Question about Maytag Neptune FAV9800AW Top Load Washer
Wire broke on lid switch can it be put back together
It's part #25001048
    Top Expert:
  • Maytag Master
  • 9,472 Answers
Is it the wire or the prong on the lock itself?
Posted on Dec 05, 2012
How to bypass a lid switch on 26002010
You first un plug machine. Front panel has screws in the four corners. Trace lid switch to the back of panel. Cut the two wires and strip wire and put together , use **** connectors and put all back together. As you now, when washer is on high spin, make sure no kids open lids, as you just bypassed safety feature.
Jun 06, 2011 | Kenmore 20172 Top Load Washer
Kenmore elite 80 series washing machine model110.26824690 cg11808832 put a heavy load (a blanket) in the machine. the top part of the agitator seems to work but i can't reach in a physically turn the...
Greetings,
check for a faint click when you close the lid..if you hear no click, paying close attention for sound..the lid switch is most likely bad..on some models..it prevents machine from spinning, but lets it wash..there is a way to get it to spin by hooking switch up direct...this is only good for checking as its a safety feature...raise console after UNPLUGGING and you will see a small block with three wires coming out of cabinet at right corner ...there will be a plug that goes into this with three wires and it comes off by holding a little tab and pulling it off. its this block that you want to make bypass..do not use the green wire as its ground, but make bypass beteen other two wires and it should drain and spin. make sure you tape this with electrical tape and purchase a new lid switch.
Jan 23, 2011 | Washing Machines
We need to know what wires to hook together to bypass the door switch on our maytag electric dryer to test it
lift the top up on your dryer.this will require a wide,flat tool @ front corners.a flat screw driver will work but a stiff putty knife is ideal.lift & pull.the door switch is in the upper right hand corner.when you raise the top & lean it carefully out of the way you will see the obvious door switch wires.pull them off of the switch & put them together w/ a clothes pin.you can bump the start button w/ the lid still up.if it starts up,its the switch.
Feb 12, 2010 | Maytag PYE2300AY Electric Dryer
Water fills tank, agitation does not start.
most modern washers wont spin unless the lid is shut. if your closing the lid and nothing is happening i would start with the lid switch. some of the new ones are magnetic so you may not hear a click when you close it. you can bypass them, they are usually a two wire switch. unplug the washer and cut the two wires going to the lid switch and twist them together, plug it back in and try it. make sure you leave enough wire on the switch if you choose to put it back or the problem is with something else.
Sep 27, 2009 | Washing Machines
I have a kenmore 70 series washing machine and all of the sudden, it won't drain....it goes through the washing cycle til the time comes to drain and then stops????
unplug washer ,very simple,your lid switch is broke,remove 2 screws from head,flip head up,unplug the jack on the washer top,cut both outside wires and wire them together,plug back in,you have now by passed the lid switch,your done,let me know how you do,if that does not work we will tackle the water pump-mike
Mar 24, 2009 | Washing Machines
HELP! My washer filled up with water and will now do nothing.
you just by pass it,unplug washer,remove the 2 head,flip head up,unplug the wire jack on the washer top,cut the 2 outside wires and wire them together,plug it back in,your done,put everything back together-mike
Mar 23, 2009 | Kenmore 22422 Top Load Washer
Washer won't spin,rinse,or drain
BAD LID SWITCH,YOU CAN REPLACE IT OR BY PASS IT,REMOVE THE 2 CONSOLE HEAD SCREWS ONE ON EACH SIDE,FLIP THE TOP UP,YOU WILL SEE THE LID SWITCH JACK,YOU CAN CUT THE 2 OUTSIDE WIRES AND PUT THEM TOGETHER WITH A WIRE NUT AND PLUG BACK IN,YOU HAVE NOW BY PASSED THE LID SWITCH AND YOUR GOOD TO GO-MIKE
Mar 02, 2009 | Kenmore 24032\24036 Top Load Washer
My Kenmore goes through all the cycles but will not spin!
Hello, ok washer not spinning is 1 of 2 things. First see if lid switch is clicking, do this by shutting and reopening the lid …do you here a click click sound. If you do then more then likely the lid switch is good. If not then replace the lid switch by unscrewing the 2 screws by the lid switch, unplug washer, pull switch out, it will come out about 4 to 5 inch’s, cut the 2 wires close to switch and then strip each wire back about ½ in. when you have the new switch cut wires 6 in from new switch and strip wires the same. Wire nut the 2 wires together and then wire nut the other two wires together. Reverse steps to put back in. if it is not the lid switch then it is the coupler. This you will need a technician for unless you are somewhat mechanical. If so you can look up how to do this. Thank you
Dec 08, 2008 | Kenmore 24032\24036 Top Load Washer
Maytag Neptune FAV9800AW Top Load Washer Logo
20 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
