Question about D-Link Xtreme N Dual Band Usb Adapter (N69506)
Not enough internet connection getting to my adapter
I only get maybe 50% internet connect and im thinking maybe the other channel of the dual channel adapter might be needed but I dont know how to switch it. Im using the wireless n750 dual band router in conjunction with this unit
  • D-Link Master
  • 7,733 Answers
Contact your ISP
Posted on Dec 06, 2012
SOURCE: wireless connection manager
remove all entries - run regedit delete all values from the adapter software and reinstall
Posted on Mar 10, 2008
ayamaya
  • 143 Answers
SOURCE: Wireless connection problem whenever I switch on my laptop
you need to isolate first which of the devices is giving you the problem.
- check first the connection from your modem by connecting a computer directly to it. check if you'll loose the connection from the modem. if so, you need to check with your internet provider if they're having maintenance from time to time since that could be the reason why the router is not providing the connection to your laptop automatically and you need to restart it to sync with the modem first.
- if you have a proper/stable connection directly from the modem, next thing to check is the connection from the router. check if your wired computers are getting the same problem. if so, you may need to check for loose/faulty cables or you may need to upgrade the firmware of your router. if the wired computers are not getting the same problem, it's time to check the wireless settings of the router.
* access the router's page by typing http://192.168.0.1 on your web browser's address bar (default username is "admin" while the default password is "password")
* go to the wireless settings page and check if the wireless name (ssid) is not the default. if it's still using the default ssid, customized it to prevent interference from other dlink network near your area
- if you have check the modem and the router, it's now time to check the wireless adapter, make sure that it is connected to your own network. if you are using it's software utility, make sure that you have created a profile using the same ssid as of your router. you can also update the driver of your wireless card if you have checked the above mentioned and you're still having the same problem
you can also try to use another wireless computer and check if it'll experience the same problem to properly isolate the if it's the router or the wireless adapter problem. you can also try to install the wireless card to another computer and check if you'll have a stable conection. if so, there could be a software (like a firewall or an antivirus software) that is giving you the problem.
hope this'll help you and just ask me if you have other concern.
ciao!
Posted on Jul 02, 2008
SOURCE: My d-link DIR-301 router is connected to my pc and on the net but connected wirelessly to my laptop local only no internet conncetion tired everything but no hope
check the firewall on your laptop sometime these block it from connecting
Posted on Aug 16, 2008
hdpanama
  • 65 Answers
SOURCE: wireless connection problem. laptop ip address is 60.60.x.x
D-LINK WILL HELP YOU...
Set up your new D-Link networking hardware in minutes using our new Quick Setup Wizard. The wizard will guide you through an easy to follow process to install your new hardware and connect to your network. If you need additional help, visit D-Link’s award-winning Customer Support Web Site for answers to frequently asked questions, product downloads, and easy access to D-Link’s friendly customer support team.
Posted on Nov 27, 2008
rahul26485
  • 611 Answers
SOURCE: wireless router through Cisco ASA 5505 series
put the one cable to wan which come from internet and you have to connect the pc or any other connection then you connect in the lan
Posted on Dec 31, 2008
Limited connectivity
Limited connectivity (this phrase occurs first inside the WIN 8 OS) means, that you have connection with your router already, but NOT to the internet. Pls. check, if you have access to internet from other computers or smartphone connected via the same router.
If so, sometimes a driver-update for your D-Link could be useful.
Check also, if other wireless adapters are working with the same frequency, this may disturb. Try to change the channel or change from 2,4 GHz to the 5 GHz Channels, if the router & your D-Link Adapter will support this.
I had the same problem with my WIN 8 - PC and I had to change the (wireless) radio-channel.
Aug 15, 2013 | D-Link D Link Dir 825 Xtreme Dual Band...
