I cant change my booting priority in bios setup
I cant cange any thing in my BIOS setup
i get a message that VIEW ONLY ITEM [OK]
should i clear CMOS jumper settings
    Problem Solver:
  • 8 Answers
No need to go into the BIOS setup for such simple and easy task, go to start -> right click My computer -> Properties -> Advanced -> Start up and Recovery ->Settings -> now u can choose the default os and time out also u can edit the boot.ini manually by clicking edit
Hope this solves your problem.
Posted on Jan 12, 2009
How to set boot priority in award modular bios v6.0
Restart your computer
during the boot process you will see on the screen to press a certain key usually Delete or F2 to enter setup
this will differ depending on which bios you have
Press and hold that key during the boot up process to enter BIOS
if you have changed any of the BIOS settings by mistake
you can load failsafe or optimised defaults using the arrow keys you can after you make any changes in BIOS press Esc then press the F10 button save to cmos to restart
CMOS is an on-board semiconductor chip powered by a CMOS battery inside computers that stores information such as the system time and date and the system hardware settings for your computer..
hope this helps
Jun 25, 2012 | ASUS A7V333 Motherboard
Tip
How to Fix NTLDR is MISSING
1. Locate you Windows XP CD and place it in your CD-ROM drive.
2. Restart your computer, or turn it off and then back on.
How to fix NTDLR MISSING error.
3. When you computer restarts you should eventually see the words "Press Any Key to enter Setup". If you do not see these words and it goes to the screen that gives you the error message, you will have to change your boot priority in your bios settings.
Changing boot device priority:
A. When you see you’re the first screen, the boot screen, press delete a few times until your computer beeps. Pressing the delete key will bring your computer up into the bios settings. The key you need to press may differ from computer to computer. If the delete key doesn't work for you, contact your computer manufacturer and ask them what key you need to press to get into bios.
B. After you are in your bios settings you will need to navigate to your boot settings. Depending on which type and version of BIOS you have, this process may be different. Either way, there should be a section called Boot or Boot Priority. Navigate to that and make sure that your CD-ROM has top or first priority. After you have don't that, save and exit (press F10).
4. Once you see the "Press Any Key to Enter Setup" message, go ahead and press any key.
5. This will start the Windows Setup Process; it will take it several minutes to load.
on Feb 04, 2009 | Microsoft Windows Vista Ultimate Edition
Dell Inspiron 546 MT : replaced cmos battery due to checkpoint error, and now receive a CMOS checksum error and asks to either press F! to run setup or pree F2 to load default values and continue. Wh
Hello there, I am the computer technician that will be assisting you today.
My name is Norman-Wynne Damstra.
Welcome to Fixya, Jbellovary.
Since the battery was removed the CMOS would have Cleared as it needs power from a battery to retain the settings.
This therefore means that the BIOS/CMOS has already been reset to defaults and this is why it is giving you this message.
It sees that the settings have changed and it wants you to tell it why.
When this screen comes up Press F2 to load defaults.
Then let it run.
You will now need to enter the BIOS/CMOS by tapping the delete key on first powering on your computer, until you see the BIOS/CMOS screen.
Now set the date and time and set the Boot priority to HDD, then DVD drive.
Also enable USB2.0 support if it is disabled. Check that your drives are being detected.
Save and exit setup.
It should now be A-Okay.
Take care!
Feb 02, 2012 | Dell Inspiron 546 MT PC Desktop
Computer would not booy up. now it does but the password does not work
which operating system ant what type of computer??
When you boot up to the log in screen type in administrator as user to log in if you cant log in
during the boot up process you will see on the screen for a short amount of time press a certain key to enter set up press and hold that key during the boot up process to enter BIOS scroll down to set user password or supervisor password you can change or remove your password from there
also
During the boot process you will see on the screen to press a certain key to enter setup
Press and hold that key during the boot up process to enter BIOS you can load failsafe defaults or load optimized defaults ,press escape then press f10 to save to cmos to restart
also
how to reset or clear the BIOS password is to physically remove the power from the computer by disconnecting the power plug and then removing the Cmos battery for 30 minutes from the motherboard. Another way is to reset the clear CMOS jumper on the motherboard itself. Both of the 2 methods mentioned works because most motherboards use a battery to sustain the BIOS/CMOS settings for the motherboards PROM chip. So by cutting off cmos the battery power, the BIOS/CMOS settings will be erased
or if using XP
During the boot process tap the f8 button three times this will boot into safe mode where the only things working will be your mouse and keyboard enabling you to attempt to repair your computer Advanced Boot Options screen appears. Select the Safe Mode option using the up and down arrow keys, then press the ENTER key. Choose "Windows XP Home/Professional", depending on the version of the operating system. Press ENTER. Shortly, the welcome screen should show.
Log in as "Administrator". Click Yes to not use System Restore Mode.
Click the Start button. Choose Run and type in "control userpasswords" (without the quotes). Click OK.
Select the "Administrator" user. Click Change my password. Enter a new password in the corresponding text boxes. Click OK. Write this password down and store it in a secure place Close the User Accounts window and restart Windows.
hope this helps you
Sep 10, 2011 | Computers & Internet
Laptop not used for some years. could enter bios OK to reset Replaced U/S CMOS battery with no problem. Restarted............ Message press F1 ibm bios setup press F11 to invoke IBM product recovery...
I received an IBM laptop with same issue a few months back. The error message due to the drained out CMOS RTC (coin-cell battery), which retains and other BIOS settings.
The system is OK and all you have to do is to get the CMOS/RTC battery replaced by the a professional.
Good Luck!
CreativeTECH
Dec 31, 2010 | IBM ThinkPad R30 2656 Notebook
Cannot change boot priority
During the boot process you will see on the screen to press delete to enter setup
Press and hold delete during the boot up process to enter BIOS the scroll down to advanced bios features press enter change your first boot devices there,press escape then press f10 to save to cmos to restart
hope this helps
Oct 12, 2010 | Intel DG31PR Motherboard
Boot priority changes made in BIOS save OK but do not change priority
The problem is caused by weak cmos battery in your motherboard that is why it cannot save anymore changes in your bios. Change the old battery with the new one. Hope it can help you..
Oct 24, 2009 | Computers & Internet
Floppy diskette seek failure
try to go to bios setup and change the boot priority for the devices, by setting first priority to your Hard Disk , and then your CD Rom and last to the floopy disk..
Jul 10, 2009 | Dell Dimension 4600 PC Desktop
Willn't boot up frome the cd rom
You can do this by changing the BOOT Priority in your BIOS settings.
To get into BIOS:-
When you first turn the system on, you get what they call a POST screen (normally has the laptop logo or enegy star monitor rating), at the bottom of the screen, it should give you an option or two (i.e. F1-Boot Options, F2-Setup (also called BIOS). Different systems use different keys to enter the BIOS (or SETUP), this is usually F2 or Delete.
Once you are in the BIOS, just have a browse for BOOT OPTIONS or BOOT PRIORITY, and change the value of FIRST BOOT to CD-ROM.
Save these new settings to CMOS and exit. The system will now reboot, and this should solve the problem
Nov 28, 2008 | Computers & Internet
Can not change Bios Boot Device
remoove battery n start
press f8 n safe mode
shut down n restart
press/dell/f2/f10/f12 key
then u will go to bios setup
if changes is not saved then change cmos battery
Jun 14, 2008 | Toshiba Portege R100 Notebook
Computers & Internet Logo
156 people viewed this question
David Payne
David Payne
