Question about Ovens
F1 Error Code : Kenmore Self-Clean Electric Range. Oven wont shut off. I can silence the F1 alert but it keeps coming right back on every 30 to 60 seconds or so. Range top burners work fine, but oven
  • 1,013 Answers
An F1 error code usually means that the temperature probe isn't sending the correct signal back to the control board. Try disconnecting power to the range for at least a minute. If F1 displays after you cycle power you may need to replace the EOC (Electronic Oven Control).
Posted on Dec 05, 2012
  • Rob Warren Feb 23, 2013
    I sent E.O.C. circuit board out to be repaired. Got it back & installed today. Range seems to be working fine now. Thank you for your help!
  • Jose Ruppenschlager
    Jose Ruppenschlager Feb 24, 2013
    Great! I'm glad that worked!
TheMobilian
  • 8220 Answers
SOURCE: self cleaning oven error code FSEO
Probably a bad door lock solenoid. That is some kind of door lock problem. Trouble is they are not all the same. This training manual shows locations of model number. Perhaps if you post that I might can come up with a tech sheet and you would get a better answer. see page 4
Posted on Apr 11, 2010
Testimonial: "was surprised at such a quick response...needed additional information to provide a better solution...very grateful for the assistance"
fridgetech
  • 473 Answers
SOURCE: Roper gas range and oven with electric igniter
First look to see if the ignitor is coming on. Most common problem is the ignitor is weak or just bad. When the power is applied to the ignitor it glows and builds up resistance to open the gas valve then it lights. If the ignitor is weak or bad it will not build up enough resistance for gas to come into the burner. One sign of this would be a "woosh" sound when it trys to light. If the ignitor is coming on but not lighting it is most likely the ignitor is bad. Should have a full glow. Also, if the ignitor looks whiteish in color this is a sign of it going bad. You can compare to the broil ignitor to be sure. If the ignitor doesn't come on at all will need to see if you have power to the ignitor. Let me know what you find and let's solve it before you rate the solution.
Posted on Nov 07, 2007
SOURCE: dacor cps130 wall oven f1 error
According to the manual, this is an element relay circuit failure. Call the tech.
Posted on Jun 15, 2008
SOURCE: Older Kenmore oven- door locked by itself
We had a quick power outage and when the power came back on it locked our older (1991) Kenmore electric oven model # 40889 / 40881. Went throought the manuel and nothing pertains to this problem. We have turned off the circuit breaker and turned back on, but nothing seems to unlock the door. Any suggestions would be GREAT!!!!!!!
Posted on Mar 16, 2009
blueextc3221
  • 15935 Answers
SOURCE: trying to self clean my kenmore electric oven get
The E1- F5 error is a door lock error.
The control (TIMER) has likely failed in this instance - BUT...
Sometimes when you disconnect power to a range and reconnect it the electronic range control gets confused.
You should disconnect power again for 15 seconds and reconnect and see if that helps.
If it doesn't cure the E1- F5 error hold the bake button in until E0- F2 appears in the display.
This is the error for a stuck button on the keypad and is the way to clear the memory of the electronic range control.
Sometimes these work, but if the control has failed it won't make any difference.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 25, 2010
How do I fix my oven door keeps locking up and F1 comes up and starts beeping
Here is a detailed description of this error code. Your control can be rebuilt by fixyourboard.com. See article here on Kenmore/GE F1 Error Code: Oven Failure After Self Clean and F1 Errors
Aug 27, 2015 | Ovens
Fridgidaire self cleaning range: F1 error code?
You have a control board failure. First thing I would try is to unplug the range for at least 10 min. and then plug back in and see if that works. Hope that helps
May 29, 2014 | Frigidaire 30" Self-Cleaning Freestanding...
Frigidaire Self-Cleaning Oven Model FEF353BFW and F1 Error Code.
I just had the same problem! If I ever see that f9 again and hear that annoying constant beep....I will pick up and dispose of that oven on the front lawn. Lol. Took a pair of pliers and turned the lock clock wise till the light went out. Silence!
May 02, 2012 | Frigidaire 30" Self-Cleaning Freestanding...
My oven when turned on goes to F1 and the heat is like broil...only the top burner comes on????
