Question about Bosch Ovens
Remove stuck light cover
Mini oven glass light cover is stuck
SOURCE: kenmore oven: glass dome for interior light removal
Hopefully someone answered your question by now. If not, the glass bulb cover sticks sometimes, but it does turn counterclockwise. Be firm with it, let it know who's boss. Once you've removed it, you can replace the 40 watt appliance bulb. (The manual suggests you unplug the range or disconnect power for your safety). Good luck.
Posted on Nov 25, 2007
barkencoa
  • 3463 Answers
SOURCE: trying to replace main oven bulb: cover jammed
Try heating it up with a hair dryer or similar if that does not work then you will probably have to break the glass cover.
Posted on Nov 17, 2008
  • 10 Answers
SOURCE: oven light bulb stuck in socket
You can use a potato (no kidding). Try to press firmly with a potato into the light socket and turn.
Posted on Mar 21, 2009
jmeredith
  • 417 Answers
SOURCE: Broken screw of Light bulb stuck in Neff Oven
hi,,
make sure the power is OFF. get yourself a flashlight and a small flat blade screwdriver. okay you have to make a small bend in the old light bulb screw area so you can get a pair of needle nose pliers in there to get that out, you need to get right in between the threads of the socket and the old light bulb, just enough room to get a pier of needle nose to turn the old bulb out, be careful take time
J
Posted on Jun 29, 2009
SOURCE: CHANGE THE LIGHT IN MIELE OVEN
Had the same problem. Ended up removing interior oven panels (sides first then top on model H310B). This is easier than you might think. Could then get a good grip on the light's glass cover and it unscrewed easily.
Posted on Sep 25, 2009
How do I change the bulb inside the cooker of the B5741 cooker
Oven Lighting
Warning: There is a danger of electric shock! Prior to changing
the oven light bulb:
  • Switch off the oven!
  • Disconnect from the electricity supply.
Place a cloth on the oven floor to protect the oven light and glass cover.
Replacing the oven light bulb/cleaning the glass cover
  1. Remove the glass cover by turning it anticlockwise and then clean it.
  2. If necessary:
Replace bulb with a 40 watt, 230 V, 300 °C heat-resistant
oven light bulb.
3. Refit the glass cover.
Dado
Apr 15, 2015 | AEG Ovens
HOW TO REPLACE THE LIGHT BULB IN MY OVEN
Oven Lighting
Warning: Risk of electric shock! Prior to changing the oven light bulb:
- Switch off the oven!
- Disconnect from the electricity supply.
Changing the oven light bulb/cleaning the glass cover
1.Remove the glass cover by turning it anti-clockwise and then clean it.
2.If necessary: replace with 25 watt, 230 V, 300 °C heat-resistant oven lighting.
3.Refit the glass cover.
24472822-skr3uzd4ii43xzwyhmpsswym-3-0.jpg Dado
May 21, 2014 | Electrolux EOB5665G Ultrafan Electric...
Replace light
The instructions state:
1. Ensure the oven is disconnected from the electrical supply.
2. Turn the glass cover anticlockwise.
3. Remove the faulty bulb and replace with the new one.
4. Refit the glass cover.
5. Reconnect to the electrical supply.
Jan 09, 2014 | Zanussi ZBF360 Electric Single Oven
I am trying to replace the bulb on my Neff B1422NOGB oven. The instructions say to unscrew the glass cover anticlockwise. However, the cover only turns by a small amount (maybe just 5 degrees) and...
A common problem with this manufacturer I'm afraid. The screw thread of the glass almost welds itself to the metal casing it screws into.
It will turn and you can remove it however, the easiest way is to get leverage on the glass. This is best done by using a Baby Boa Strap Wrench, which you can pick up for a few pounds in a DIY store. I have removed many apparantly stuck round glass oven lamp covers in this way.
Aug 26, 2011 | Neff B1421 Electric Single Oven
How do I remove the glass cover to replace the light bulb
Hello, Thank You for using FixYa. I will be helping you today.If its stuck spray some pam around the base of the glass wipe up any over spray and turn the oven on 200 degrees for about 20min. let it cool and try to turn the glass cover.
Thank You and please rate my answer if it was helpful..
Jun 16, 2011 | Whirlpool 30" Self-Cleaning Freestanding...
I have a 30" (76cm)
Most ovens have either a flat piece of glass with clips either side covering the oven light or a round glass knob which unscrews. The glass covers can sometimes be difficult to remove due to heat and fat build up. You can tap the flat glass with a blunt object. You can use multigrips on the glass knob, just be careful.
Feb 14, 2011 | Whirlpool Ovens
Cover stuck on oven light
is it a wire? tilt wire to a side. if no wire its a glass thread
Feb 10, 2010 | Neff Ovens
Nov 19, 2008 | Miele DG 4080 Stainless Steel Electric...
Ovens Logo
Top Bosch Ovens Experts
ashburton
reliableservice
Are you a Bosch Oven Expert? Answer questions, earn points and help others
