Question about Acer "X1110 Projectors Svga 800 X 600 Uxga 1,600 X 1,200 1080P 1"
HI, MY PROJECT WILL AUTOMATICALLY TRIP OFF
WHAT ARE THE PROBABLE CAUSE THAT MAKES MY PROJECTOR TRIP OFF
    Champion:
  • Acer Expert
  • 225 Answers
Filter needs to cleaned is the first thing.
Posted on Dec 06, 2012
Vivtek d510 projector has black and white spots covering 1/3 of projected image
The DLP Chip is failing .The DLP or Digital Light Projection Chip contains up to 8 million tiny microscopic mirrors that tilt to project a digital image onto the screen. These mirrors are failing causing light and dark spots to appear.Unfortunately fixing this projector is probably going to cost more than buying a new one. Hope this helps.
Jan 02, 2014 | Vivitek Office Equipment & Supplies
Epson Projector, Model: EMP-X5, Epson projector shuts down after 30 minutes work
There are several things that can cause this problem, but the first thing I would check is the filter. The projector requires airflow to keep it cool. If airflow is blocked, the projector will overheat and shut down automatically.
Jan 02, 2013 | Epson ELPLP41 EB S6 Lamp
Overheating
What is the operating temperature please?
Aug 27, 2012 | Sanyo 6102607208 Projector Lamp for...
MY EPSOM PROJECTOR IMAGE IS UPSIDE DOWN. WHAT DO I DO?
Hi, Your projector is probably set for ceiling mount which will project an upside down image because the projector is normally mounted upside down when installed on the ceiling. Go into the menu and select extended then select projection then select front. That should return the image to right side up.
Aug 22, 2011 | Epson EX30 LCD Projector
My projector keep on searching for source
Once you have the project on and the cord connected then start or restart your computer and the connection will then be made automatically in most cases...
heatman101
Jun 17, 2011 | LG DS420 DLP Projector
I have an occasional problem with my Hasselblad PCP80 projector. Shortly after switching on the lamp will go out for no apparent reason, but all other controls on the projector work okay. The high...
From my PCP80 Service Manual:
FAULT: The projection lamp is lit for a short moment and then goes out. POSSIBLE CAUSE: 1.The rectifier and lamp change board are out of order. AND/OR: 2.Both triacs turn on. Both lamps are lighted until the automatic circuit breaker is released. MEASURES: 1. Change both boards. 2. Change the triac board.
See Also:
FAULT: The projection lamp does not light. POSSIBLE CAUSE: The automatic circuit breaker has released. MEASURE: Reset the circuit breaker. AND/OR: Fuse F102 has blown. MEASURE: Change the fuse. AND/OR: The rectifier and lamp change board are out of order. MEASURE: Change both boards. AND/OR: The triac board is out of order. MEASURE: Change the board.
Dec 21, 2010 | Hasselblad PCP 80 Slide Projector
When tv goes to turn projectors on it powers off
The main power transformer is either going bad or has bad solder points holding it on to the board. sometimes if it is a bad solder joint sound vibration from the speakers can cause the solder joint to disconnect and this inturns trips the system to power down. what make and model of TV?
try running the TV on Mute to see if it is a sound vibration jiggling a loose solder connection.
Sep 13, 2009 | JVC AV-56WP74 56" Rear Projection...
BenQ 8700 Won't Power On
As far as the projector goes, the ac power supply is fused with probably no more than a 7 amp fuse, that would blow before your breaker would if the problem were in the projector. The only thing that could case the breaker to trip would be a defective AC outlet socket or your cord for the projector is bad. I have seen cases where cat's have chewed though the cord and shorted it out and triped a breaker, outside of that if the projector is bad now then your thought of sending to the manufacturer is the best one.
Jun 07, 2009 | Televison & Video
Projector not projecting anything
Have you try pressing the Fn+F7 key. This will switch between the laptop screen and external screen.
Let me know if this helps.
Mar 28, 2009 | Dell 2200MP Multimedia Projector
Can not make picture bigger on my Sanyo PLC-SW20 projector
depending on the size of the surface you are projecting on, and what the zoom capacity of your lens is, you probably only have one choice available to you, and that is to move your projector farther away from what you are trying to project onto.....
hope this helps!
Jan 10, 2009 | Sanyo PLC-SW30 Multimedia Projector
Acer "X1110 Projectors Svga 800 X 600 Uxga 1,600 X 1,200 1080P 1" Logo
95 people viewed this question
Top Acer Office Equipment & Supplies Experts
jasbo
jasbo
color wheel light...
Are you an Acer Office Equipment and Supply Expert? Answer questions, earn points and help others
