Question about Toshiba 57HX81 57" Rear Projection Television
I need a replacement screen broken during a move. Do I need all three parts? I can find 2 out of the 3.
I believe the part numbers are 23311885, 23311886, 23311857
    Top Expert:
  • Toshiba Master
  • 14,553 Answers
One is the outer clear protective screen and the other two the inner screens, if just the outer replace it only.
Posted on Dec 06, 2012
Hobart LXiH error E4 AND part makes noise when OFF
test this steps and fix it. GOd bless you
Drain Pump
If the dishwasher is loud during operation, the drain pump might be defective or might have some debris in it. This is a common problem.
Enter your model number to see parts for your dishwasher.
Help me find my model number
Circulation Pump
If the dishwasher is loud during operation, and the noise is a continuous drone similar in speed to the circulation pump sound, it's likely that the circulation pump motor bearings have failed. Once this happens the circulation pump will have to be replaced, the bearings are not repairable.
Drain Impeller
If the dishwasher is loud during operation, the drain impeller might be broken, or there might be debris in the pump. Generally, to gain access to the pump the top of the pump housing will have to be removed.
Pump and Motor Assembly
If the dishwasher is loud the motor bearings, drain impeller or wash impeller might have worn out. All three of these components are part of the pump and motor assembly. It may be possible to replace one of the impellers, but the motor bearings cannot be repaired. In that case the pump and motor assembly will need to be replaced.
Wash Impeller
The wash impeller is a small, plastic blade. The motor spins the impeller forcing water through the spray arms to clean the dishes. If one or more blades has broken off of the impeller the dishwasher is loud. The impeller can also scrape against the pump housing if it is damaged, warped or bent.
Circulation and Drain Pump Motor
If the dishwasher is loud during operation, and the noise is a continuous drone similar in speed to the motor sound, it's likely that the circulation and drain pump motor bearings have failed. Once this happens the motor will have to be replaced, the bearings are not repairable.
Water Inlet Valve
The water inlet valve is an electrically controlled water valve. When it is new, the water inlet valve is very quiet. Over time, the diaphragm inside the valve deteriorates and deforms. This deformation interacts with the water rushing in and can cause a loud vibration, buzzing, squealing or other noises. If the dishwasher is loud during the filling cycle, replacing the water inlet valve may solve the problem.
Jul 22, 2013 | Hobart Dishwashers
Hp g60-230us: Motherboard, screen, or other? Turned working laptop off, put in padded bag, drove 3hrs, no trauma, plugged p.s. in and turned on, screen had strange blotchy look then displayed left 1/2...
HI there,
I'm a pro laptop repair/rebuild tech. I do not believe the numbers lock and screen are related excepting that the screen plugin on the board affected a curcuit when the screen failed, which is exactly what your problem is. I would replace the screen and the inverter (directly under the screen behind the bezel at bottom) and you should be good to go.
Best Regards,
Marcus
Sep 13, 2010 | HP Computers & Internet
The outer screen of my 50" projection tv ripped during a move. Is there any way to find a replacement part for this?
scherffkids,
Go to http://www.encompass.com and logon as a guest. Type in your units model number in the appropriate block. A list of all the available parts should come up. Type "screen" into the search engine. If available the part number for the screen should come up. There should be three parts to the screen. If you are absolutely sure that you only need the outer screen it should be obvious which one it is.
When you get the screen you will need to remove the front bezel. This usually involves removing the top rear cabinet first. Then there will probably be some screws on the front and finally many screws around the perimeter to get the actual screen out.
Once out you should be able to separate the three sections, install the new unit and using cloth tape, tape the sections together around the perimeter.
Reassemble the unit and you should be done.
Thanks for using FixYa and for the generous rating.
hardrocko
Aug 21, 2010 | Panasonic Televison & Video
Roaring noise during spin cycle
The roaring noise is from the drum bearing and it will only get worse with time until it fails completely. You will need to replace the rear tub assembly which is about $300 for the part. The rear tub assembly part number is 285984. It will take about 2 hours in labor.
Make sure you are using HE (high efficiency) detergent and only about 2 tablespoons per load.
Mar 10, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore ultra fabric care I washer; 80 series- lid switch needs replaced
This is a very easy problem that you can repair yourself. The following link explains in detail how to replace a lid switch such as yours:
http://www.fixya.com/support/r385198-replacing_lid_switch
A replacement switch can be purchased on line at any of the following sources:
searspartsdirect.com
appliancepartspros.com
repairclinic.com
All three sites offer great service and have competitive pricing. So, shop all three for the best price. Just use your COMPLETE model number (usually located under the washer lid along the tub rim) to begin your search criteria. If you do not wish to order on line, use the part number provided by the Sears website and go to your nearest appliance parts retailer. Yes, this a part that they should carry in their inventory.
If you have questions, or need further assistance, please let me know. I hope this helps you.
Jan 16, 2009 | Washing Machines
Need replacement drawer
Pali Order Parts:
http://www.pali-design.com/index.php?path=customer_services&template=order_parts&section=customer_services&subsection=order_parts&page=order_parts
Aug 17, 2008 | Pali Katie Crib
Sony KV36HS500 Flyback Shorts
I HAVE A SONY CRT TV, BUT THE TUBE IS BROKEN. i BELIEVED. THE TV IS
Sony KV36HS500
May 23, 2008 | Sony FD Trinitron WEGA KV-36HS500 36" TV
Whirlpool washing machine
you dont youll need to remove the top of the washer, first remove the angular access panel between the washer and dryer, youll see 2 brass clip holding down top POP those off, there may be 2 screws directly behind the clips as well, the main top will slide off. now there are 2 5/16 screws holding the front panel on probably 5 inc or so down on inside wall of unit, after the front panel is removed youll see the suspension for hte unit, theres 3 suspension rods, im sure 1 or more is broke or come detached. retailing for about 85 bucks id see the temptation to replace the broken one but honestly id replace all three if that is indeed the problem
Feb 09, 2008 | Whirlpool LTE5243D Top Load Stacked...
Apple ipod Gen 3 short battery life
Replace the battery.  Here's the link:
fastmac.com/downloads/install3withadd.pdf
Nov 01, 2007 | Apple iPOD 20GB Toshiba Harddrive for Gen...
Sony Grand WEGA KDF-50WE655 Parts Numbers Needed
1-788-159-21
1-788-162-21
A-1087-018-A
here are your part numbers for the 2 screens and mirror
Oct 12, 2007 | Sony Grand WEGA KDF-50WE655 50" Rear...
Toshiba 57HX81 57" Rear Projection Television Logo
Top Toshiba Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
