Question about Admiral AAV7000A
Admiral washing machine out of balance - Admiral AAV7000A
Model ATW 44775x00. Why does it become unbalance during spin cycle?
The tub balance could have been upset when the machine was moved to storage.
Oct 20, 2015 | Admiral Washing Machines
My admiral washing machine goes out of balance a lot
Check machine for level with level and adjust the legs.
Dec 29, 2009 | Washing Machines
Machine knocks and walks when spinning a small load
amke sure it is level and on a solid floor with little bounce.
Jan 23, 2009 | Admiral AAV7000A
AAV7000AWW washer
sounds like the thrust bearing is worn causing an imbalance on the shaft. check herehttp://www.partselect.com/AdvancedModelSearch.aspx?ModelNum=AAV7000AWW&mfgModelNum=&fkMfgID=1:- for a schematic on this machine and parts as listed.. hope this is of some help
Oct 22, 2008 | Admiral AAV7000A
My admiral super capacity washing machine
remove the front panel and check the securing springs at the bottom, probably one has snapped, replace the set.
Check for dust - evidence that the snubber washer has worn also
Jun 02, 2008 | Admiral AW22 Top Load Washer
Admiral mega 22 plus heavy duty 2 speed washing machine
I think my set i just got today used is a 3 speed.Seems to be alright for now.There is a thing i was told called a harmonic balance it might be off or messed up.Tina.A(nc)
Feb 23, 2008 | Washing Machines
Off Balance
1. Check all the filtration system...ie pump and all hose's and connetions there after...one of the most common is a coin where the drain hose connects to the back of the machine.
2. Age of the machine could mean the suspension is getting soft...only fix is 4 new suspention rods.
3. Balance switch Adjustment..most modern washers do not have this thou...not sure for your model
Jan 03, 2008 | Admiral AW22 Top Load Washer
Admiral Heavy Duty 22lb. 2 speed motor going off balance
Had Same problem. Replaced The 6 retaining springs and snubber.
$15.00 worth of parts.
Dec 22, 2007 | Admiral AW22 Top Load Washer
Admiral AAV7000A Logo
69 people viewed this question
Top Admiral Washing Machines Experts
Dan Webster
Dan Webster
Sal DeAngelo
Are you an Admiral Washing Machine Expert? Answer questions, earn points and help others
