Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
Electric eye doesn't work on my craftsman garage door opener 41a5021-2e
geemarie
  • 876 Answers
SOURCE: craftsman garage door opener instruction manual
Have you tried the manufacturers site at either craftsman or sears. You should be able to find it there. You will need your model #.
Posted on Aug 01, 2008
Door Tech
  • 98 Answers
SOURCE: 1/2hp Craftsman Garage door opener light bulb
If you are getting a click the relay on the board sounds like it is working. Sometimes the contacts in the light socket gets burn spots on them. Try unplugging the unit, unscrewing the bulb and with a small scrapping tool (small flat screwdriver) scrap the bottom contact and the contact on the threads. Bend the contact on the threads a little too make better contact with the bulb. Screw the bulb the bulb in completely. If this does not solve your problem the only the left to do is to replace the logic board.
Posted on Jan 10, 2009
  • 244 Answers
SOURCE: keypad garage door opener will not operate
what keypad are you using with new opener? Frequency has changed. can't use old one. you probably never needed to change things; just needed to follow proper coding procedures.
Posted on Jan 28, 2009
  • 95 Answers
SOURCE: garage door opener does not work correctly
Make sure the door springs on the door are ok.Unhook the opener from the track by pulling the red handle rope on the track,make sure the door moves up and down freely.There is a up-force adjustment on the end of the opener that the small wires run to,you will see 2 slotted adjuster screws,find the one labeled up force,turn it clockwise a little bit(1/16th of a turn).Also there is a plastic gear inside the case that gets dry,unplug the opener,remove the 8 screws that hold the case on and lube it with a lithium grease,see if it is worn badly while you have the case off.
Posted on Aug 12, 2009
  • 3197 Answers
SOURCE: Craftsman Model 139.53684 Security+ Keyless Entry
To answer your question the opener is in vacation mode. Press and hold for 3 seconds the button on your wall control with the lock icon. The green light will stop flashing and you will be back in business.
Posted on Dec 08, 2009
Garage door senser not working
What doesn't the sensor do with an obstacle?
Feb 27, 2012 | Sears Craftsman LiftMaster Chamberlain...
The garage door opener inside the garage doesn't open or close the garage door. How do I diagnose? The model # is: 41A5389-1B
The model number you give is a part number for the logic board. Does your remotes work? Is it only the wall control that isn't working?
Sep 11, 2011 | Sears Craftsman LiftMaster Chamberlain...
Craftsman 3/4 chain drive will not open, when pressing wall switch I hear click at the unit and the programming light will flash, but it doesn't open the door, or close for that matter the motor...
The unit is for sure repairable. You should remove the cover from the motor unit and check the drive gear. It is a white nylon gear just in front of the motor and it will be obvious if it is bad. If you have had electrical storms it may have gotten to your logic board. You need to pull it and check for burnt or missing traces on the printed circuit.
Aug 09, 2011 | Sears Craftsman LiftMaster Chamberlain...
Garage door opened, won't close
If you can press and hold the wall button and the door will go down, you have a photo eye issue. Check the photo eyes at the bottom of the door.
Jan 16, 2009 | Sears Craftsman LiftMaster Chamberlain...
GARAGE DOOR OPENS BUT WILL NOT CLOSE AUTOMATICALLY
is bulb on motor flashing 10 times. then you have electric eye problem. otherwise, sounds like you need to increase down force a hair. adjustement is on logic board, right knob.
Jan 06, 2009 | Sears Craftsman LiftMaster Chamberlain...
Undoing sensor.
the equipment it doesn work with out the sensors in some models
Oct 05, 2008 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
16 people viewed this question
Top Sears Building Materials Experts
Glenn Mayer
Glenn Mayer
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
