Msi g41m-p26 won start (no power)
Hello , please help me , i have a new mother board msi g41m-p26 and it stopped working. WHEN PRESS THE POWER SWITCH THERE IS NOTHING HAPENS NOTE (IF I REMOVE THE CPU 4 PINS ATX 12V POWER CONNECTOR IT POWERD UP) THE REASON WHY MY MOTHER BOARD STOPPED THE MOTHER BOARD WAS NOT INSTALLED CORRECTLY SO MY FRIEND INSTALLED A NEW WEBCAM , THE MOTHER BOARD MOVED AND I THINK A SHORTCUT HAPPEND BETWEEN THE MOTHERBOARD AND THE COMPUTER CASE. HELP ME IF THERE IS A SOLUTION OR SOME COMPOSENTS CHANGING LIKE MOSFETS OR CAPASITORS OR ANY SOLUTION PLEASE !!! .
  • 3,799 Answers
The most likely solution is to replace any Capacitors that have blown in the onboard power circuit. Look for a Capacitor that has got a very bulging top in the region of the power connector.
Posted on Dec 06, 2012
  • 1 more comment
  • tp0002 Dec 07, 2012
    thank you Michael Green for your Replay , there is no blowing or blugin capacitor , all the capacitors looks great and fine , iv tested all the mosfets around the cpu and i found some one who doesnt give the same result this one named (P0903BD), am i wrong ??
  • Michael Green Dec 07, 2012
    Sorry, I don't know. But for an IC to have fried from a shorted motherboard, it would have had to be a substantial contact with the case, as there is an insulating layer on the underside of most modern boards. But I have had boards with the same symptoms and it has always been a capacitor.
  • tp0002 Dec 08, 2012
    Okey , thank you very Michael Green , i ll try to change the capacitors and see what hapens , thank you again.
5 Suggested Answers
  • 99 Answers
SOURCE: Motherboard not functioning
If the power supply had a problem then it is likely that the motherboard and/or the CPU got damage from that. I would check the 12V and the 3.3V lines from the PSU.
Without more information I cannot say specifically what the problem is. You can try disconnecting everything from the motherboard except video card, CPU, and RAM to see if it would work that way. If it does then you can start connecting devices until it does not work any more then you have found the problem. If that does not work at all then unplug the video card and RAM see if anything changes (you should get a beep code without the video or RAM). If nothing changes then either the CPU or motherboard is bad and the only way that I know of to find out which one is to either try the CPU in another motherboard or try a different CPU in that motherboard.
Posted on Nov 13, 2007
  • 25 Answers
SOURCE: Power supply Ok.But CPU fans started with seconds It's stop.
sounds to me like your mainboard is bad, i bet if you closely inspect the capacitors around the cpu one or more is bulged out or leaking
Posted on Feb 15, 2009
mbase213
  • 728 Answers
SOURCE: i installed the motherboard with the cpu 3500+
There could be many things that could stop the board from turning on, Determining what is wrong is like detective work. What I do, is take everything off the board to start. Then add the minimum to start a board to see if it will start. That's one drive (cd or otherwise) the CPU, and one bank of memory. (that's not a required eliminate, but it helps avoid beep codes) Also, make sure you have your pin's set on the board absolutely correct, or that could be your problem to begin with. Also, if your going to load a ide drive, make sure you set your pin setting correctly on it. Now, you should get the power supply on, and the cpu. If those don't power up, it's then either one of the five elements. The CPU, Power supply, Ram, Drive, or the motherboard. The next step is to replace each one of the first four with another to see if you get any change. Also, on the drive, try a different cable to make sure it's not that, If no change, then I usually get another board that I can test the first four, and make sure that they work. If after that and you have tested all of the components and they all work, then it's save to say you have a Dead Board
Good Luck and don't forget to leave a rating.
Thanks
Mark
Posted on Dec 19, 2009
Testimonial: "Thank you! the board is dead, i tried everything but nothing helped.now i'll take the board to a local service, maybe they can fix the mobo..."
pgh_pa_guy
  • 2992 Answers
SOURCE: I've got a new Gigabyte
Most motherboards now have a 24-pin power supply connector. If you haven't already found a diagram showing the pinouts of the 20- and 24-pin power plugs, here's one borrowed from a handy site:
The two plugs are essentially the same, but the 24-pin version duplicates some voltages on the extra pins. The extra pins in the larger connector were meant to provide extra current paths for voltages that see heavy loads from newer processors and motherboard circuitry. Depending on how a motherboard is designed, it might work with a 20-pin plug connected (leaving pins 11, 12, 23 and 24 empty). But typically if the board has a 24-pin connector it needs the 24-pin power supply plug.
