Question about Dyson DC14 Animal Bagless Upright Cyclonic Vacuum
Changing the main hose on a Dyson DC15 Animal
I got a replacement hose from Dyson for my DC15 Animal. However, I can't see how to release the bottom fitting. Thank you
-Bob Walker
  • 6 more comments
  • walkerent Jan 14, 2009
    Thank you very much. It was so easy when it was explained.
  • Anonymous Feb 18, 2009
    Where did you purchase the main hose?
  • garylynam Feb 18, 2009
    where did you locate the part?
  • Anonymous Mar 14, 2014
    dyson vacumI need to replace the front cover on my dyson d14 animal
  • Anonymous Mar 17, 2014
    how do you replace the hose u bend on a dyson dc15
  • Anonymous Mar 20, 2014
    It won't turn on. Last week we played with it and got it to turn on but that was the last.
  • Anonymous Mar 23, 2014
    where is the printed circuit or cutout reset button
  • Anonymous Mar 31, 2014
    seal,suction,canister
  • 372 Answers
Hi Bob.
If you look carefully where hose & elbow jount enter machine you will see a slot.
Rotate elbow so that lug on elbow aligns with slot & pull off.
http://dysonmanuals.llc.nu
Posted on Jan 14, 2009
How to replace hose on dyson animal
Reales the hose and extend the wand buuton on the top releases it from the pole
bottom of unit where the cup sits there is a clip press that
Replacement Dyson DC25 Hose complete DY 915677 07
Apr 24, 2015 | Dyson Bagless Upright Vacuum DC25 Animal
Change the Hepa filter on Dyson dc15
Now for a proper answer haha,
Remove the bin and underneath you will find a large disc (filter holder) that the bin in sits on. This needs to be removed. Its not as easy as it should be either.
Lay the machine flat on a table and stand behind the filter and pull the two top tab points with some firmly place fingers. Once these tabs release the last bottom tab can be gently flipped off with a flat blade screwdriver from the back (behind the wand hose).
I like to peel out the old filter and clean it up with a razor blade. Once this is done you can fit a lower cost DC14 filter in and save some money. No peeling needed if you buy a DC15 filter for big bucks.
Good luck.
May 06, 2012 | Dyson DC15 All Floors - The Ball Bagless...
Dyson dc15 animal brush won't turn
Your DC15 is equipped with a sensor which shuts off the brushbar if something jams it. Once you've checked the cleaner head for obstructions and removed any threads or hair from the brushbar, you should be able to reset the machine. For guidance on doing this, please refer to our online support guide:
http://support.dyson.co.uk/support/dc15/dc15-the-ball-animal/my-machine-is-not-working/i-can-see-something-wrong-visual/does-the-brushbar-turn-with-the-power-on
This should resolve the issue, but if you'd like any further assistance, please call us on 0800 298 0298 (UK), or 1-866-693-9766 (US).
Best wishes,
Jack
Dyson Online Customer Support
http://www.dyson.com
Feb 07, 2012 | Dyson DC15 Animal Bagless Upright Cyclonic...
The brush does not work on my dc15 animal, there is great suction but after about 20 seconds it sounds like something has got blocked in it although nothing is clogged, filters and hoses have all been...
Sorry to hear you're having a problem with your DC15. You might find it helpful to visit the Support section of our website and follow these simple steps:
http://www.dyson.co.uk/support/help.asp?article=903&product=DC15-ANIMAL
You should find this resolves the issue. However, if you're still having difficulties, please get in touch with us free, on 08002980298 (UK), or 1866MYDYSON (US), so we can run through some checks over the phone.
Kind regards,
Jack
Dyson Customer Service
May 26, 2011 | Dyson DC15 All Floors - The Ball Bagless...
Dyson dc15 animal vaccum ,the roller o brush won't run, what can i do, luzelenamorales@live.com
Take it apart and I bet you find a broken belt,replace belt from sweeper shop ,put back together and on your way
Feb 17, 2011 | Dyson DC15 Animal Bagless Upright Cyclonic...
I've managed to detach the back wheel truck/foot mechanism and need to know how to reattach please.....
See if this link helps you. It was posted in one of the DC15 solutions. Probably not, but worth the try?
http://www.espares.co.uk/diagram/dyson/dc15-animal/p/1086/716/10/420640?ed=4365
Sep 08, 2010 | Dyson DC15 Animal Bagless Upright Cyclonic...
The hose on the DC15 vacuum serial # 030605VS is clogged and must be replaced as I accidentally vacuumed a bag of needles and the hose has pin holes besides, I cannot get it out. Is there a place I can...
http://www.espares.co.uk/datastore/ProductManuals/350256.pdf
Check the above link to see if it helps. It shows you how to break down the DC15 to check for issues.
you can also try calling their helpline at 866-MyDyson for local authorized service centers or further help.
Aug 09, 2010 | Dyson DC15 Animal Bagless Upright Cyclonic...
I need a vacuum brush housing assembly for Dyson DC15 animal. Part of it is broken (plastic).
http://www.espares.co.uk/dyson/dc15/p/1086/716/10
Try the above link or do a search in google for "Dyson DC15 parts". Also, try searching in Ebay. You should have no problem in locating the part. Lastly, try calling Dyson at 866-MyDyson.
Good luck.
Aug 10, 2009 | Dyson DC15 Animal Bagless Upright Cyclonic...
Dyson D15 Animal is clogged, both in hose and in bottom
take pipe off and push a bamboo or somthing simular down hose
Jan 08, 2009 | Dyson DC15 Animal Bagless Upright Cyclonic...
Dyson DC14 Animal Bagless Upright Cyclonic Vacuum Logo
3,756 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Samyfam
Samyfam
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
