Question about Garden
Below the gas tank on my old montgomery ward snowblower is a glass ball which i took off it has a bushing underneath it I need to know what that bushing is called and where I would get one
    Filmmaker:
    Uploaded 5 video answers.
  • 15 Answers
It's either a gasket or a float cant see it all that well, to be honest that carb probably has no rebuild kit and you will probably have to fabricate the gasket with like a gasket maker please excuse the video ha, dont really have much to put on
Posted on Dec 06, 2012
4 Suggested Answers
num1wrench
  • 14 Answers
SOURCE: i have montgomery ward riding mower and cant
Line up the deck where it needs to be, and lower the lever....the hanging links should come close to where they go, then use the pins (or whatever) to insert into the hanging levers....Leave the handle lowered, then hook the belt onto the engine pulley, then line it up with the pulley on the deck...you may have removed the belt guides, so put them back on...They help keep the belt from falling off.
Check your work to make sure things look right...You should be done.
Posted on May 10, 2009
  • 12 Answers
SOURCE: hi i have a montgomery wards riding mower 1990
I might know what the problem is, on those models there should be a ignition switch, or a killswitch under the seat of the mower. When the 2 people sat on it, it might have jarred or broke the switch. You might want to check it to see if thats your problem. I hope this might help.
Posted on Nov 02, 2009
vincob
  • 718 Answers
SOURCE: montgomery ward lawn tractor kohler
If your engine is an OHV engine you need to adjust intake and exhaust valves. Go to smalleng.com watch video clip. or go to U tube lots of tutorials there. Good luck...
Posted on Apr 19, 2011
Manual for wards hot water heater
1) Copy following links to identify gas control valve, troubleshoot resources, and gas water heater installation
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html#intellivent
http://waterheatertimer.org/How-to-install-gas-water-heater.html
2) Unsure which manufacture makes/made Wards water heater, or how old your unit is.
Three manufactures make most brands tank-type water heaters, and generic manual basically covers all brands.
http://waterheatertimer.org/Water-heater-manufacturers.html
3) Add comment Feb 2013, and say what you are doing.
Feb 03, 2013 | Water Heaters
I have a montgomery ward snowblower model GIL 35212 A and need a new drive gear. do you know where or if they are sold anywhere?
I did a quick search on the internet, and I found this possible source:
http://www.outdoordistributors.com/parts.html
THey have some parts for MW lawn and snow equipment-
Try them-- if they don't have the part-- ask if they know who might--
Mack B
Jan 15, 2011 | Montgomery Ward (223600UP) Heater
Montgomery Ward snowblower, single speed how can I slow it down, moves to fast and pluggs up.
well... that's a difficult task, you need to open it up and replace the current gear with a bigger on, if it's possible, it may not be... you could try coating the auger with wax/cooking spray
Feb 13, 2010 | Montgomery Ward (223600UP) Heater
We have a old Montgomery Ward five-hundred Glass Lined hot water heater Serial # SNN 1177204708 Model # SRM33331A Type Gas NATURAL GAS PRESS IN. W.C. Input BTUH 46,000 MAX SAFE INLET 7.0 RECOVERY GPH 38.6...
I believe I had the same problem with my water heater about 15 years ago. It started with a small leak, then the tank broke flooding the room. I think it would be be best to replace the unit. Water heaters tipically have a 8-10 year life.
Mar 11, 2009 | Montgomery Ward (223600UP) Heater
Wick and manual for Montgomery Wards Windsor kerosene heater
Hi, I have a Montgomery Ward Sunheat heater. It's a dual burner enclosed type with a door on the front. The fuel tank is cylindrical and about 1 1/2 - 2 gallons. The cap has a needle valve and when turned upside down releases fuel to the burners by gravity. The whole heater itself is rectangular with louvers on the sides and top. I don't know what wicks go in this or if there are compatible replacements out there.
No 84ALO5800A is the only I.D. or Model No.
Thanks,
Jack
Nov 27, 2008 | Montgomery Ward (223600UP) Heater
I need help with older Ward's snow blower
have you checked to see if you have spark to the plug? If not you may have sheared the key between the flywheel and crankshaft. It is made of aluminum and could have sheared for this reason. This happened to me.
Aug 25, 2008 | Montgomery Ward (223600UP) Heater
Garden Logo
112 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
