Question about Toshiba 32A43 32" TV
Toshiba tv 32a43 changes input by itself
I turn the TV on, and it automatically scrolls through all of the input options. I cannot get it to stay on any of the input modes. The remote control doesn't work either.
    Top Expert:
  • Toshiba Master
  • 14,553 Answers
I will try to explain this: I first presume there is a physical button on the set for the input options.
I have seen this a lot:
Not the plastic button on the set but the tiny push switch behind it.
These are called momentary switches as only should function when the plastic button is pressed and contacts the momentary switch.
They go bad, and will internally engage without be touched.
The simple way to prove/disprove this is to open the set and get at that switch which usually is soldered into a small circuit board--two pins for the switch and maybe two more tabs for mounting.
If individual switches unsolder and REMOVE THE INPUT SWITCH (the one under the plastic button on the set)
Set should now operate normally and remote should have same feature on it. If it works you do not have to replace anything.
FYI: the reason the remote may not be working is the buttons on the set have PRIORITY over the remote.
Both the remote and the buttons go to the same area inside the set but buttons are #1 in line.
Posted on Dec 05, 2012
ebrus
  • 30 Answers
SOURCE: Toshiba 24AF44
You need the original remote controller to be able to switch input modes.Universal ones usually don't work. If you don't have the original remote and can't find it ever or if it is too expensive you can buy an rf modulator ( very cheap) and connect your dvd player, game console etc) to the modulator then connect the modulator to your antenna with a coax cable. This worked for me. It placed the connection to channel 4 and other cable channels are still working,
You can buy the RF Modulator from: http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=180299245670
Posted on Oct 28, 2008
  • 1694 Answers
SOURCE: Toshiba 36inch color tv demo troubleshooting
Demo is activated / de-activated by holding a combination of
two buttons on the tv front for at least four seconds. Try menu &
power or vol up & chan up...........T.
Please rate this solution.......
Posted on Nov 12, 2007
  • 15 Answers
SOURCE: How to get TV/video mode without remote
some tv do that changing the channels.
in the control panels in the tv where r the buttons for change channel there must be video button, push it and there you go.
Good Luck
Posted on Jan 12, 2009
  • 8457 Answers
SOURCE: How can I use the input on my toshiba TV without a remote?
Press the UP/DOWN channels buttons u well get a couples channels,than u will get the input, to use for input divices.If ur tv don't have the menu button on the front pannel of the tv.
Posted on Aug 28, 2009
SOURCE: Toshiba (Model : 36A43) - volume goes down automatically
I am having same problem on 32 inch same problem. After playing with board with no results,I tried front buttons and found that if I held the power button in ever so slighItly as not to turn it off, it fixed problem which is the micro on/off switch, I removed the switch and used the remote and everything is back to normal, I am about to insall a used micro switch after I finish typing this but I am sure this will clear up volume problen and menu going crazy problem if not I will just leave micro switch out and use the remote, and I will get back to this board only if that micro switch still causes the problem, so if I don't post in next hour the problem is fixed and I'm more than glad to help.
Posted on Sep 14, 2009
Power surge
Yes possibile there's some IC's that are burn inside it and also the power supply can be damage so resetting it will not do anything , if you can take it to a repair center and let them check this unit and fix it.
Good luck........
Aug 09, 2008 | Toshiba 32A43 32" TV
When we try to turn on the tv (toshiba model 32A43) it makes the sound of turning on then off and the screen stays black and a red light by the power button keeps binking
You're either losing high voltage or power supply is not producing the horizontal drive signal, Check for 130v on the collector of the horizontal output transistor, if you're missing your voltage, you have a power supply problem. If voltage is too high you have something open in the power supply such as a low value resistor. If its low, something is shorted in power supply, possibly voltage regulator ic.
Jul 31, 2011 | Toshiba 32A43 32" TV
My tv hasa problem whenever i plug the cable for tv and or a dvd playr nothing happens no picture but it turns on i can go to menue i tried proggraming the channels and still nothing\
Let me know is it Toshiba 32A43 tv or any other model?
Do you get sound of tv in any input, like dvd playback or cable channels?
Can you test voltage in circuit board with multimeter, it will help me to diagnose problem.
I'll try best to help you to get this tv fixed.
Thanks.
Nov 02, 2010 | Toshiba 32A43 32" TV
Toshiba 32a43 32' picture garbled mess
If you can get the tv to display the blue blackground(usually happens when there is no antenna or cable feed to tv) check to see if the whole screen is a solid blue, if it shows discolored areas around the screen then you might have to "demag" the screen. See if you can rent a demad coil from a tv shop and with tv on turn the coil in circular movements all over the front of screen till blue is solid.good luck!
Aug 03, 2009 | Toshiba 32A43 32" TV
Tv will not stay on just tv
Look at the IR emmiter "eye" on your remote thru your Cell phone camera. You can tell if the remote is constantly emitting a signal.
Jan 27, 2009 | Toshiba 32AF43 32" TV
Vertical hold problem
There is a fault in either the input video amp, sync amp, sync separator, or the vertical scan generator areas. Most of the time this type of failure is caused by capacitors in these areas going off spec from age and use.
An experienced TV tech who is familiar with your set should be able to service this for you.
Jerry G.
Jul 16, 2008 | Toshiba 32A43 32" TV
Menu pop ups
dopy, the problem is leaky tact switches on the control board, have changed out many of these especially on the 2003 model which of course is the 32A43, part number for the switches is 23344443, swap them and your done, BMW Rider
Sep 06, 2007 | Toshiba 32A43 32" TV
Tv problems
There are a number of things that can cause this.
If you have a compact flourescent lamp in the room, this can cause some models of TV sets to go nuts, or not respond to the remote. These compact flourescent lamps use a frequency band that is close to the data carrier freqency of the remote.
Excellent article about compact flourescent lamps interfering with appliance IR remotes:
http://www.neptunlight.com/files/IR-and-CFLs.pdf
The other thing that can be wrong is there may be a fault in the keypad assembly on the TV set, or a fault condition with the uPC.
Jerry G.
Jul 02, 2007 | Toshiba 32A43 32" TV
Toshiba 32A43 32" TV Logo
77 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
