Question about Xerox Phaser 4600N Printer
Xerox Phaser 4600 random toner smudging
Brand new Xerox Phaser 4600 printing just fine, but toner is smudging randomly on each page, even blank pages. Replacement toner/drum units are a little pricey, so cleaning options would be preferable to component replacement.
Soulvisitor
  • 1113 Answers
SOURCE: Xerox Phaser 6250
How Brave is Jan?
Doubt it be the fuser(100 000life), "just magenta dots".... fuser would be "all smudged" or "black marks" , "the print rubs off" , "paper is creasing or jamming"
Can prove it by stopping a print (open door) when paper is1/2 way threw machine, you need to stop it before it goes threw the hot bit, so you can tell if the hot bit (fuser) puts the marks on the paper.
Transfer roller one would expect to effect whole print Smudged/Faint,uneven density
It will be the imaging unit ( 30 000 pagelife Ouch$ ) or possible leaking toner (if aftermarket)
Remove imaging unit and inspect film you should find image of lines, dots are usually chips or sticky stuff on drum surface, carefull no oily human fingers on surface please.
When stopping machine mid print and perfecting your timing, pull out the imaging unit and look at replica of your print notice if marked and where.
Hope this helps
Posted on Nov 19, 2007
  • 2072 Answers
SOURCE: Xerox Phaser 8400N Printing Stripes
When you go into the eliminate light stripes there is also a mode called Jet Substitution. You can sometimes bypass the bad jets.
If that does not work then the print head will most likely need to be replaced.
You can replace the printer for less than the cost of a print head normally..
Posted on Jul 08, 2008
  • 2072 Answers
SOURCE: workcentrepro 575 will not reset
This should reset that for you.
NOTE: Perform the following procedure to reset the Drum Cartridge counter after you replace the Drum Cartridge. Do not perform this procedure at any other time.
  1. From the Standby Mode, press the [Menu] (up arrow) button, then press [5], [2], [0], [4]. The screen will display: Change drum.
    1. Yes
    2. No
  2. Press [1], then press [Enter]. The screen will display: Completed.
  3. Press [Stop] to return to the Standby Mode.
Posted on Aug 14, 2008
worldvet
  • 859 Answers
SOURCE: I have a xerox xc1044
I'm not going to help you with this, no matter that I have the code fix to give you or not.
Try Yahoo Answers.
Posted on Oct 26, 2008
ikechinedu
  • 184 Answers
SOURCE: Invalid Black Toner Xerox Phaser 6110 MFP
reload the driver again and if it persists, change the toner
Posted on Jun 23, 2009
Phaser stuck warming up
Your Configuration Chip 069E00520 may be bad.
If not that...then the Main Controller 960K41683 would be the culprit.
Oct 08, 2015 | Xerox Phaser 6360DN Printer
Xerox 3250 printer smudges with new toner cartridge
Go to the settinge. Go to maintenance a perform the cleaning steps.If that doesn't correct exchange cartridges . Remember recharged cartridges have problems. Possible you need to shake the cartridge.
Feb 25, 2013 | Xerox Phaser 3250DN printer BW laser...
Xerox Phaser 6125 prints pink
you cal also try to clean the laserwindow of the Magenta imaging unit
Nov 08, 2012 | Xerox Phaser 6125 Laser Printer
Vertical lines of missing print
I'd certainly be swapping the fuser first although I know how expensive they can be and what a pain they can be to get at. You've tried everything else I would start with and as the text is smudging I'd certainly be testing the fuser next. Scott.
Dec 12, 2009 | Konica Minolta magicolor 2500 Printer
Jun 23, 2009 | Xerox Phaser 6110MFP All-In-One Laser...
Problem with phaser
Phaser 2135 Printer: Resolving dirty looking background or gray haze
Description: Tiny speckles of toner scattered all over the page, even in areas of the page that should be blank.
  1. Make sure the media being used is supported by the Phaser 2135 printer.
  2. Inspect imaging drums for any signs of leakage or excess toner that could be falling onto the print as it travels though the printer. Any leaking imaging drums should be replaced.
  3. Verify environmental conditions. See article Dealing with humidity, humidifiers. If the environmental conditions are not within the specified range, the printer should be moved before trying to troubleshoot the cause to the background toner.
  4. Determine if any of the imaging drums were exposed to light for an extended period of time (more than 10 minutes). If so, then Replace the imaging drum. (Xerox is not responsible for any imaging drums that have been damaged by over exposure to light.)
Additional Recommendations:
Background toner may increase, if printing occurs at temperatures towards the higher end of the specified operating temperature range. For this reason, it is recommended that the printer be moved to another area if at all possible.
In addition, very smooth media types such as glossy; allow toner to more easily scatter about the page prior to becoming fused. Try using a less smooth media if at all possible.
Feb 08, 2008 | Xerox Phaser 2135N Laser Printer
Xerox Phaser 6250
How Brave is Jan?
Hope this helps
Nov 19, 2007 | Xerox Phaser 6250 Laser Printer
Xerox Phaser 4600N Printer Logo
204 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
