Question about Kenmore Dishwashers
Model # 665.13594k600
Keeps blowing thermal fuse
5 Suggested Answers
SOURCE: Thermal fuse keeps blowing
Mr. Larry (guru?)
The thermal fuse is just that It doesn't protect the circuit from over current although it certainly can open in that case. It is there to protect the board from overheating , thus the term thermal. The dishwasher could be allowing the water to heat too hot or the water heater in the home is turned up too much. The heater could also be shorted to case thus allowing it to be on even though the control is not calling for it especially if the polarity is incorrect to the dishwasher or the relay on the board could be welded closed so that the heater can't turn off even though the thermostat is satisfied. The best thing is to get a person who can check these things. You don't necessarily need to change the board with a fuse. I have changed many fuses with no other problems and verified that the machine was still working years later. sometimes the fuse just blows!
Posted on Jan 27, 2009
jgwhomeequip
  • 1902 Answers
SOURCE: thermal fuse has blown 2 times
Check for a bad ground wire. Also while you are check the ground check all the other wires to make sure that they are seated properly and nothing has come lose or te wire plastic has come off or rubbed off and grounding itself out
Posted on Feb 21, 2009
  • 423 Answers
SOURCE: The thermal fuse blows out midcycle. It used to occur about every 6 months but is getting more frequent
The first thing I would inspect is the heating element for damage that may beginning to short out.
If the element checks out good, a failing motor could blow the fuse.
If the motor checks out, look for shorts in the wiring both in the door and under the unit.
It is hard to be more specific without knowing the make & model and the dishwashers approximate age (years.)
Good Luck! Please report back what you found, OK?
Posted on May 26, 2009
jtd866
  • 71 Answers
SOURCE: the thermal fuse keeps blowing during a wash cycle
clean the stator of your motor and bushing.
Posted on Aug 29, 2009
E28 error. Why does the thermal fuse keep blowing out?
If the thermostat is not functioning properly the heater will run "wide open" and overheat.
Feb 07, 2016 | Water Water Heaters
Why does dryer's thermal fuse keep blowing out
Take it back to where you bought it or call the number on the warranty and the costumer care person can help you! Good Luck!
Sep 24, 2012 | Whirlpool Dryers
Knemore Series 80 Dryer - Blows Thermal Fuses, Humming Noise
The heating element is shorted to ground. You will need to replace the heating element and the thermal fuse, both available at the link below.
Heating Element $40.77
Thermal Fuse $6.99
Mar 02, 2012 | Kenmore Dryers
Thermal fuse blown on kenmore dryer what is the cause
The thermal fuse blows when the vent gets restricted and builds up too much heat. After it gets to a certain point the thermal fuse blows. Clean out the vent, keep the lint trap clean, and hopefully your problems will go away.
Feb 04, 2012 | Dryers
Thermal fuse keeps blowing. Dryer heats up too
The problem will be either your vent is stopped up or the cycling thermostat and the high limit thermostat are bad. If the vent is clean, both the cycling thermostat and the high limit thermostat are welded closed. Both are supost to open to avoid over heating. Go to www.partselect.com and enter your complete model number. It will bring up diagrams of you machine. From there you can find the parts ans also order them if you want to. Good luck.
Nov 25, 2009 | Cars & Trucks
Model 110.68622700 keeps blowing thermal fuse.changed fuse a month ago
If the thermal fuse is blowing, it's because the inner dryer is getting too hot. The control thermostat is the likely culprit. It's not cycling the heating element is staying on continuously. I would change the operating thermostat. If you go to repairclinic.com., put in your make and model, it will pull up all the parts for your machine.
Sep 13, 2009 | Dryers
May 25, 2009 | Dishwashers
Keep blowing fuses
hi, make sure you are using a time delay fuse and not a regular fuse. this may be the reason why the fuse keeps blowing out on your dryer.
Mar 09, 2009 | Whirlpool LGV4634JQ Gas Dryer
Mr. Larry (guru?)
Dec 02, 2008 | Dishwashers
Dishwashers Logo
54 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
D. E. Hev
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
