“connect” the client to the SBG900. The procedure depends on your
wireless adapter and computer operating system.
In your initial profile, use the SBG900 default wireless Network Name
(ESSID) motorola (case-sensitive).
Your computers are connected but not secure.
The default SBG900 settings provide no wireless security. After
your wireless LAN is operational, be sure to enable security as
described in “Setting Up the Wireless LAN” in the SBG900
User Guide
Oct 30, 2008 | Arris SURFboard SBG900 Wireless Router...
Arris SURFboard SBG900 Wireless Router (DHSBG900) Logo
292 people viewed this question
Top Arris Computers & Internet Experts
Jerry
Jerry
bobkoure
Level 1 Expert
Are you an Arris Computer and Internet Expert? Answer questions, earn points and help others
