Question about Conair Health & Beauty
Conair Ion 1875 hair dryer won't go on
    New Friend:
  • 3 Answers
Did u try pressing the trouble shooter on the cord if that dosent work
take it back
Posted on Feb 20, 2013
5 Suggested Answers
taran_2005
  • 10515 Answers
SOURCE: Hi. I have a
A hinged filter is located at the back of the hair dryer. It is easy to open and simple to remove the filter for cleaning. The filter feels like layered nylon netting; lots of holes for air circulation. Just remove and rinse the filter in clean water. Don't stretch the filter while cleaning it. Let the filter fully dry, and then replace it in the hair dryer. (There are no instructions for cleaning the filter. I have an air cleaner with a similar filter, and this is how I clean it.)
let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Sep 12, 2010
SOURCE: conair hc318d reassembly
i have hc318d clipper it been use two time and havent use it in a year so was going to use it last nite and the small blade fell out. i try to put it back in and it want hold keep falling out
Posted on Aug 02, 2009
SOURCE: Revlon 1875 Ion Select hair dryer warranty
After Contacting Revlon directly:
They asked me to call:
800 487 7273
Helen of Troy
They said to mail the item back with a short letter and it would be replaced in 2-3 weeks. Nothing else need.
Helen of Troy
1 Helen of Troy
El Paso, TX 79912
Posted on Apr 02, 2009
SOURCE: HOW TO PUT THE SPRING BACK IN A CONAIR HAIR HC318D
I can help with this!
Posted on Aug 07, 2009
Revlon hair dryer rv484 is dead
most likely a thermal fuse has failed if the fan still works
Jan 14, 2014 | Revlon Rv484 Ion 1875 Watt Hair Dryer
Where can I find an online instruction manual for the Yellow Bird Conair Pro 1875 watt blowdryer, please?
I found a list of all their instruction booklets for hair dryers (some are 1875 watts) but they don't have the Yellow Bird:
http://www.conair.com/cnt_ib.php?action=filter&type=category
You could try calling Customer Service at 1-800-326-6247, or ask for the instructions via the online form here:
http://www.conair.com/customer-service-cn-18.html
Good luck, and I hope this helps!
Jul 01, 2011 | Conair YB075W HAIR DRYER 1875W YELLOW BIRD
This dryer does not appear to come apart in any way in order to clean out the lint. Can you tell me how to do this?
Good for you! Cleaning out the lint is the only way to keep your dryer from burning out the motor. And you're right, it won't come apart. I have had this dryer for years, thanks to cleaning out the vents.
First, UNPLUG YOUR DRYER.
I've found that my slightly-curved manicure scissors are the easiest tool to use for cleaning these vents. With the scissors closed, I use the pointy end to scrape up the lint, using a rocking motion-- don't scrape all along the vent, you'll only compress the lint into the mesh. Sort of how you would ice a cake: dab and lift. It's okay if you don't get absolutely all of it out, just do the best you can. If you can't find manicure scissors, a toothpick or a large, un-bent safety pin (be careful!) will do.
Apr 30, 2011 | Conair 1875 Watt Ionic Folding Handle...
Wires burned inside handle.
This is most likely caused by a short circuit. It's dangerous to use as it could go on fire or melt the handle and electrocute you. It's best to get rid of it and get a new one.
Apr 17, 2011 | Conair 1875 Watt Ionic Folding Handle...
I need maual for Revlon 1875 IONIC hair dryer Model # RV479 i want to download the PDF manual if possible
Well you may please follow the link below to get your manual -
http://www.conair.com/instruction_booklets/1875Watt_Ionic_Styler_146XR.pdf
Good Luck!!
Thanks for using FixYa!!
Mar 26, 2011 | Vacuums
It will not run as the reset button on the will not lock in place
The lock or the thermostat might be damaged, get them replaced.
Mar 13, 2009 | Conair Health & Beauty
Hair Dryer cord has electrical shortage
IF you take off about a inch of wire from the plug and re-wire it [somtimes with new plug also] make sure to remember the fuse and this should do the trick.
Jun 27, 2008 | Conair Dry 'N Straight Hair Dryer and...
Health & Beauty Logo
651 people viewed this question
Top Conair Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
 Mikey
Mikey
Are you a Conair Health and Beauty Expert? Answer questions, earn points and help others
