Question about Technics SL-PD888 5-Disc CD Changer
SL-PD888 rotates disk tray continuously after turn on
  • Technics Master
  • 1,267 Answers
The tray is usually detected by an opto interrupter device. When they or the interconnecting circuits fail this is the symptom you will have. It can also be due to the alignment of the tray. This is why all of my CD players are not changers.
Posted on Dec 11, 2012
Testimonial: "I gave it to a service. Some electronic circuts were broken down indeed. Also some maintenance of mechanical parts were done. It works now. Thanks for your assistance."
  • Sam Palermo
    Sam Palermo Dec 13, 2012
    Glad to be of some help, many of these units do not have an easy answer due to complicated designs. Sometimes a Technician and schematics is the only thing betwen a working unit and landfill. Good for you that it now works.
2 Suggested Answers
dunnbiker
  • 8546 Answers
SOURCE: Technics SL-PD888: Output signal is distorted/overdriven.
I can't find a manual. If it has both analog and digital outputs, compare both for sound quality and report the results. Also try them on different INputs of your electronics to eliminate that as a problem.
Let's examine THAT side, too. What are the components involved and how are they connected?
Posted on Feb 22, 2010
Testimonial: "Quick and courteous response... My problem is solved, but ended up being a dumb-dumb mistake and not an equipment problem at all."
My HP 2430 continues to jam on Tray 2 only. Tray 3 and Tray 1 (manual feed) are fine. I have replaced rollers and it continues to jam paper.
Common problem on this printer is for either the drive shaft for tray 2 to come lose or to break. Pull out the tray and try to rotate the roller. If it turns freely then the shaft is broken. The replacement procedure is too complex to describe here. If the roller does not turn freely then likely the pick solenoid has failed.
Oct 12, 2016 | HP LaserJet 2430dtn Printer
SL-pd888
Servo is shot in it, Minimun $110 end up to have it replaced,
Dec 05, 2012 | Audio Players & Recorders
What CD types does the PD887 play (CD-R, CD+R, MP3 format)?
You will have to experiment on this unit. I have looked at the owners manual and it does not refer to ANY type of recordable media. Your unit may not be able to play any recorded media. That is why I suggest that you try -R first, then you may want to try a Audio CD, specifically made for audio.
Here is a link to your owners manual if you need it.
http://www2.panasonic.com/consumer-electronics/support/Audio/Technics-Audio-DJ/Technics-CD-Players/model.SL-PD888
I hope that this helps you.
If you need any further assistance please respond to this post.
asnowman
Apr 12, 2010 | Technics SL-PD887 5-Disc CD Changer
Feb 21, 2010 | Technics SL-PD888 5-Disc CD Changer
SL-PD8 cd tray is opening and closing, nonstop.
I called panasonic and they told me to do a hard reset on the system it seems to have worked on mine. Hold the power button continually while you unplug and replug the unit.
Jul 26, 2009 | Technics SL-PD8 5-Disc CD Changer
Disk tray stops spinning disks
You need a new laser. Thats the only fix
May 28, 2009 | Microsoft Xbox 360 Console
Technics SL-PD888 5-Disc CD Changer Logo
97 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
