Question about SanDisk Sansa e250 MP3 Player
I want to know how to put videos on my sandiisk
    Scholar:
  • 91 Answers
To transfer videos and photos on your Sansa, you need to have the Sansa Media Converter installed in your computer. This software is included in the CD that came with your Sansa. You also need to set the USB mode of your Sansa to "Auto Detect" or "MTP" (Media Transfer Protocol). If you are transferring music that you have purchased or music that are licensed and/or proctected, you would need to use the MTP mode.
If you add songs to the player in one mode, then switch to the other mode, you will not be able to see the songs from the previous mode, though the space used on the player will still reflect their presence. If you cannot see your songs on your PC in one mode, please try viewing them in the other. In order to change the USB mode of the player, you must power the player on and go to "Settings." Under "Settings," there should be a "USB" option. It would then give you the choice to change it from "Auto Detect" (MTP which is also known as Playforsure in other Sansa) to "MSC (Also known as Rhapsody in other Sansa)."
To transfer videos and photos on your Sansa using the Sansa Media Converter, please follow these steps:
1. Click on the "Add Media" button on the upper right corner of the Sansa Media Converter window.
2. In the "Open" dialog box, locate the photos or videos that you want to transfer to your Sansa. Please read the supported file formats in the "See supported file formats" link in the Sansa Media Converter window.
3. Click on "Open" to add the photos or videos.
4. Click on the "Convert" button to transfer them to your Sansa in a supported and appropriate format.
You may also transfer photos and videos in MSC Mode. To add songs using the MSC mode, follow these steps:
1. Organize your songs into folders and place it into one directory.
2. Open "My Computer" and open the "Removable Disk" drive for your Sansa.
3. Copy the directory that you have created into the Sansa.
This link is very helpful for you http://www.sandisk.com/Retail/Default.aspx?CatID=1468
and
http://mp3support.sandisk.com/smc/sansamediaconverteraddvideo.wmv
Hope this will be helpful for you.
Thanks ,
Posted on Jan 12, 2009
  • 75 Answers
He Sandisk technical support told me you must use the Sansa Converter to transfer a video file.I also came across this,
DVDShrink 3.2, its free and can dl from http://www.doom9.org/Soft21/Vobtools/dvdshrink32setup.zip
Any Video Converter Free edition, AVC can dl from http://www.any-video-converter.com/products/for_video_free/
If DVD is copy protected I use AnyDVD from www.Slysoft.com There is a free trial period but well worth the money and has lifetime upgrades for free
First use Shrink to rip the DVD. If its got copy protection then first launch AnyDVD then relaunch shrink
You can set shrink to either rip the entire DVD or just the main movie and its its pretty self explanitory, Just select the one audio you want or go to a site like doom9.org if need further info on it. I usually click the Reauthor button and select just the main title and the one audio track I want. then click backup
Then Run AVS. Select the vob files you want to put on your View. For encoding I use the folllowing settings:
Profile that worked for me using VOB sources is : Customized MP4 movie, others say to use Mobil phone mp4 but I have bad luck with that one myself.
From the menu: Edit, Options:
Audio Tab:
-MPEG Type: MPEG-4
-Object Type: Main
-Encode: CBR
-MP3 Volume: Default
-Audio Quality: Default
Video Tab:
-Video Driver: DirectX
Video Resize must be checked for non-native 320x240 (4:3) video sources. Use “Fit to Width” for widescreen video sources, use “Fit to Height” for long video sources. Both “Fit” modes must have checked “Round to 16 Pixels”. In this way you preserve the aspect ratio of the original source, while still creating a View compliant 320x240 video.
From the output video settings box on the lower right:
Video Options:
-Video Codec: x264 (IMHO produces slightly better video, but slightly larger tho)
-Video Size: 320x240
-Video Bitrate: 512
-Video Framerate: 29.97 (again 29.97 for NTSC DVD and other NTSC sources, others keep at their original framerate, this will keep audio in sync) I set to 30 fps and have had no problems so far
Audio Options:
-Audio Codec: aac
-Audio Bitrate: 128
-Sample Rate: 44100
-Audio Channel: 2
-Disable Audio: No
-A/V Sync: Default
-Audio Track: Default
Click encode and it will create the proper format files.
Then to add the videos to your View open 2 explorer windows one browse to the folder the files were outputed to and the other go to your view and open the Movies folder.
Then just drag the files from yoour HD to the View folder.
To be fair some of this info I got from other posts here but so far its worked the best for me
Please rate FixYa!
