Question about Hampton Bay 37225 Cameron II Plus Fan
Hampton bay neon blue
Light does not work
  • 157 Answers
SOURCE: hampton bay fan, wall mount remote control
Hello burrow31. There maybe a switch located on the fan stating 'remote/manual'. Check your manual. Remove the battiers in your remote and short out the battery contact terminals. Reinstall the battiers, start the fan and after fan has reached set speed press & hold fan speed button for one second. Still no speed change contact the Mgfr. with model & serial #.
Posted on Oct 13, 2008
  • 75 Answers
SOURCE: Hampton Bay 60" Brookedale fan remote not working
The Remote (TRANSMITTER) control AND the RECEIVER must both be set to the same CODE in order for the REMOTE to operate the fan.
!!WARNING!! YOU ARE ABOUT TO ENTER HIGH VOLTAGE ELECTRICITY ZONE!!
The RECEIVER is located in the CANOPY, the part of the fan assembly next to the ceiling which is also called the Hanger Bracket.
At the bottom of the Canopy you will see what looks like a large flat washer. Rotate the washer counter-clock wise to release it.
Then rotate the Canopy counter-clock wise to release and lower it. You will see the RECEIVER, which will have a short antenna at one end, tucked in among the electrical wire and bracket. Simply pull the RECEIVER out and you will see the CODE switches. Remember to set both devices to the same CODE.
Good luck. :)
Posted on Apr 26, 2009
  • 26 Answers
SOURCE: Hampton Bay 52 In. Clarington. How do I reverse the fan?
Try these two: 1) look for a small switch up near the light area on the dark-colored area of the fan. If a switch is there, then simply flip the switch to the other position; 2) if you have a remote control for the fan, the reverse mode may appear on the remote control. Hope this helps.
Posted on May 19, 2009
  • 3 Answers
SOURCE: Lost Instructions for Hampton Bay remote control 838956
Go to www.kingoffans.com and follow the site. They are the makers of Hampton Bay.
Posted on May 24, 2009
  • 10865 Answers
SOURCE: i bought a hampton bay ceiling fan model uc7083t but i didn't
hi there i can help. There is a "dip switch" on nearly all fan remote units, much like a garage door opener has. To keep all the fans in your home from operating at one time, each fan needs a seperate "code". To use your other remote, you need to locate the receiver unit in the fan, usually in the "canopy". This is the bowl looking piece against the ceiling. then note the "code" which is the position of the switches. For instance, most have a block with 4 switches, and if the first is "on", and the remaining are "off", that is it's set code. This "code" can be changed to any combination of "on , off" that you like. BUT, you must also open the remote control and set it's switch to the exact same "Code", or order of "on off" as your Fan receiver. (Usually the control "Dip switch" is in the battery compartment.
Posted on Jun 20, 2009
The pull chain for our Hampton Bay Sibley 52" Ceiling fan quit working so we think we need a new light kit???
You just need the switch by the sounds of it.
Hampton Bay Customer Support -Troubleshooting & FAQ ' The Home ...
www.homedepot.com/c/SPC_BRD_HamptonBay_Help
  1. Cached
  2. Similar
Find Hampton Bay customer support, replacement parts, warranty information, troubleshooting and ... Ceiling Fans Patio Furniture Lighting Bath Fans Fireplace
Hampton Bay - Ceiling Fan Parts - Ceiling Fans & Accessories - The ...
www.homedepot.com > ... > Ceiling Fans & Accessories > Ceiling Fan Parts
  1. Cached
Shop our selection of Hampton Bay, Ceiling Fan Parts in the Lighting & Ceiling ... Hampton Bay 3-Light Universal Ceiling Fan Light Kit with Shatter Resistant Bowl .... Fan Light is an ideal choice for replacing worn or outdated fan light fixtures.
Hampton Bay Lighting Parts and Accessories ' eBay
www.ebay.com > ... > Hampton Bay Lighting Parts and Accessories
  1. Cached
  2. Similar
Replaces Hampton Bay and many other similar ceiling fan remote controls. Common replacement for model number UC7078T or FAN-HD with a reverse button.
Hampton Bay Replacement Parts
hamptonlightingadvice.com/hampton-bay-replacement-parts/
  1. Cached
If you have a Hampton Bay product such as a lighting fixture or patio furniture or maybe even some solar lights or ceiling fans then you may need to find a ...
Hampton bay fan and lighting company website store
hamptonbayfanandlighting.net/
  1. Cached
Hampton bay fan and lighting online store. Menu. Skip to content. Hampton bay moved to new ... Hampton bay moved to new website >>>> hampton bay ...
Hampton Bay Ceiling Fan Parts
www.ceilingfansbay.com/hampton-bay-ceiling-fan-parts/
  1. Cached
Do you need help to find a Hampton Bay Ceiling Fan Part? ... known and reputable manufacturer of ceiling fans, bath fans, light fixtures, patio furniture, chandeliers and more. ... Easy Way to Finding the correct Hampton Bay replacement part:.
Hampton Bay Ceiling Fans & Lighting
  1. Cached
If you need a Hampton Bay replacement part, we can help you with that. Here are the most common Hampton Bay replacement parts that people search for, and ...
Lighting Replacement Parts For Your Ceiling Fan
www.ceilingfanreplacementparts.com/hampton_bay_lighting_replacement_parts.html
  1. Cached
  2. Similar
Hampton Bay lighting replacement parts are readily available to let you maintain for many years the beauty and function of your ceiling fans, lamps, chandeliers, ...
Hampton Bay Google Search
Nov 21, 2016 | Hampton Bay Dryers
Hampton bay springview
Make sure the blue wire from the top of the fan is connected to the hot wire in the ceiling.
Aug 06, 2013 | Dryers
We have the hapmton bay 52 in cameron II plus in chrome and blue neon fan. Is there a different light fixture that can be attached instead the neon light fixture? The fan still works great, but we dont...
Contact "King of Fans" (kingoffans.com) in Ft. Lauderdale at 800-330-3267. They made or make Hampton Bay fans. I just ordered an arm for mine. Have your UPC number handy.
Feb 18, 2011 | Hampton Bay 52 In. Cameron II Plus in...
Trying to connect a ceiling fan light kit. I connected the blue wire from the fan kit to the black wire in the light kit and then connected the white wire from the fan kit to the white wire in the light...
Those connections sound OK ,, now you have to go to the canopy and see if all the wires for the fan/light are connected to a house wire. If there are two switches , then the blue fan wire would connect to the red wire .. it may be capped off in the ceiling. If there is only one control switch , then the blue wire from the fan will connect to the same ceiling wire as the black fan wire does.
Please Vote !!
May 30, 2010 | Hampton Bay 24002 Ceiling Fan
My light kit wire is not connected
Blue, is usually international color for the NEUTRAL wire. EUROPE BROWN==PHASE BLUE===NEUTRAL Green/Yellow stripe==EARTH. (Most important wire)
USA. BLACK==PHASE WHITE==NEUTRAL GREEN/BARE==EARTH (Most important wire)
Mar 28, 2010 | Hampton Bay 24002 Ceiling Fan
Hampton Bay 37225 Cameron II Plus Fan Logo
Top Hampton Bay Dryers Experts
Donald Klecher
Donald Klecher
Level 1 Expert
Are you a Hampton Bay Dryer Expert? Answer questions, earn points and help others
