Question about JVC Televison & Video
Dark screen on my jvc52FA97 DLP i changed the bulb and nothing cleaned the mirror and nothing i was wondering if it might be the color wheel or there was another light that shot up towards the mirror do i need to change it out need help quick
    Top Expert:
  • JVC Master
  • 14,553 Answers
If not the lamp I would suspect the light engine itself.
Posted on Dec 06, 2012
Slinteriors
  • 8617 Answers
SOURCE: Samsung 61" DLP 3 Blinking lights.
all 3 lights blinking means lamp has a fault the service manual says replace the lamp. If you need the service training manual for that model let me know and I will post the link as the training manual has excellent trouble shooting breakdowns for that model DLP
Posted on Mar 26, 2008
SOURCE: How to change the color wheel of Samsung HL-P5063W
Look on Youtube for samsung color wheel. you should find your answers there...
Posted on Aug 02, 2008
  • 80 Answers
SOURCE: Dark picture problem
did you change the lamp with an original or bulb only - mitsubishi only sells the lamp and housing!!!
never use generic
Posted on Oct 16, 2008
SOURCE: How do I change Part #267888
Go in through the front of the TV behind the screen. From there you remove the light engine cover which will expose the color wheel. Take out the two screws that hold the color wheel in place and disconnect the two wires. Put the new color wheel in and re-assemble your TV.
It's a very easy job, there's just a lot of screws that hold the screen to the TV so don't lose them. Also there are four clip in wire's that you will need to disconnect from the light engine cover, so make a note of were they go before you unplug them.
Posted on Jan 29, 2009
SOURCE: Fading picture that looks dark and dull on a 42" Samsung DLP tv.
You need a new lamp...
Posted on Feb 27, 2009
InFocus X3 plastic lens
If you still have the owners manual there should be an 800 number or some sort of customer support for it. Unless it's really old that is your best bet for the internal pieces
Nov 23, 2012 | InFocus X3 DLP Projector
I just finished replacing the color wheel on my samsung dlp tv and now there is a 3 inch wide dark stripe down the left edge of the tv. the stripe is transparent but it looks like something is covering up...
First thing you want to check is the bulb alignment and make sure there is nothing obstructing the light source. Check the foam sheath on the projector lens and I hope you didn't touch the color wheel with your fingers, you coauld be seeing the effects of finger prints.
Jun 08, 2011 | Televison & Video
Is the color wheel fine if it is spinning? Can you see any light from the dlp lamp when the screen is off? I had a service guy come by to fix my dlp and he replaced the bulb with no luck. He said it was...
First You can look on the rear of the set and see the lamp light shine through the lamp door vents when the set is on. Second you need to replace the whole color wheel before the set will work. Third Color wheels may spin but not at the correct rpm and may shut down the tv and sometimes color wheels will emit a high pitched whine or buzzing sound indicating that the bearings in the motor are wearing out. But now that you have to replace the color wheel you will need to adjust the index delay in the service menu. I suggest having a factory trained tech repair the set.
Jul 10, 2009 | Televison & Video
Mitsu 65" DLP-picture seems washed out
Most likely cause of your trouble is dust on the small mirror inside you set. Your DLP set has 2 mirrors not including the DLP chip itself which has about 500,000 tiny mirrors. The 2 mirrors reflect the DLP chip image to the screen you view. The first is the main suspect it's about 4inches by 7inches. It's mounted on the bottom center facing backwards. This mirror faces slightly up and somtimes after time dust, smoke, dirt settles on it . The second fills the space of the entire back of the cabinet but it faces down and takes alot longer to get dirty.
The compartment is sealed but dust seems to find it's way in. If you remove the screws that secure the screen assembly from the top , sides and bottom. Make sure to have a friend available the screen assembly is delicate when it's not mounted to the cabinet. You can remove and clean the mirrors. These mirrors are glass and you can use glass cleaned. Don't use glass cleaner on the screen it's plastic. You can clean it if necessary with plastic cleaner only. Probably not needed.
Good luck.
Apr 23, 2009 | Mitsubishi Televison & Video
Color of the picture is faded/green
Hello Jdillon917,
I understand what you are saying, however the devil is in the details in reference to your problem. Let me explain, DLP Televisions use what is called "Color Wheel Technology". A wheel made up of primary and secondary colors spin at a synchronized rate with the Luminance Video signal and this along with the changing of the mirrors of the DLP processor creates the color that you see on the screen (This is a high level description, but it covers what is happening). Now what you are experiencing can happen if the sync between the signal to the color wheel and the DLP processor is off center, if the color wheel is out of alignment, or if the signal to the DLP is drifting. The bulb "light" is working but something happened to interfere with the sync between the color wheel and the DLP processor. I would suggest getting this looked at by a DLP qualified TV technician, because of the nature of this problem. In addition I would request that you have the technician do a certified alignment after the problem is taken care of.
I hope this helps,
Thank you,
Shuttle83
http://www.electron-age-technologies-llc.com
Jan 19, 2009 | JVC HD-52G786 52" Rear Projection HDTV
there are 2 mirrors did you clean both there is one down in front near the light source when front screen removed lean in and look down there is another smaller mirrorclean it
Jan 02, 2009 | Mitsubishi WD-62327 62" Rear Projection...
Dark transperant vertical line, left side of screen
Your light tunnel is bad. This requires partial disassembly of the light engine. Suggest contacting a tech
Dec 30, 2008 | Samsung HL-R4264W 42" DLP HDTV
Dark spots on tv
I have the same TV, and I was getting the black spots on my screen as well. It is dust settling on the bottom mirror. Yoiu can call Mitsubishi and spend 150-200 on getting it cleaned, or you can do like I did and take the front panel off and the 10 screws around the edge on the back of the black plastic border around the screen. Then lift up gently and have someone hold the screen for you and gently dust the bottom mirror. I did this by myself, but it would be wise to have 2 people do it.
Nov 26, 2007 | Mitsubishi WD-62525 62" Rear Projection...
InFocus X2 Projector Fault
This error is to do with the light tube - 4 retangular mirror's just after the colour wheel. The dark band is where the bonding for the mirror's is failing, the spring clip holding the assembely inplace pushes the top mirror down slightly causing the dark band as mentioned.
To fix this use a high temp glass glue and very careful clean, reposition the mirror's (in the correct position). Allow to cure fully then re-assemble the unit.
I have only have had to do this twice the 1st time using a sub standard adhesive and dark return a few weeks later. The 2nd I did some reseach and have a quailty glass glue. The X2 has been fine for many years now with no sign of the band re showing.
hope that has helped you.?
ps. if you are rubbish at doing stuff like this - just don't try, it's fiddly and requires a good understand of what you are trying to achieve. A perfect retangular tube with parrallel sides...!!!
Sep 26, 2007 | Compaq MP2800 Microportable Projector sps...
Televison & Video Logo
167 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
