Question about Miele S7210 Bagged Upright Vacuum
When the brush is on it won't **** properly
When the nozzle is on the hose sucks properly, but when the brush is on there's so little suction it does not pick up from the carpet properly.
    Top Expert:
  • 14,553 Answers
Look for blockage carefully as the unit does not know which you have attached.
Posted on Dec 06, 2012
4 Suggested Answers
  • 383 Answers
SOURCE: When vacuuming carpet with the electric power
You gave a good start to giving us good information to help you with solving this problem-- But I need a little more information:
It sounds like you have the Electric Motor driven Power nozzle/ Floor attachment-- am I correct? (Not the type that has a little vacuum motor down at the floor attachment-- Not one that depends upon air flowing thru the unit to power the brush, -- am I correct?)
You can control the motor with a switch at the handle-- correct?
So here is the question: - when you say "the electric power brush -- goes to zero suction" -- what tells you that it 'went to zero suction'?-- the little red flag on the vacuum?-- or what?
I am suspecting something might be caught up in the floor wand-- or at the power nozzle itself-- or even in the flexible hose. Do you know how to take the hose off, and place the hand-held end, in the opening in the Miele Vacuum? Can you do that, and clear out the hose first-- and then the hose with the want connected?
If they are all clear-- we may need to open the floor plate on the floor nozzle, and check for something caught in the air passageway--
Tell us more
Mack B
Posted on Dec 28, 2010
  • 29 Answers
SOURCE: suction stopped working
Sounds likw you have a clog in the tube. You will probably need to take it apart to find what ever is stuck. It was some pieces of paper that jammed mine once and now I try to pick up anything that seems large to avoid the disassembly again.
Posted on Jun 15, 2009
fixdat22
  • 34 Answers
SOURCE: My S 7000 upright vacuum red carp light on
its probobly the belt is broken
Posted on Sep 12, 2009
Power nozzle motor not working on my rainbow e2 vacuum?
Check plugin on the power nozzle and poles there may be some thing blocking connections
Dec 28, 2013 | Rainbow E series Canister Wet/Dry Vacuum
My dyson hose sucks good but, when i put handle down, it won't **** but brush does turn
I just had the same problem....suction from wand, but no suction from soleplate, the brush bar spins. Did all the troubleshooting steps on dyson.com but they didn't work...dyson.com says need to take to repairman, being a diyer I went to search engine. I didn't find a fix, however I found one myself....it appears the vac can get stuck in floor mode or in between modes....the dial on top on dc07 ....selector of floor or carpet..try pushing it back and forth to see if that puts it in carpet mode...check for suction or try vacuuming...if that doesn't work, looking at vac from behind vac on the right hand side is the selector dial..on top of bottom portion of vac.....with vac in upright position, recline it as if about to vacuumn floor...look down at selector area ...you should be able to see a rectangular type button exposed ..push this to reset position...you may have to push it a few times...then try vacuumniing.....I finally had suction from soleplate!! Another tipoff to this problem is my selector dial would not stay in place would pop I to carpet by itself, but only halfway....fro a long time my vac would work but not very well...had to go over same area.4-5 times..What a workout! The first time I contacted dyson via tele the rep had me remove some stuff and I was able to look at area below selector...what I saw was two holes, one hole was only over the other hole half way...hence at that time I had only part suction since holes were not aligning properly....I read somewhere as a further tip to get suction to engage, while vac is reclined step on front edge of vac head it said you'll get more suction that way, I haven't tried that, but thought it may help someone
Feb 16, 2013 | Dyson DC07 Animal Bagless Upright Cyclonic...
I have a hoover Dust Manager DM6200. actually it is my friend's. She said it wasn't working well, so I took a look. It wasn't picking up, and seemed to be spreading dirt in fact. I emptied...
Hey Julie,
Hopefully we will get this solved together.
To me, this problem sounds like either the filters are choked up and cannot breathe, OR.... the bagless cannister is not quite sitting in the machine properly.
Honestly, I am more leaning towards the cannister not quite in properly, that is assuming that everything is out of the suction hose.
Start with the process of elimination. Remove and clean the filters with a paint brush or other brush. Get as much dirt and debris off of them as you can and replace them into the machine.
Turn on the machine, and using only the hose attachment, feel if the suction is there. If not, try a re-alignment of the cannister and check the hose. a small coin or marble running through the hose will tell you if there is still a blockage in there.
Where the attachment hose connects to the bottom of the machine could also be blocked up as well. This will also give the same effect of the dirt blowing out the bottom of the machine.
Lastly, it is also quite possible that the belt has stretched or worn out. This too will contribute to it not picking up.
Let me know if this helps, and we will go from there.
Good luck,
Mark
Jan 24, 2012 | Kirby Ultimate G Bagged Upright Vacuum
Shark SV736R motorized brush won't rotate
The 2 metal pins of the motorized brush are not in contact with the vacuum cleaner. or the Motorized brush is clogged up. You have mentioned that it is cleaned, but still give a thorough inspection. For the metal pins, firmly insert the motorized brush into the air-intake nozzle. This will connect the motorized nozzle to the unit power supply.
Oct 21, 2011 | Euro-Pro Shark Steam Mop - Gray/ Purple...
The main machine is not sucking up dirt but you can use the hose with an attachment and it still sucks up o.k.
There's probably a clog in the tube in the power nozzle. Detach hose and drop a marble or similar size object down tube. It should roll through and out at the brush. If not, there's a clog and it needs to be removed.
Oct 06, 2010 | Dyson Vacuums
Works in FLOOR position but not in CARPET.
The power nozzle has a reset button. Push that and that should fix the issue. You could of sucked up the corner of a piece of carpet causing the brush roller to become jammed. If that doesn't work, there could be a problem with the hose. The hose perhaps isn't providing the power to run the power nozzle.
Oct 12, 2009 | Kenmore 23612 Progressive PowerMate Bagged...
Carpet cleaner not doing too well
there is a dial on the side of the housing move this to tools this diverts the suction from the floor nozzle to the hose,. .
the brush only rotates slowly.
If this dose not work check red lint filter, .this is in the back corner of the tank lid ,
On the turbo brush there is a sliding swicth ,this diverts the suction from the nozzle of the attachment to the attachments brush
Oct 27, 2007 | Bissell 7920 ProHeat Pro-Tech Upright...
My dirt devil vacuum won't suck up anything and its brand new!!
Take the vac bag off and turn on the vac , it should blow air out, if not unclogg the hose where the bag connects, also when you check the roller and belt, unclog the flex hose(located inside base near roller assembly) that sucks up the dirt. As long as the motor works fine the rest is just maint.
Mar 30, 2007 | Dirt Devil M085805 Upright Vacuum
Miele S7210 Bagged Upright Vacuum Logo
216 people viewed this question
Top Miele Vacuums Experts
Mack Baxter
Colin Stickland
Colin Stickland
Are you a Miele Vacuum Expert? Answer questions, earn points and help others
