Question about Refrigerators
My viva water dispenser does not dispensed the hot water
I bought an hidden VIVa water dispenser last 3 months ago, but now it does not dispensed the hot water. Please help. Thank you
  • 8 Answers
SOURCE: Amana SBS Water and Ice maker issues
The water solenoid on the back of the refrigerator at the bottom is becoming clogged. There is only a very small hole in the diaphram of the valve. I suspect you have very hard water, or at least a fair amount of sediment in the water.
This valve will most likely need to be replaced by a qualified technician.
They sometimes can be cleaned, but it doesn't always work.
Posted on Jun 10, 2008
catriver
  • 878 Answers
SOURCE: Ice dispenser not working
Scorpio, remove the ice bin itself, dump the ice and see if you can move the bin auger by hand by turning the actuator in the rear. If the bin is ok, with the door open and the door switch held in see if the auger motor is turning when pressing the ice lever. If it's not turning the next logical step is to see whether the auger motor is getting voltage when calling for ice. Make sure the door switch is closed. The part number for the auger motor on the posted model is wr60x0202. Hope this gets you going..Catriver.
Posted on Jul 24, 2006
SOURCE: Rinse Aid does not dispense
http://www.partselect.com/ModelFrames.aspx?ModelID=149370&ModelNum=PDB2600AWX&mfgModelNum=&ManufactureID=1&Selected=54869&Position=1&mfg=Maytag&Type=&Mark=3
From diagram RINSE AID & SOAP DISPENSER, replace 138912t.jpg PS138912
Wax Motor for Detergent Cup Actuation.
Posted on Apr 27, 2008
SOURCE: ge refridgerator model gsl25jfpe bs
I have a gsl25jfpe bs ge regrigerator and the baffle motor that controls air flow from the freezer to the refrigerator is out. This had been causing everthing in the fridge to freeze and cause the water to stop working due to water freezing in the storage tank. The baffle is in the back top of the fridge covered with a plastic cover. Remove plastic cover to check baffle function.
Posted on Nov 08, 2008
  • 531 Answers
SOURCE: ice maker and water dispenser to not work. Just quit!
water valve
Posted on Apr 05, 2009
Viva bottom loading water cooler does not dispense water
Some others addressed this issue on Fixya.com before:
Brett 42 said: the water line is froze.. I took a hair dryer and applied it directly to the dispenser for about 10 minutes. I then held down the buttton for approximately 30 seconds and the water began to drip extremely slowly then faster until a small chunk of ice shot out of the dispenser. I believe the reason this happened was that I the temp of my freezer set lower than the fatory setting.
Mike Smith said: "1) remove the tubing connector behind refrig kickplate . Press for water . If no water comes from tube under refrig , then possibly frozen tank but probably not . Probably bad water inlet valve . ( tank is in the lower potrion of the refrig section behind the crispers ) .
2) if water does shoot out , then your freezer door is frozen which requires leaving door open and tapeing light switch closed and tape plastic around freezer section opening so fridge will continue to operate normally . Thawing freezer door could take a day or 2 . 3) You can plug the hoses back togather and walk by occasionally pressing water untill comes out . Lower your freezer temperature setting also ( could be set for too cold)"
I hope this helps you out!
Apr 09, 2017 | Water Filters & Coolers
Request unlock HTC viva touch
Hi, To which network has your HTC TOUCH VIVA has been locked to? You can unlock your HTC TOUCH VIVA safer and easier using unlock code. You can get the unlock code for a HTC TOUCH VIVA from www.onlinegsmunlock.com/htc-touch-viva/rs7wp9/ at affordable cost.
UNLOCKING STEPS FOR HTC TOUCH VIVA
1. Switch ON your HTC Touch Viva with a Not ACCEPTED SIM Card.
2. If your HTC Touch Viva asks for a PIN code, then enter your SIM card PIN and press OK.
3. HTC Touch Viva will ask to enter an "unlock code".
4. Enter Unlock Code we send to you.
5. Your HTC Touch Viva is now unlocked.
Oct 06, 2012 | Cell Phones
LG fridge LRSC26915SW -= water dispenser and ice are not getting water
Replace water filter, this unit had a issue with restrictions in filter due to a design issue. Water valve is all so called a water pump from many people.
Aug 17, 2012 | LG LRSC26915SW 36" Side-by-Side...
Viva water dispenser Noise
The cooler is making a bep noice
Jan 20, 2012 | Refrigerators
Ice dispenser won't work, light won't work.ge side by side fridge
A GE uses a 12 volt bulb . It will not come on , if you went and bought a bulb with the same receptical end . HAS to be a 12 volt .
Sep 12, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Want to transfer msgs from htc p3400 to htc viva..possible?
yes it is possible u can use sms back up softwere to take a back up and the same can be used in ur viva
Jun 07, 2009 | HTC Touch Viva Cell Phone
Bendix Washer/Dryer - softener dispenser not working
the softer dispenser is blocked, remove drawer wash it out with hot water ,clean out small hole in softer compartment close IRE bye
Aug 16, 2007 | Tricity Bendix WDR1040W Front Load Washer...
Feb 20, 2007 | Maytag 24 in. MDB4100 Built-in Dishwasher
Refrigerators Logo
774 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