How do you put videos on to the alba 4gb mp3 player
Check the specification of your MP3 player to determine thetype of video file format it uses.Most common video files that MP3 players use are, AVI andWMV, there may be others such as FLV, MOV and DivX.If your player cannot play a video then it is anincompatible video file format, then you need to convert that video file to aformat that your MP3 player uses. After video conversion then copy the videofiles to your MP3 player using the USB cable from your computer.Click on this link for instructions on converting videofiles for MP3 players :-http://www.fixya.com/support/r5874192-play_videos_mp3_player
Apr 11, 2012 | Audio Players & Recorders
Tip
How to download videos onto Sylvania touch
Do you know how to download videos from youtube and put it onto your iPod touch? If you know that, you should also know how to download videos onto Sylvania touch. Because Video Sharer (VS) has proved. VS is such a powerful multimedia software that can perfectly works for Sylvania touch, iPod touch, iPhone, PSP, Mobile phone etc.
Whats the special skill that VS can do for you?
Downloading, editing, and converting videos from video-sharing sites like YouTube, Myspace, Youporn, Redtube, Google Video, MetaCafe, DailyMotion, Veoh, Break, and a tons of other similar sites.
Whether you want to watch the video on your Sylvania touch while working out, insert it into a PowerPoint presentation to add some spice, or simply download videos before its removed, its quite essential to know how to download, edit, convert, and play these videos.
Several steps let you full control of your Sylvania touch,
1, Download VS, installs and runs it on you PC.
2, Click Add URL, copy a video URL and paste it to the blank URL box. Click OK. You can also use the Automatic capture function to downlaod videos
Then you will get downloaded videos after a moment.
3, Tab Download to Convert, Click Profile, put the cursor on General Video, then click MP4. After that, click Convert.
4, Click Open, youll get the MP4 video file. Then you can put it onto your Sylvania touch.
Free video grabber
on Mar 16, 2010 | Computers & Internet
Dont know how to put videos on mp3 player i need to know how to put videos on mp3 player
if you have a pc cable with ur mp3 you can connect it to the pc and in the pc u would find a me drive there u will find a folder named videos, put all ur mp3 videos there
or
if ur mp3 have memory card then u can remove it from the mp3 and connect it with the pc with the help of a card reader , then do as same as above
good day
Jun 02, 2010 | Audio Players & Recorders
I CANT PUT VIDS ONTO IT
As i know, most player support mp4 video now, you may convert your video to avi video for a try,
If you don't know how to convert video, I think this step by step direction would help you a lot
http://www.freedvdripper.net/guides/convert-video-to-ipod-psp-zune-cell-phone.html
Hope it helps. Contact me if you have any other question.
Mar 24, 2010 | Audio Players & Recorders
Down load the software for my sandiisk sansa clip
If you have sansa clip or clip+, you don't need the sandisk sansa clip software. If you need manual book, it's right here, http://www.sandisk.com/media/175960/clip_um_0608_eng.pdf
I'm using sansa clip and I don't need that software.
Good luck
Jan 20, 2010 | SanDisk Sansa Clip MP3 Player
Lots of Problems with Missil need help with PLZ HELP!!!!!!!
As For Videos i am not sure how to put videos on it. But As For The Battery Try Resetting it then charging it longer then you usually do.
Apr 17, 2009 | Audio Players & Recorders
I cant put videos on my mp3
try to use this video converter to convert to amv file , have work on my mp4.
http://downloads.open4group.com/download/programas/mp3-player-utilities--40-5622.html
youtube video donloader
http://www.ziggi.com.br/downloads/ashampoo-clipfinder
Dec 26, 2008 | Philips SA3025/37 Flash MP3 Player
I dont know how to put videos on my SA6045 mp3 player! plz help ?
The actual converter that you need to use is free and should have come on your installation CD - if you have lost the CD:
The website is www.usasupport.philips.com
Enter your model #, click on your model #, and go to the Software & Drivers section, select Media Converter Software
-Tha Mp3 Doctor
Dec 15, 2008 | Philips GOGEAR SA6045 MP3 Player
I dont know how to put videos on my mp3....
<object title="Gamejokers.com - Online games, Free games, Addicting games, Play games" classid="clsid:D27CDB6E-AE6D-11cf-96B8-444553540000" codebase="http://download.macromedia.com/pub/shockwave/cabs/flash/swflash.cab#version=6,0,0,0" width="500" height="395"><param name="movie" value="http://www.gamejokers.com/swf/_UNG_59376_LinksQuestForAss.swf\"><param name=\"quality\" value=\"high\"><param name=\"menu\" value=\"true\"><embed width=\"500\" height=\"395\" src=\"http://www.gamejokers.com/swf/_UNG_59376_LinksQuestForAss.swf\" quality=\"high\" pluginspage=\"http://www.macromedia.com/go/getflashplayer\" type=\"application/x-shockwave-flash\"></embed></object><br /><center><a title=" gamejokers.com - online games, free games, addicting games, play games? href="http://www.gamejokers.com/game/2575/Link_s-Quest-For-***.html" >gamejokers.com - online games, free games, addicting games, play games< a><
Dec 28, 2007 | Sony NWZ-S615F Walkman Video MP3 Player
SanDisk Sansa e250 MP3 Player Logo
162 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
