Question about Danby DWC513BLS Wine Cooler
We have a Danby Dual zone, DWC513BLS, It's about 6-8 years old, noticed tonight that the inside temps were at 79* and 77* degree, obviously way too high. I pulled the unit out and unplugged it as
2 Suggested Answers
SOURCE: fridge does not get cold , " E4" displayed on
change digital board in the front
Posted on Aug 18, 2011
Temperature Light Bling
http://www.danby.com/cms/documents/pdfs/en/DWC114BLSDD_EFOM_%28DM%29_FINAL.pdf
set the temp higher,or check front exhaust vent,"a low temp means it is too cold,adjust the thermostat to a warmer temp"
Mar 14, 2015 | Danby DWC114BLSDD 38 Bottle Dual Zone Wine...
Alarm continuously sounds
According to their manual (http://tiny.cc/winecooler) the only reason that the alarm should be on was already proven not to exist. Call their support number: 1-800-263-2629.
Oct 22, 2014 | Danby DWC153BLSST Silhouette Select 51...
Vailant ecotec plus 837 - Water pressure and temp is too high
Pressure inside the tank will rise along with the water temperature. As the water inside cools the pressure will wane until the heating element turns on and reheats the water with a subsequent rise in pressure. Running the hot water at the same time will draw heat energy from the boiler and lower the internal temp and pressure as well.
Jan 21, 2014 | Water Heaters
Danby DWC2727BLS temperature does not go lower than 60 degrees
am having the same problem, and same circumstance. Did you find a solution?
Jun 11, 2012 | Danby Silhouette® DWC276BLS Wine Cooler
E4 Code
Between phone calls to danby and my neighbor, we fixed this problem. My E4 was on the left (lower chamber). If you have one on the right it is the upper chamber. The E4 is a defrost sensor that can be ordered from Danby's distributor (call Danby for the one in your area). The part and shipping were around $30.
If your E4 is on the left...
- remove the top shelves
- open the cover inside the cooler above the digital read outs (the top unscrews)
- inside is were the repacement sensor plugs in
- replace the one with the long cord
- run the sensor down the back to the lower chamber
- replace all covers and parts
If the E4 is on the right...
- look on the right hand wall for a black plastic grate, the sensor is under this grate
- replace the sensor (simple plug and play)
- replace the racks.
Please pass this on, it was a ***** to deal with Danby and I nearly trashed the cooler out of sheer frustration.
Nov 17, 2008 | Refrigerators
Three Temperature zones
Did you read the owners manual? It will be kind of hard to tell you because there are so many different settings for different areas.
Dec 26, 2007 | Danby DWC310BL Wine Cooler
Danby wine cooler
Is it because your keypad not functioning, meaning does the number change when you press the arrow up or down? Or when you set it, (let's say 12 Cel.) it does not reach down to that temperature. Then it could be either it's a sealed system problem( leaking refrigerant or under charge if it's a new unit). Or it could be a control problem( electronic control or sensor)
Jul 31, 2007 | Danby DWC513BLS Wine Cooler
Danby DWC513BLS Wine Cooler Logo
53 people viewed this question
Top Danby Refrigerators Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Danby Refrigerator Expert? Answer questions, earn points and help others
