Question about Xerox DocuPrint N2125 Laser Printer
I have this printer that is networked in a small office with 4 other computers. The person who installed this printer has left the left with all its documentations and the user guide. Someone has printed something which turns out to be an empty sheet of paper with just some parallet lines. Anyways is there any way I can cancel the papers that are printing from the printer instead of the computers that are printing because I have canceled all documents from the computers but still the printer is printing.
Restart the Windows printing services, if they run Win2000 or newer. Go to Start > Run, type CMD, hit Enter, in the command dialog that opens, type NET STOP SPOOLER and hit Enter and it should tell you the service has stopped.
then type NET START SPOOLER and hit Enter and the service should start again.
Do this on all computers until printing stops. If printing doesn't stop, power off the printer and its server (unless it's connected to one of those pcs in which case you already restarted that service).
Posted on Jan 12, 2009
Make my Lexmark x5340 be wireless'
Is this a wireless printer? Is it being used for a large office or a small home type office? If you are using it for a home office and have multiple pcs, then you can setup a homegroup. A homegroup is like building your own personal small network. You will be able to share and print documents between your computers. Once you setup the homegroup, on one computer, then you will have to add the other computers to the group using the access code that the first computer will provide. Be sure to enable printer and file sharing when setting-up the homegroup. Once setup, you will be able to print your documents from any connected printer on your network. It's not wireless but it might help to solve a print sharing problem. Good luck. How To Set Up Homegroup Sharing Plus Printer Sharing
Dec 22, 2014 | Lexmark X5340 AllInOne InkJet Printer
Tip
How to use a printer?
Install a New Printer DIY installation of your new printer in Windows. You may have a new printer with an installation disc, or maybe a second hand one with no disc. Either way you will find out how to install your printer onto your computer.
Add Network Printer If you have two or more computers in your house or office you will only need one printer installed on one computer for both to have printing privileges. This article shows you how to add a network printer to Windows Vista.
Add Network Printer Applies to Windows XP. Even though the instructions are similar to installing a network printer on Windows Vista, there are a few extra tips that might be interesting.
Enable Printer and File sharing How to enable in Windows XP And Vista. If you want to share a printer on your network you must enable printer sharing. It is not hard to do but it will not work if it is not enabled.
Path to your network printer How to find the path \\server\printer. If Windows does not find your network printer automatically then you will need to know the path to your network printer.
Set Network printer permissions Set who can change printer settings in Windows XP and Vista. I personally like to let everyone on the network just print and not be able to change too many settings to do with the printer.
Network printer has problems printing - You do not have permission to use selected printer.
Quick Printing Trick Cool printing trick for Windows Vista and XP.
on Jan 18, 2010 | Office Equipment & Supplies
Won't print wireless.
Ensure the wireless printer software is installed on all computers in the network for issuing the print command from any computer within the home or office premises. Bluetooth printer is a suitable option for small offices and Wi-Fi for a greater operational distance.
Mar 22, 2011 | HP Photosmart Premium C309g multifunction...
In our office we have one Laserjet2300d printer whis is shared in a LAN network by network cable. my computer is till in the network but not configure with the printer how can i get print via that printer
make sure you have set up your computer's network in file and printer sharing is on..
if you have never done it before...
here is how you will do it..
click start
my network places
on the left side of the window you can see this "set up home or small office network"
click it and a dialog box will appear
click next
next again
just next again
asign a computer name that you want
check what is your work group name if there is any..if not just use the default then next again
turn on file and printer sharing then next
then wait until it is finished
sometimes if it is your first time to set up it
it needs to restart your computer..
and now you can print your document via lan printer..
Feb 12, 2010 | HP LaserJet 2300d Printer
Printer will work for only one computer
It's not the printer, it's the network. When Comcast installed cable in your office they disrupted/changed the network settings on the other computers. Go to the computer that can use the printer and right-click on it. Check Properties/Sharing. Make sure the Share This Printer box is checked. If it is, the problem lies in the network connection of the other PC's.