Graphics card hdmi output to monitor digital input seems to not be working
i am having a problem with my sound and i need sound driver for dell dimension 2350
May 22, 2009 | Gigabyte Computers & Internet
USB wireless internet adapter disconnecting
Sounds like the usb ports are sharing an I/O channel. So when you unplug one usb device the CPU is being told that the USB port is not being used.....Maybe..... To test this, hardwire into a data cable and plug in different devices, next unplug a devise and see what happens. If you stay connected you may have found your answer. Unfortunately I don’t think a reimage or restore will fix the problem. If you get the same result try a reimage of your OS. Good luck.
Again sound like a mother board issue.
Questions to ask, When did I notice the problem (Maybe able to restore to the point the problem started.) and did I install new software or hardware when this happened?
Good Luck
Apr 05, 2009 | NetGear WPN111 RangeMax Wireless USB 2.0...
Linksys dual-band wireless-n gaming adapter + westell versalink
put all the adresses and getways(on xbox internet setings same as pc then it should work
Mar 25, 2009 | Linksys Dual-Band Wireless-N Gaming...
Wireless Network working on laptop, lost internet on desktop.
If you disconnect the desktop from the modem, were you able to get an Internet connection in your laptop?
In order to get Internet connectivity on your desktop at the same time with the laptop, then the desktop needs to be connected to the router. It should be connected to one of the Ethernet ports at the back of the router. Since, your desktop doesn't have an Ethernet port, then you need to connect a USB to Ethernet adapter to your desktop. Then from that adapter, you will connect to it an Ethernet cable going to the router.
You may check the following models:
Linksys USB200M
Linksys USB100TX
Belkin Gigabit USB 2.0 Network Adapter(F5D5055)
D-Link DUB-E100
There are other brands that offer USB to Ethernet adapters that you can check.
Hope this helps!
Nov 22, 2008 | Linksys Wireless-G Broadband Router
Belkin G+ mimo adapter (a timely problem)
that does seem a long time to connect... is it the wireless connection or getting an IP that is the delay... if it's IP then the network icon in the taskbar will have a moving part to the icon rather than being static... kinda yello ball running along a wire (if ya know what I mean)
try THIS util to see what your signal strength is and if there any other services sharing the same channel. Maybe you need to change the channel of the router?
Jul 16, 2008 | Belkin (F5D7050) 802.11a/g/b Wireless...
Laptop wireless internet connectivity
use the zyxel you have best range and good signal also otherwise you take a acces point and you get it the best of the best link and signal
Jun 10, 2008 | NetGear (IM-WG511T) Wireless Adapter
Connected to acess point but internet
The first thing you should try is connecting one machine via a cable to the router, to see if the connection is stable. This will prove the router is working, or not, as the case may be. Assuming the router still fails to function properly, you can then replace it.
However this assumes that the modem and internet connection are working properly. If either is causing the problems, then the router might be just fine.
But if the router does appear to work fine when wired in, then it at least proves everything outside the router is fine. And while it is possible, it is rather unlikely that just the wireless part of the router failed without killing the switch/router part.
So try this, and once we have the result, we can take the next step
Jan 29, 2008 | Linksys WPC54G Wireless-G Notebook Adapter...
Netgear wireless adapter
When you say home bases, i assume you mean desktop pc's. If the channel you mention is the channel that the router works off eg channel 11 then all wireless adapters have to be set to channel 11, or the same channel as the router. The reason for one disconnecting from the internet will probably be the adapter losing the signal because of obstacles like walls and doors, as if the signal gets too low then the reciever cannot connect properly with the router, hence dropping the connection. Try the router in a different higher position or at a phone socket nearer the troubled pc. The connection accross the network should be atleast good and at 54 MBPS, anything less may not connect properly. The laptops will tend to have a stronger connection as most have a signal up booster built in the screen.
Apr 11, 2007 | NetGear WG111 802.11g/b Wireless Adapter
D-Link Xtreme N Dual Band Usb Adapter (N69506) Logo
67 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
