Daewoo model dvd 5900 cannot get remote to work .i changed batteries but does not turn dvfd player on
    Top Expert:
  • Televison & ... Master
  • 14,553 Answers
Have the remote tested, most shops have a tester you point the remote at and push buttons, it reacts if the remote is sending a signal.
Many digital cameras can also be used in a very dark room, point the remote at the powered up and on camera and press buttons, if you see a tiny flash on the camera display screen the remote is working.
If you find the remote is not working most can be taken apart and fixed which is quicker than trying to get a original replacement on the brand unit you own.
I do this on a regular basis in our shop and cost is usually under ten dollars total.
Posted on Dec 05, 2012
4 Suggested Answers
  • 3 Answers
SOURCE: DVD player remote is dead
It's quite possible that something got spilled into the remote. I've had this happen a bunch of times, & the remote goes dead! What I did was to take the remote apart by first separating the two halves with a knife & a lot of patience. The two halves are connected together by little clips of plastic all around the perimeter of the remote. Once you start to pry at it, you'll see little indentations ~1/8" - 1/4" wide, every here & there...these are the clip locations. Try to separate them without breaking them. Once you have the remote apart, there's four parts to it; the two halves that you just fought with, the circuit board, (PCB), & the rubber matt that contains the buttons. What you'll need to do is to clean the PCB thuroughly with rubbing alchohol, making sure to dry it completely. Do the same to the other parts, being carfull not to break anything but at the same time being sure to get them clean! Check that there aren't any broken wires or components, resolder anything that may need it. Once you're sure that everything is connected, clean & dry, reassemble the unit by first placing the rubber matt over the PCB, (line up the buttons & make sure it's in the right orientation. Then press the front cover onto the PCB/matt while holding the whole thing aligned, then put on the back cover & click it all together with the little clips. Be extra carefull that the battery connectors go into their proper slots. You may also want to bend the battery connectors alittle bit, in such a way as to make sure that the battery makes a good contact, don't go crazy, you don't want to break them! Once you have it all back together, put in some fresh batteries & try it out! If it still doesn't work....go buy a universal remote!!! Don't worry....be happy!! Good luck!!!
Don
Posted on Feb 14, 2008
SOURCE: daewoo dvd 5900 missing a code for the comcast 3 in 1 remote
the code is 21172
Posted on Jul 06, 2010
electrotech1
  • 1126 Answers
SOURCE: my daewoo dvd player shows that it has power, but
Remove all power from player, if it has a internal battery, remove it too, remove all power from player for 40 min. and that should reset it back to normal, if not then the processor is damaged.
Posted on Nov 19, 2010
Needinformation on how to hook up to tv,with red and yellow cable daewoo dvd 5900
need more info what connections does the dvd palyer have and tv in the back?
Mar 27, 2010 | Daewoo DVD-5900 DVD Player
I LOST THE REMOTE TO THE DVD PLAYER. HOW CAN I GET ANOTHER ONE IT IS MODEL DAEWOO DVG-9500N
You would be better off to purchase a unversal remote,it will be less expensive than trying to get the original Daewoo remote,just make sure the remote you select lists Daewoo as one of the manufacturers that it can be coded to operate.This will be a simple process. Good luck!
Nov 26, 2009 | Daewoo DVG-9500N DVD Player
My dvd/vcr player doesn't have a booklet on how to program it. I have also tried to use a different remote to it and nothing is happening
Go to Daewoo's website, download User's Manual and order replacement remote that is compatable with your Daewoo model; others WON'T WORK!
Oct 11, 2009 | Daewoo DV6T844B DVD Player/VCR
Remote won;t work
Hi
if the battery is new, you need to replace the IR in the remote control this is the bad parts thats why you can not operate.
Thanks!
Jun 06, 2009 | Daewoo DVD Player
CHANGE ZONE 0
1. Open DVD tray.
2. Entre 0520 using remote.
3. Press keys in this order: UP, DOWN, LEFT, RIGHT.
4. Enter region code, 0 for complete code free.
5. Close DVD tray.
May 26, 2008 | Daewoo DV-6T955B DVD Player/VCR
Televison & Video Logo
23 people viewed this question
Top Televison & Video Experts
Electro Med Services...
