Question about Motorola Mobility H680 - Headset - wireless - Bluetooth - black
Motorola H680 battery Replacement
Battery no longer holds a charge for very long - only getting about 15 minutes of talk time. How do I replace the battery in this unit?
How can I get my Samsung Galaxy Tablet to turn on. The battery is fully charged.
There is usually a method such as holding the on button for a longer period of time. If it is easy to do the other thing that I've found with all sorts of "smart" devices which turn "not-so-smart" is to remove the battery for a minute or so, then put it back in. Many times the unit will turn on as soon as the battery is reinstalled and work correctly again after that. Last ditch effort, unless someone knows about the Galaxy, is a hard reset, there may be a reset button somewhere on the unit, I don't think the Galaxy has a reset button. If the unit still does not turn on it may need servicing.
1. Try the on button for 15 - 20 seconds if you know it is charged
2. Try charging for an hour or two then the 15-20 second hold on button, #1 above.
3. Removed battery (I'd measure the battery voltage while I have it out) wait ~1 - 2 minutes & reinstall the battery. If it doesn't turn on by itself try #1.
4. Nothing works start a service ticket with Samsung, URL:
http://support-us.samsung.com
You might try searching there as well for an answer to see if there's anything I missed.
Jan 31, 2015 | Samsung Galaxy Tab Tablet PC
Battery wont work without the charger plugged in
All batteries have a FINITE amount of time before they can no longer hold a charge, if your battery is older then a year it is no longer covered under warranty either. Have you noticed prior to this that the battery was holding less and less of a charge? ALSO batteries do over heat and stop receiving a charge, best way to tell is to keep the laptop plugged in. unplug the battery for a minute, then plug it back in and see on your task bar if it says charging or plugged in not charging. let me know! good luck to you as well!
Sep 06, 2012 | Dell Inspiron 15 Laptop
My battry is not charging properly.it goes upto 100% and the charge is finished in 4 or 5 minutes
Laptop batteries worn out with the passage of time and their charge holding capacity decreases.
The battery now has very less charge holding capacity (equal to 4-5 minutes), that's why it says it is 100% charged (capacity of 4-5-minutes).
So, it is recommended to replace the battery with original battery as it would last longer and serve you better.
Let me know if any further clarification/ assistance is required.
Good Luck!
CreativeTECH
Dec 15, 2010 | Compaq HSTNNLB42 Laptop Battery
LG VU,battery indicator shows fully charged but I can only talk a couple of minutes before phone shuts off and shows dead battery? Just a dead battery or something else going on here?
I believe the cells of your battery is very weak that is why it can no longer hold charges for long.
All you need to do is to get a new battery on your phone and makesure you charge the new battery to its maximum capacity before you start making use of it.
This will help preserve the life span of the battery and make it last longer.
Take care.
May 02, 2010 | LG Vu CU920 Cellular Phone
Power is green but when i turn on clean status is red and power is red
Battery time! Get a nice new longer life battery on Ebay, or go for the Nicad replacement if you have no carpet and want to save some cash.
You have dead nimh (nickle metal hydride) batteries. You will need a replacement. You can test for this by removing the battery and holding the power button for 15 seconds. This will restart the charging cycle as if the battery were new.
Mar 15, 2010 | iRobot Roomba 560 Robotic Vacuum
Inspiron 640m
Portable batteries are considered a consumable item because as they are used, there is some degradation to the battery. The average life of a portable battery is 300 to 500 discharge/recharge cycles. After that point, the battery's ability to hold a charge slowly decreases, to where it will only power the system for 10 to 15 minutes even when indicating a full charge.
If this is the Original System Battery, then you will need to get a replacement battery to have the system run for a longer period on battery only.
Jul 03, 2009 | Dell Inspiron 640m Notebook
Invalid battery
The battery is probaly no longer capable of holding a charge, you can get a replacment Motorola V170 battery here - Motorola V170 battery
Apr 13, 2009 | Motorola Mobility V170
My MOTOKRZR K1 battery/phone will not stay charged very long.
Let ur phone completely die. Don't charge it or anything when the low battery notice comes on. After it completely dies, put it on the charger only until it says charge complete. U might have to do it a few times to get ur battery performing as it should. If you charge ur battery too often, it causes ur battery to swell (weird I know) and your battery starts resisting charge. Hope this helps!! (I used to have the same phone and the same problem. I did this, and now my mom is using the phone and has an exceptional battery time)
Mar 21, 2009 | Motorola Mobility MOTOKRZR K1 Cellular...
Motorola Mobility H680 - Headset  - wireless - Bluetooth - black Logo
260 people viewed this question
Top Motorola Mobility Radio Communications Experts
Lawrence Oravetz
Dennis
Are you a Motorola Mobility Radio Communication Expert? Answer questions, earn points and help others
