Question about Casio Office Equipment & Supplies
SOURCE: how do I calculate normal distribution using a
I don't know about fx-9750gII, but for fx-991MS
Change the mode to REG
Then
Shift->3(DISTR)->1(P())->give your Z value
Posted on Feb 04, 2010
SOURCE: i do not know how
Hey it is. Okay, so start with a equation: say, y = -(1 |x|). Now type y = -(1 , then press the [OPTN] button, next to the shift. Next press the [NUM] button or F5. The first menu button should be Abs or absolute value. When your done it should look like this. y = -(1 Abs (x)) then graph it.
Posted on Aug 30, 2010
SOURCE: In casio fx-991ES, i am
This post is rather exhaustive as regards the matrix capabilities of the calculator. So if the post recalls things you already know, please skip them. Matrix multiplication is at the end.
Let me explain how to create matrices. (If you know how to do it, skip
to the operations on matrices, at the end.)
First you must set
Matrix calculation
[MODE][6:Matrix]. Then By entering one of the numbers [1:MatA] or
[2:Matb] or [3:MatC] you get to choose the dimensions of the matrix
(mxn]. Once finished entering the matrix you clear the screen.
The operations on matrices are available by pressing [Shift][Matrix]
[1:Dim] to change the dimension of a matrix (in fact redefining the
matrix)
[2:Data] enter values
in a matrix
[3:MatA] access Matrix A
[4:Matb] access Matrix B
[5:MatC] access matrix C
[6:MatAns] access the Answer Matrix (the last matrix calculated)
[7:det] Calculate the determinant of a matrix already defined
[8:Trn] The transpose of a matrix already defined
To add matrices MatA+MatB (MUST have identical dimensions same m and same n, m and n do not have to be the same)
To subtract MatA-MatB. (MUST have identical dimensions, see above)
To multiply MatAxMatB (See below for conditions on dimensions)
To raise a matrix to a power 2 [x2], cube [x3]
To obtain inverse of a SQUARE MatA already defined MatA[x-1]. The key [x-1] is the x to
the power -1 key. If the determinant of a matrix is zero, the matrix is singular and its inverse does not exit.
Dimensions of matrices involved in operations must match. Here is a
short summary
The multiplication of structured mathematical
entities (vectors, complex
numbers, matrices, etc.) is different from the multiplication of
unstructured (scalar) mathematical entities (regular numbers). As you
well know matrix multiplication is not commutative> This has to do
with the dimensions.
An mXn matrix has m rows and
n columns. To perform multiplication of an kXl matrix by
an mXn matrix you multiply each element in one row of the first
matrix by a specific element in a column of the second matrix. This
imposes a condition, namely that the number of columns of the first
matrix be equal to the number of rows of the second.
Thus, to be
able to multiply a kXl matrix by am mXn matrix, the number of columns of
the first (l) must be equal to the number of rows of the second (m).
So
MatA(kXl) * MatB(mXn) is possible only if l=m
MatA(kX3) *
Mat(3Xn) is possible and meaningful, but
Mat(kX3) * Mat(nX3) may not
be possible.
To get back to your calculation, make sure that the
number of columns of the first matrix is equal to the number of rows of
the second. If this condition is not satisfied, the calculator
returns a dimension error. The order of the matrices in the
multiplication is, shall we say, vital.
Posted on Dec 23, 2010
SOURCE: I have a Casio fx-9750GII,
From the Run Mode (select it and press exe), enter Setup (Shift Menu) and then highlight Angle. Press the function key that correponds to Deg and then press Exit.
The manual for the Casio Fx-9750GII is here: http://support.casio.com/manualfile.php?rgn=1&cid=004002013 . Other calculator manuals are here: http://support.casio.com/manuallist.php?rgn=1&cid=004 .
I hope this helps.
Posted on Jan 19, 2011
SOURCE: casio fx-9750gII looking for factorial
press Option, F6, F3, F1 to find the "!"
Posted on Mar 18, 2011
Testimonial: "Thank you very much I finally found it after searching and searching through the manual!"
Jan 05, 2016 | Casio Office Equipment & Supplies
Oct 13, 2015 | Casio FX-9750GII Graphing Calculator
Oct 14, 2014 | Casio FX-9750GII Graphing Calculator
Oct 16, 2012 | Casio Calculator Graphing FX 9750GII...
May 02, 2012 | Casio FX-9750GPlus Calculator
Feb 22, 2012 | Office Equipment & Supplies
Jul 31, 2011 | Casio FX-9750GPlus Calculator
Jan 19, 2011 | Casio FX-9750GPlus Calculator
Jan 12, 2010 | Casio FX-9750GPlus Calculator
Jan 07, 2010 | Casio Office Equipment & Supplies
710 people viewed this question