Most power supplies have a 20-pin plug with a separate 4-pin section that fastens to it for connection to a 24-pin mobo connector. It typically has one side designed to slide onto the end of the 20-pin plug, essentially turning it into the 24-pin version. This added plug does not have a retaining clamp on its side, so you can tell it from the the 4-pin CPU power plug. The wire colors are also different. For reference, here is the processor power plug, from the same website:
New motherboard specs call for the separate processor power connector for the same reason the extra pins were added to the power supply connector: to handle the high currents needed by increasingly faster CPUs.
When the motherboard has these connectors, you need to use them all to get everything working. Hope this helps. Thanks to smspowersupply.com for the diagrams, and thank you for using Fixya.
Posted on Nov 20, 2010
Testimonial: "Thanx - cleared up the confusion about P1. Additional tests are pointing to a d.o.a. motherboard."
MSI G41M-P26 jpwr2? if i disconnect it no power. if i connect it there is a power but no display.
You don't give enough information. You need to decide if motherboard is starting up - and you can hear hard disk(s) running and accessing data, or if everything is totally dead.
If the former the lack of a display could be a fault with your graphics card.
You need to see if the power supply is running, look and see if its fan is going and then listen to see if hard disk motor is running. If these are dead try a replacement Power Supply.
If you get some text or graphics on the screen when you first turn on, and before screen goes blank, that suggests it is running and the blank screen can be due to a software problem.
If you need more help, supply more info about the fault.
Cheers.
May 16, 2014 | MSI G41m-p26 Desktop Motherboard - Intel...
How to reset bios on a msi g41m-p26
on the board is a jumper right above the pci slot (blue) with the pc powered off, move the jumper to pins 2 and 3, then wait 5 seconds, then move it back to 1 and 2. your bios is now reset :)
Jan 01, 2012 | Computers & Internet
Hi, I have this mother board MSI P67A and Intel Core I5-2500K 3.3Ghz processor. I have it mounted in a Thermaltake V3 Mid Tower with a Ultra LSP550 550w power supply and also 2 Patriot Signature 4GB DDR3...
Welcome to Fixya. With the specs of the computer it seems that the power of 550W is enough and after changing the Power supply to 600W you same result. Most likely the problem is the motherboard if the board is brand new you can ask to a replacement to Tiger Direct and you can ask them since it still has a warranty.
If you have questions please let me know. Thanks for using Fixya
Mar 21, 2011 | Computers & Internet
Installed new motherboard (Gigabyte GA-G41M-ES2L), I cannot figure out where to plug the blue & white wire coming from the main power button on the front of the computer on the motherboard. Please...
hello tami_hennacy
unfortunately the wiring color for computer cases are not standard. so blue and white does not mean much. you need to look at the connection on the tip of the wire to see if it is labeled so you can locate the corresponding connection point on the mother board. Gigabyte motherboards have a very good step by step discretion of all connections.
if it is not labeled then you need to oped the case front panel and see what the other end of this pair of wires is connected to.
hopefully this has helped
good luck
Dec 30, 2010 | Gigabyte GA-G41M-ES2L Motherboard
I am working on a KT3 Ultra CE MS-6380E ver.1 mother board. The original problem was that nothing run after I pushed the power switch. I thought the Power Supply went out so I replaced the power supply but...
Sounds like the board or processor has failed. You will have checked all the power connectors to the board? Usual fix is a new board, rather than trying to find which component on the board has failed.
manual
MSI MS 6380LE User Manual
specs
MSI KT3 Ultra2 Specs
MSI website details on the board
KT3 Ultra Ultra ARU Motherboard The world leader in motherboard design MSI...
Seems to be a problem board
Questions Answers for kt3 ultra ce ms 6380e
Jul 12, 2017 | AMD MicroStar KT3 Ultra Socket A ATX...
What is the power switch on mother board?
Hello sir, hi, like in any mother board, the power switch is on the header port located on the corner. Read the label just to make sure.
Dec 17, 2009 | MSI 845GVM-L (MS-6714-040) Motherboard
Mother board
Check you power button is unserviceable.
Open the cabinet disconnect the power On cable from front panel and short with screw driver for starting if computer is working fine. then power on switch is unserviceable,
Check the power supply also
Jul 04, 2008 | Intel Motherboard
New mother board
sounds like either you have button connections wrong or you need to set bios defaults
Nov 12, 2007 | MSI PM8M-V Motherboard
MSI KT3 Ultra2-R Motherboard
http://global.msi.com.tw/index.php?func=downloaddetail&type=manual&maincat_no=1&prod_no=497
Sep 26, 2007 | MSI KT3 Ultra2-R Motherboard
Computers & Internet Logo
453 people viewed this question
David Payne
David Payne
