Question about RCA D56W20 56" Rear Projection Television
I have an RCA model D56W20. When I press power, the light flashes 3 long flashes then nothing. No picture, no sound.
  • jeff Dec 06, 2012
    I can solder, so what do I have to do?
    Top Expert:
  • RCA Master
  • 14,553 Answers
I may of seen a different version of this question a few days ago, The set has a 3 strikes and you are out (not a joke) as it will try 3 times when powered up to come on and then go into shutdown.
Most common issue is bad solder connections under the High voltage transformer (see photo of typical one).
Not knowing your skill level let me know how you want to proceed.
I have an RCA model D56W20.  When I press power, t - 12_6_2012_3_02_57_am.jpg
Posted on Dec 06, 2012
  • jeff Dec 06, 2012
ilragatzzo78
  • 241 Answers
SOURCE: model 32v434tyx6 RCA TV
SEEMS THAT YOUR POWER SUPPLY IS ON SHORT AND IT'S SELF PROTECTING YOU WILL HAVE TO HAVE A PROFESSIONAL TECH TO DO THE JOB I JUST FIXED ONE WITH THOSE SYMPTOMS AND I REPLACED THE COIL PLUS A COUPLE OF RESISTORS AND IT'S ALIVE AGAIN
THE DOWN SIDE IS THAT THERE IS NOTHING YOU CAN DO IF YOU DO NOT KNOW WHAT TO DO, IT'S NOT AN EASY TASK
Posted on Apr 03, 2008
SOURCE: RCA 52 INCH D52W20B WON'T COME ON
Just fixed it!!! Remove the back panel from the television, you will see a board where the input jacks are located. To the left you will notice a red power wire. Just up and to the right approx 7" or so you will see a [_] shaped metal shield surrounding a capacitor in the middle of it. The part # on the board is CP150. It is a green/gold 16v 2200uF capacitor. More than likely this capacitor is faulty. Run your finger over the top of the capacitor, if it is beveled rather than smooth you have a definite solution to your problem. You may need to remove the plastic piece that covers the transformer to the left of the capacitor to gain easy access. Good luck!!
Posted on Oct 14, 2008
SOURCE: RCA MODEL D52W19 I PRESS THAT POWER BUTTON GREEN LIGHT FLICKS FOR
try unplugging the tv for a few hours. then plug it in and push the power button on the front of the tv.
it has something to do with this processor issue inside the tv....its pretty much a stupid thing.
should have been a recall because everyone has the same problem on here.
this is pretty much just a band-aid over cancer, but i've been having to do this for about a month now, and it works.
Posted on Apr 18, 2009
Slinteriors
  • 8617 Answers
SOURCE: tv wont turn on, RCA D56w20, 56" rear prjection
replace the flyback 259296 and the CP150 capacitor. You can get the replacement parts with free instructions at the following link.
http://servicemanuals.vstore.ca/
Posted on May 17, 2009
  • 8457 Answers
SOURCE: Power light flashes 3 times then nothing
Replace the intire board,not just caps.
Posted on Sep 12, 2009
I have a 56 inch RCA D56W20 and when i turn it on I can hear the sound, but i can't see any picture.
In menu check the Lamp Hours You may need a new lamp or the lamp has failed
Please rate my help++++Thanks for using FIXYA
Aug 13, 2010 | RCA D56W20 56" Rear Projection Television
Picture won't show
Pull Back off CK both ribbon connectors on deflection board make sure they are in good there is 2 of them they connect the deflection board to the SSB board that has tuners on it ,also try with tv unpluged spay wash FBT flyback transfomer let dry then plug set back in and try.Also CK capacitors cp150 cp120 cp114 if cp 150 is puffed up ontop it is bad so replasce all 3 capacitors 2200uf 16v 220uf 35v.
Jul 22, 2009 | RCA D56W20 56" Rear Projection Television
Rca model number d56w20 green light blinks 3 times and then off , repeats cycle 3 times then nothing. no pic no sound
Sorry but I can't afford your service, and yes i stil have the same prob..
thanks
jandjmayo@yahoo.com
May 29, 2009 | RCA Televison & Video
Tv wont turn on, RCA D56w20, 56" rear prjection
May 17, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Won't turn on
id be calling the friend asking for a refund...what you have going on is pretty common but did you see it work prior to buying it or just take their word for it? you may have a bad flyback or transformer but it shouldnt be bad so soon after you happened to buy the tv and no it would not have gone bad from moving the tv
Jan 12, 2009 | RCA D56W20 56" Rear Projection Television
56 inch RCA rear proj T.V.
Sounds like the capicator on the high voltage is swelled,removing the back cover,make sure to unplug the unit first,there is a u shaped heat sink about middle ways of the board,inside that heat sink is a cap,it will be swelled on top of it,its a 2200 35v cap.
Jan 05, 2008 | RCA D56W20 56" Rear Projection Television
52 RCA DLP 1080P Television with NO picture and buttons flash
IF you would like help diagnosing your set. Go to the enclosed link. They have the service manual for your set and offer unlimited chat support for only 29.99. Just click on your sets manufacturer and you will see your model. Then click on the contact us link and provide your email address and they will email your manual and instructions on how to obtain your support. I am one of their techs. This manual contains step by step procedure for troubleshooting Your RCA DLP Light Engine
Dec 30, 2007 | RCA HD61LPW175 61" Rear Projection HDTV
My tv power won't come on
does a picture come up. from what you have told.. i would think not so. after it goes off does the light flash. this unit has a processor that shut the set down when it "SEE's " a problem..high voltage..crt..theres about 20 to 25 different problems that can cause this.
Dec 09, 2007 | RCA D56W20 56" Rear Projection Television
RCA D56W20 no power and whistling
ok. the FLyback is the large black part on the lower left corner.. has large red wire comeing from it... the HOrizontal.. is the large black transistor right in front on the left side on the largest heat sink..getting these parts are tricky.. you must get some numbers on the part itself..there are three different flybacks.... and the horizontal is ussally 259899 rca part number. Good luck and if you need any more assitance email me at FORDTV.com ; I work on alot these chasis
Nov 04, 2007 | RCA D56W20 56" Rear Projection Television
RCA D56W20 56" Rear Projection Television Logo
139 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