Apr 18, 2009 | Minolta Office Equipment & Supplies
NETWORK
Does your copier have a Network Interface Card ( NIC ) installed in the printer? If not, and if the copier has the Parallel port option installed, you can purchase an HP JetDirect EX network print server, and then connect it to the printer parallel port, and then into your ethernet network. This option is very effective, and a very "Green" solution vs using a computer as a print server for example, or the high cost of adding a Toshiba ethernet option if not already installed.
Nov 07, 2008 | Toshiba e-STUDIO 16 Printer
Printer FREEZES and prints blank pages
I DON'T THINK ITS THE PRINTER. THIS IS A SOFTWARE OR NETWORK ISSUE.
1 IT SOUNDS LIKE CORRUPTED FILES BEING SENT TO PRINTER, OFTEN PDFS. CLEARED ALL PRINT JOBS? ALSO AS400 PRINT QUEUE?
2 ALSO SOUNDS LIKE A VIRUS POSSIBLY "Adot.BAT". go online to housecall.com and do online virus scan.
3 OR, SOME OTHER CHANGE OR NEW DEVICE ON THE NETWORK MIGHT BE INTERFERING.
FIRST, TRY ISOLATING THE PRINTER FROM YOUR NETWORK. UNPLUG THE PRINTER FROM ALL DATA INPUTS AND RESTORE DEFAULTS. (LEFT OR RIGHT BUTTON TO SERVICE MENU, PUSH CHECK BUTTON, LEFT OR RIGHT TO RESTORE DEFAULTS, PUSH CHECK BUTTON).
IT SHOULD RESTART, THEN CALIBRATE. NEXT PRINT A CONFIGURATION PAGE FROM ITS MENUS, IF NOT TWO PAGES NET CARD IS DEAD.
IF OK SO FAR, TRY CONNECTING IT JUST TO A LAPTOP. USB ONLY THIS WAY, OR USE A NETWORK HUB, SEPARATE FROM YOUR NETWORK. INSTALL ANY OLD LASERJET DRIVER OR PRINTER ON THE LAPTOP JUST TO TEST IT.
IF ALL THIS WORKS, THE PRINTER IS FINE. BEFORE RECONNECTING THE PRINTER TO YOUR OFFICE COMPUTERS, FIX YOUR NETWORK & INTERNET OR VPN PROBLEMS.
THEN, DELETE ALL HP LASERJET PRINTERS & UNINSTALL ALL HP DRIVERS ON ALL NETWORKED COMPUTERS AND SERVER. (EXCEPT ZIPPED DOWNLOADED DRIVERS). START NEW HP PRINTER INSTALLATION COMPLETELY FROM ZERO. REINSTALL ONLY THE DRIVER YOU NEED. PCL5 IS RECOMMENDED.
Jun 13, 2008 | HP Color LaserJet 2600n Printer
HP Laserjet 1022 can be used as Shared Printer
Run the networking wizard on all of your machines.
Give the computers easy names like "FrontDesk"
Go the printer control panel on the machine the printer is installed on.
Right click printer and select share printer.
On all the other computers...
Go to Network places
Then on the far left select view workgroup computers.
Select the computer with the printer.
Double click on printer will install it.
Mar 05, 2008 | Office Equipment & Supplies
Help please....printer name does NOT appear
You must have a network set up, and you must enable file and printer sharing on the desktop. The laptop and the desktop should be in the same workgroup. Some firewalls will cause this problem.
Start with the network setup wizard in Settings/Network.
Jan 25, 2008 | D-Link NETWORK CARD DFE550TXREF Network...
Network Connection (LAN) for HP 650C
Plug it directly into the router and set the printer up on your Win2k/Xp as a network printer via the new printer wizard. The router will allow it to pull an IP number and you will find it on the network that way. It does not have USB because it was meant as an office printer and the option was network adaptor when purchased. If you look at the card in it, you can see it can be swapped out for another adaptor.
Apr 26, 2007 | HP DesignJet 750c plus InkJet Printer
Xerox DocuPrint N2125 Laser Printer Logo
100 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
