Question about Sewing Machines
My machine stopped working!
I was sewing and my needle hit a pin and broke. I made sure both parts of the broken needle were accounted for and installed a new needle. I rethreaded my machine and began sewing again, but after a few stitches it just stopped. When I push the pedal it tries to go but only makes a buzzing noise. I checked and made sure there were no pieces of thread or lint caught everywhere. I have tried everything I know to try and it's just not working. Please help!!
  • Sewing Machines Master
  • 7,365 Answers
It's possible that the machine will need a adjustment or the timing
checked at a repair shop
Posted on Dec 06, 2012
RickE1
  • 202 Answers
SOURCE: broke a needle
Best scenario is that the needle hit deflected and hit the hook that the bobbin snaps on to. When needles hit hooks they can leave a mark or burr that the thread will catch on when it comes around. Take out the hook and run your fingernail over the edge from the point back. If you find a burr get some crocus paper (very, very fine sanding paper and polish the burr off.
Next would be that your machine is knocked out of timing meaning a trech will have to reset it.
Posted on Dec 12, 2008
SOURCE: Needle hitting bobbin casing when sewing.
your needle is too long
Posted on Nov 29, 2009
  • 1788 Answers
SOURCE: Wads of Thread Caught in Singer Simple Sewing Machine
Sounds like you threaded it wrong and kept trying to sew, gently get all of your material out of the machine, DO NOT FORCE, GENTLY ROCK IT OUT OR YOU WILL WRECK THE MACHINE, also watch your dvd and learn about threading from your book. Always, hold your thread ends when you start to sew. If, you cannot find your manual go to www.singerco.com, I have sewn for 50+ years and found that the dvd was very helpful, each machine is different.
Posted on Aug 21, 2010
  • 1788 Answers
SOURCE: Needle won't pick up bobbin thread. Has been
Most of the time it is because the needle was inserted with the flat side facing you instead of away from you. And for the heck of it, put in a different needle, there may have been a burr or some defect on your new needle. Other than that, it could be your timing.
Posted on Apr 04, 2011
SOURCE: have a Husqvarna 870 Quilt
you can put a piece of tape on it to keep the thread from coming off
or as one service tech showed me, take a pair of pliers & put a small cloth over the thread take up
lever & take the pliers & gently mash down the take up lever closed or as much as need to keep
Posted on Aug 09, 2011
My sewing machine was sewing fine until the needle broke and I changed the bobbin what did I do wrong
First, check to make sure you have threaded it correctly--upper thread and bobbin.
Most likely the sewing machine's timing was knocked out of alignment when the needle hit something, possibly a pin, a thick piece of fabric, the presser foot, or needleplate. Search for sewing machine timing or take it for service.
Jan 14, 2017 | Sewing Machines
My needle broke and a piece of metal fell out of machine
just adjust to needle in fix to strait in needle clamp hole it operate to needle strait to hole so needle do nt break but needle is best buy qualtity
Aug 31, 2008 | Brother XR-65t Mechanical Sewing Machine
The needle broke, but now u cannot insert new needle, it hits the bottom a d would break again!
have a service done and check the needle and hook timing
it is a reason that needles hit and break
Oct 24, 2015 | Sewing Machines
The needle broke whilst sewing using my Brother machine and now the machine will not work it appears to have jammed ?
check to make sure that all the broke needle has been removed
make sure there is no part of the broken needle in the bobbin area
try putting in a new needle & see if the machine will sew
make sure the bobbin is not damaged
it's very possible since the needle broke the machine could have
jumped time
I suggest to have the machine checked to see if the broken needle
caused any damage to the machine
Jun 09, 2012 | Brother Sewing Machines
Designer SE hit pin head while sewing.
did you take out the whole bobin case and see if it has a piece of the broke needle in there?
Jul 22, 2010 | Husqvarna Viking 1
I have broken 2 needles and now the new needle (foot) will not move up and down. i have double checked all settings and nothing has helped. any suggestions
Here are several solutions for you to try.
* Your broken needle may have been too thin for your fabric. Make sure your replacement needle
is appropriate for the weight and type of your fabric and thread. You may also need a thicker needle if you’re sewing through bulky layers of fabric. When you insert your new needle, make sure it’s positioned correctly (usually with the flat side away from the bobbin, but consult your manual), that it goes all the way into the holder, and that the screw is securely tightened.
If there doesn’t seem to be a problem with your needle, try the following:
* Check your pressure foot to make sure it’s attached securely.
* Change your pressure foot. Your pressure foot may be bent, causing your needle to hit it.
* Don’t sew over pins. A needle that hits a pin can break. Always remove the pins from your fabric before they reach your needle.
* Don’t pull your fabric as you sew. You could be bending your needle back, causing it to hit your needle plate instead of going into the hole. Just guide your fabric, letting it feed on its own.
* Check your needle plate to make sure it's securely in position.
* Change your needle plate. If you’ve been using a straight stitch needle plate (a plate with a small hole, often used for sewing fine, delicate fabrics), switch to a needle plate with a wider hole.
* Check the position of your needle. Sewing machines with zigzag capability allow you to adjust the position of your needle, right,left, or center. If your needle is not positioned correctly, it may be hitting your needle plate or pressure foot.
I hope this helps.
Dec 23, 2009 | Bernina Artista 180
Bobbin holder seems to be broke and needle breaks
Here are several things to try.
* When you insert your new needle, make sure it’s positioned correctly (usually with the flat side away from the bobbin, but consult your manual), that it goes all the way into the holder, and that the screw is securely tightened.
* Check your pressure foot and make sure it’s attached securely.
* Change your pressure foot Your pressure foot may be bent, causing your needle to hit it.
* Don’t sew over pins a needle that hits a pin can break. Always remove the pins from your fabric before they reach your needle.
* Check your needle plate and make sure it's securely in position.
* Check the position of your needle. Sewing machines with zigzag capability allow you to adjust the position of your needle – right, left, or center. If your needle is not positioned correctly, it may be hitting your needle plate or pressure foot.
* Un-thread your machine and remove your bobbin. Clean any loose thread or lint out of your
bobbin case. Re-thread your machine, reinsert and re-thread your bobbin.
* Change your bobbin. There could be a nick along the edge of your bobbin spool that’s catching your thread as you sew.
Also, before you start to sew a seam, hold the upper and bobbin thread tails. Hold them back
and out of the way as you sew your first couple of stitches. This will keep them from getting
caught in your machine.
I hope these solutions help you.
Sep 20, 2009 | Brother XL-2230 Mechanical Sewing Machine
My PE 100 keeps breaking needles, they are striking something during use.
    Here are some things to try.
    * Your broken needles may have been too thin for your fabric. Make sure your replacement needle
    If this doesn’t seem to be the problem
    Make sure it’s attached securely.
    Make sure it's securely in position.
    I hope this helps.
Sep 11, 2009 | Brother Sewing Machines
Sewing Machines Logo
Top Sewing Machines Experts
Tally Girl
Tally Girl
Are you a Sewing Machine Expert? Answer questions, earn points and help others
