Question about Whirlpool Duet GHW9150P Front Load Washer
We have a whirlpool duet washer and the door lock is activated but the door is open. What can we do?
  • 15,935 Answers
1. Remove the lower panel under the door by loosening the three screws under the bottom edge on the front of the washer. HINT: If you prop up the front feet of the washer with some small blocks of wood, this will make access to the screws much easier.
2. With the screws removed, the lower panel should drop down then come off. If the panel sticks, a light tap on either side will knock it loose.
3. Reach your hand up inside the washer behind the front casing on the right-hand side. This is where the door latch assembly is located.
4. At the bottom of the door latch assembly is a small pull tab. This is the manual release for the door. Pull the tab straight down and the door will come open.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 30, 2010
How can I unlock the door to my Whirlpool Duet washing machine?
try this link..Pull down on the bottom panel and pull it away from the washer. Reach through the open panel and up to the door lock. Find the release ring below the locking mechanism. Pull down on the ring to unlock the door.
How to Unlock a Whirlpool Duet Washing Machine ' Home Guides ' SF ...
homeguides.sfgate.com/unlock-whirlpool-duet-washing-machine-68645.html How can unlock the door to my Whirlpool Duet washing machine Google Search
Dec 12, 2016 | Whirlpool Washing Machines
Whirlpool duet washer, door locked light on door open no other lights on unable to set control
The control can be locked to keep the buttons from activating during external cleaning or to help from small children starting the machine.
To activate or deactivate press and hold the "end of cycle signal" button for 3 seconds.
Jun 21, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Door is locked
Press and hold "end of cycle" button for 3 seconds, on the right side of panel. Try door after 2 minutes. This is the child lock feature, do it again & it locks.
If helped, pl rate me good!!
May 21, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Door wont open
Here is a tip that will tell you how you can get your washing machine unlocked manually...
Washing Machine Door Jammed
http://www.fixya.com/support/r3864434-washing_machine_door_jammed
heatman101
May 05, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool door lock error
turn off all water to your washer run the washer empty for a full cycle when the cycle ends the door will release
spray a lubricant such a WD40 into/onto the door lock
the door kit will not fix the problem
Jun 01, 2009 | Whirlpool Gold Duet GHW9400P 3.8 Cu. Ft....
Whirlpool duet washer door is open. I can't close it because the latch is stuck in the "locked" position.
The first thing to try is to hold the cancel button for 15 seconds. The more labor intensive solution is this: Remove the panel beneath the door (2 or 3 screws). Reach up, there is a little "ring" beneath the door lock. Pull this down, it releases the mechanism.
May 03, 2009 | Whirlpool Duet GHW9150P Front Load Washer
F dL symbol on Whirlpool duet HT
It is saying there is a problem with your door Lock. when you close the door does it hold like it use too? try to open and close the door if it doesn't really close properly then you will just need a door latch. If the machine gives you an f11 code then its the main computer board that can also give your the door lock error. I would check the door first though.
Jan 09, 2009 | Whirlpool Gold Duet GHW9400P 3.8 Cu. Ft....
Duet Whirlpool Washer
You will need service at this time!
A&E Factory Service is nation wide!
1800-905-9505
They are open 7 days 24 hours to make appointments
Neil
Aug 23, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Washer will not start
hiya
this is more than likely a faulty door lock, it's quite a common fault with whirlpools.
hope this helps
please dont forget to rate the helpfulness of this reply thanks kj
Jul 31, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Try everything else, like reseating the connectors, then look here:
http://adsisecurity.com/KenmoreWasher.htm
Jun 23, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
26 people viewed this question
Dan Webster
Dan Webster
Sal De
