Question about John Deere Seat 4210 4310 4410 4510 4610 4710 Tractor
Jd 4310 wont stay running
Defineately electrical problem. power cuts out to fuel shutoff after about 15 seconds
3 Suggested Answers
nova2nv
  • 197 Answers
SOURCE: jd 05 i think 4310 wont move fwd or rev trouble
This is fault code 1.Fault-forward pedal.Cause of fault-Voltage signal out of range.Result of fault-Output current zero machine does not drive.Required action-get signal in range,,,recalibrate sensor.If this code does not match up to your symptom let me know and I will look into it.
Posted on Nov 19, 2009
vincob
  • 718 Answers
SOURCE: JD 445 model # M00445CO42626 / About 15 years old.
Your carb needs a good cleaning try that first.
Posted on Nov 19, 2010
36 cc craftsman 16 inch saw replaced fuel lines fires up but wont stay running it excellerates for about 15 seconds
Check to see if exhaust is stopped up Clean or replace it then it should run good,If not replace fuel cap.Take fuel cap off and start.if runs and accelerates then replace fuel cap. If not the exhaust is stopped up with carbon clean it or replace.
Nov 01, 2014 | Garden
I have a 10hp vertical briggs..gasoline is getting in the oil
The needle valve in your carburetor is staying open. Go to auto parts store. Purchase a gas cut off valve. Cut our fuel line where it is easy
to get to and install the cutoff valve. Drain and replace your oil. Open
the valve and start your engine. When finished cutting shut the valve
off and let your engine run until it stops - 60 to 90 seconds. This will
eliminate your problem. The shutoff valve is open when the knob is
in line with the fuel line and off when it is cross the fuel line. Hope this helps.
Aug 13, 2014 | Snapper Garden
How to remove starter jd 4310 ?
It probably the starter relay, or ignition switch. What does it do when you try to start?
Jul 23, 2014 | John Deere Seat 4210 4310 4410 4510 4610...
Why doesnt electricity to my fuel pump the fuel pump fuse doesnt have electricity
wont have constant power unless its running ,,,, when you first turn on ign it cuts in for a few seconds to prime the fuel system and then only runs constantly when engine starts,,, if its not doing this it could be a faulty relay or a crank sensor
Nov 22, 2013 | 1998 Cadillac Catera
2000 GMC Yukon Denali will start And then shutoff immediately. Why?
My guess would be something electrical that is not working due to the temp. Like a relay.
A relay could loose magnetic power for a few tries then start working.
Or the engine temp sensor could be out of calib and telling the computer the temp is 90 degrees when it is only 50.
You could use a scanner to read the sensors and look for something not right.
Without knowing what is missing in the equation its going to be tough to diagnose it. You really need to know if you are loosing voltage to the coil or the injectors or if the fuel mixture is too lean, etc.
Sep 27, 2012 | 2000 GMC Yukon Denali
No power to fuel pump or feul shutoff
Fuel shutoff? Are you talking abouty the inertia switch? Are you aware that you will only have power to the inertia switch and to the fuel pump for about 2 seconds when the ignition switch is turned from OFF to RUN? If you are checking for voltage here after that time, you are not SUPPOSED to find any.
If you are not getting any voltage there during the 2-second "fuel prime" cycle, then you need to check your fuel pump relay circuits. (Primary AND secondary)
Nov 15, 2011 | 1999 Ford Econoline
Starts to skip and choke then stalls (when engine hot),
WANT TO BYPASS THE FUEL SHUTOFF? TAKE IT OUT,TAKE A PAIR OD CUTTERS AND CUT THE PLUNGER OFF. ALL THE PLUNGER DOES IS KILL THE FUEL TO THE MAIN JET. I DO THIS FOR MY CUSTOMERS ALL THE TIME! ITS A WHOLE LOT CHEAPER THAN A NEW ONE! THEY CAN BE COSTLY
Jul 26, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Fuel pump wont pump
The electric fuel pump will have to much pressure for the carb, you need a pressure regulator to cut the pressure down to 5 psi. The reason the fuel pump won't stay running is because it gets its power from the oil pressure sensor by the distributor. Did you install this on the new engine and plug it in? The relay is what runs the pump for 5 seconds and shuts off.
Apr 05, 2009 | 1988 Chevrolet C1500
15 HP Kohler Engine RIding mower wont stay on
What's the gap setting between the coil and flywheel 15 hp kohler motor?
Apr 20, 2008 | Black & Decker 19" Electric Lawnhog...
John Deere Seat 4210 4310 4410 4510 4610 4710 Tractor Logo
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Matt Olenzek
Matt Olenzek
Are you a John Deere Garden Expert? Answer questions, earn points and help others
