I have tried to auto tune my 43 inch samsung plasma keeps coming but with weak signal or no cable connection
    Top Expert:
  • Televison & ... Master
  • 14,553 Answers
Consider hooking the signal source with a box to the rear audio/video or component etc inputs and bypass the tuner in your set, use a box instead.
Posted on Dec 06, 2012
3 Suggested Answers
  • 718 Answers
SOURCE: displays weak or no signal
To get any HDTV to work this is what you have to do;
CHANNEL section
1) Connect your antenna cable which you have done.
2) Go into the menu to the source option and select AIR/ANTENNA since you are using an antenna.
3) In the menu you will have to SCAN in the stations. This auto program will find all available stations.
Now you can watch tv by selecting the station you want.
The new generation of HDTV is different from the old analog sets. These have to be set up to work.
Exact information can be found in your Users Manual.
Posted on Feb 23, 2009
tedatcit
  • 89 Answers
SOURCE: Hi just moved and trying
check cable there is a break or In the middle of the cable comming in your t.v. is not long enough....if you look at it should be poking out.
Posted on Oct 23, 2010
Samsung PN43F4500AFXZA HDMI FIX
make sure you have it set to hdmi when cable is connected to source. try another working hdmi cable. try other hdmi ports.
May 08, 2017 | Samsung Televison & Video
Why my 55in plasma some times wont get signal. arial ok other tv good on same arial lead. doesen't happen all the time ?
How old is your cable? How old is your outside anteena? After awhile they need to be replaced or connections checked. In my area the tv has been going out for hours while they work on it. But you seem ti indicate that is not the problem. What type of cable are you using? An which connectors? Need more info
Jan 28, 2015 | Samsung 50 in. Plasma TV
Tv wont tne in to ch9 why iam getting all the other channels
If you are using an antenna to receive broadcast TV you may have to rescan to add channel 9 back into the TV's channel list. If this does not work, it may be seasonal or a weak signal from your channel 9 broadcaster. I use a signal booster on my antenna (purchased at Radio Shack..)
Dec 10, 2014 | Samsung Pn64d8000 64-inch 1080p 600hz 3d...
Will not tune in channels on auto store
Well, there's your answer then. You have poor aerial signal so the TV cannot lock on when tuning. You need to sort out the reason why there's "Poor or No Signal" You need to fix the aerial, not the TV. I would have thought that was self-evident, surely?
What kind of aerial are you using. Do you know it works? Check out the aerial cables for breaks or badly fitted connector plugs.
Sep 15, 2014 | Samsung PS42B430 42 in. Plasma TV
Unable to set TV channels on Samsung LED TV
Check the orientation of the antenna. If the transmitter you're trying to tune is very far away from your home, the signals will be very weak, that the tuner inside the TV can't catch. If this is the case, the orientation of the antenna is very important.
Dec 03, 2013 | Samsung Televison & Video
I get a weak or no signal message on my new Samsung plasma. I'm using coaxial to my cable box. The cable works fine because I can see the vcr when it plays. I have it set to cable on the right channel...
In this case, your VCR becomes the cable channels tuning device for your TV, the better connection should be from your cable box output to your antenna/cable TV input with the coaxial cable, surely, your TV has a better cable tuner than your VCR, to connect the VCR to TV you can use its AV outputs to an available AV inputs of your TV, you can get a better sound and picture in this way.
Mar 17, 2011 | Televison & Video
Hi just moved and trying to tune my samsung plasma but it keeps coming up weak or no signal... im using 0000 as my pin can anyone help... please..
Oct 23, 2010 | Samsung Televison & Video
Samsung 50'' plasma model ps50b450b1wxxu keeps losing all stored channels and needing re-tuned,tv says weak or no signal, it is only 3 weeks old, is it something i,m doing wrong or is the tv faulty?
If you are always needing to auto program the tuner then I suspect a faulty main board. Bring it back as it should be under a 30 day return policy..
Nov 03, 2009 | Televison & Video
Displays weak or no signal
CHANNEL section
Feb 23, 2009 | Samsung Televison & Video
Televison & Video Logo
Top Televison & Video Experts