Hello,Please use the chart to determine which stove you have. You will have to look at the model number. The first 3 numbers will be the series on the chart. In most cases an F1 error would require replacement of the electronic control. This part is commonly refered to as an EOC or ERC. However this type of repair is usually reserved for repair specialists.
KENMORE Range/Stove/Oven Fault Codes – 362 Series (General Electric)
F1 = Stuck Touch Pad Key - Replace Electronic Range Control (ERC).
KENMORE - 911 Series (General Electric/Roper)
F0-F1-FF = Failed transistor in Electronic Range Control (ERC).
KENMORE Range/Stove/Oven Fault Codes- 665 Series (Whirlpool)
F1-E0 EPROM Error - Electronic Range Control (ERC).
F1-E1 EPROM Error - Electronic Range Control (ERC).
F1-E2 U/L ERC Errors - Electronic Range Control (ERC).
F1-E3 Fuel Type Fail
Kill power 30 seconds-Cancel-Start/Enter-5 seconds-Should see “E” for electric-
“9” for gas-If code changes again-replace Electronic Range Control (ERC).
KENMORE - 790 Series Electronic Oven Control (Frigidaire)
F1 = Shorted Touch Pad = Electronic Range Control (EOC) Internal check sum error.
Runaway Temp = Replace Electronic Oven Control (EOC).
Kill power 30 seconds - if error returns - replace Electronic Oven Control (EOC).
Thanks
May 28, 2010 | Kenmore 40494 / 40495 / 40499 Electric...
Self cleaning oven error code FSEO
Apr 11, 2010 | Whirlpool 30" Self-Cleaning Freestanding...
F1 error code and constant beeping and oven shuts off.
Hi gwhiz03,
If you are having error code F1 with your Jenn-Air double wall oven this is because you have a defective touch pad or clock (ERC). This simple test will help determine whether the ERC (Electronic Range Control or Clock) or the touch pad is defective when F1 error code is present.
Note: Some models incorporate the touch pad in to the ERC as a single assembly, in which case this test is not necessary. Simply replace the ERC (Clock).
Warning: If you feel in any way uncomfortable performing this test or making this repair, please contact a qualified appliance repair technician.
1. Disconnect power to the range (unplug the range power cord or turn the power off to the range at the circuit breaker). It is very important that the power to the range has been disconnected, so please double check before continuing.
2. Gain access inside the control panel.
3. Disconnect the touch pad (also called keypad or membrane switch) ribbon from the ERC.
4. Make sure there are no lose wires, or anything else that may cause a short when power is turned back on. Assemble the control panel back the way it was.
5. Turn the power back on.
6. Wait for at least one hour to see if the F1 code comes back (usually accompanied by a beeping sound).
7. If F1 comes back, replace the ERC. If it does not, replace the touch pad.
Hope this helps.
Thank you for using FixYa.
Feb 10, 2010 | Jenn-Air WW30430P Stainless Steel Electric...
Code : E3 -F1-
I have an Inglis electric stove with a self cleaning oven We turned the left dial to "CLEAN" and when turned the right dial to clean, a buzzer went off. Can you give me any advise?
Oct 17, 2009 | Whirlpool 30" Self-Cleaning Freestanding...
Getting error code F10 on Kenmore model 47889603 wall oven
Leaving the breaker off for the time I was at work (about 9 hours) seems to have cleared the problem. May have just been an abberation and not an actual problem with the appliance. Since the first step with most electronics that develop a fault of some type is to power down for a while then power back up to reset the electronics, I decided to see if that would do it and it did. Thanks for having a site to go to for assistance, though!!!! -Mike-
Dec 19, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
My kenmore oven is beeping and will not stop. the display shows F-1.
Please use the chart to determine which stove you have. You will have to look at the model number. The first 3 numbers will be the series on the chart. In most cases an F1 error would require replacment of the electronic control. This part is commonly refered to as an EOC or ERC. However this type of repair is usually reserved for repair specialists.
F1 = Shorted Touch Pad = Electronic Range Control (EOC) Internal checksum error.
Dec 16, 2008 | Ovens
My kenmore electronic stove is having a beep with code F1 on the
Dec 15, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
Ovens Logo
777 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
