Question about HP LaserJet 5200tn Printer
Why does my HP LJ5200 only prints landscape from manual feed tray
SOURCE: HP Color laserjet 4700 is printing in landscape
check paper settings in paper handling to set
at plain paper/ letter. or reset factory defaults.
check paper size on tray if app, set to standard or
letter ,not custom
do cold reset . must reinstall network info afterwards.
Posted on Jan 20, 2009
  • 85 Answers
SOURCE: HP Laserjet 3050, need to press ok each time printing
did it work before? check paper size for trays - suspect it is set for a4, change to letter size
Posted on Mar 13, 2009
DosHog
  • 168 Answers
SOURCE: 13.01.00 paper jam tray 2
The pickup rollers are worn out. Replace them and your problem will be gone. While you are sourcing them, use some alcohol. This may give them a little more life.
Posted on Jul 23, 2009
SOURCE: HP P3005 Will not pull from Tray 1
Click File > Print > Properties to check your settings.
To verify that tray 1 is working, put paper in tray 1. Press green check until you see Information Menu. Scroll using arrows until you see Print Menu Map then press green check. If it prints from tray 1, your problem is not with the printer, but with the PC settings.
i has follow this step, but need to press green check button to resume print menu map.
tray 1 manual feed set to A4 paper plain size
manual feed is on.
there is paper on tray 1
ps setting tray1 manual feed is A4 plain size paper.
send print to tray1 manual feed even there is paper at tray 1
i still need go to the printer and press green check button to resume print
Posted on Jul 25, 2009
  • 40 Answers
SOURCE: hp laserjet p3005dn tray1 manual feed problem
you can choose mp first in "paper handing" printer menu or print tray1 is A4 default in properties of printer software.
Posted on Jul 27, 2009
Won't print manual feed
MANUAL PRINT IS ALSO KNOWN AS TRAY 1 ON HP PRINTERS. LOAD PAPER INTO THE SLOT ABOVE YOUR PAPER TRAY.
Dec 13, 2015 | HP LASERJET P1006 Printer
Unable to pick up papaer on tray 2 error 13.00
common faults for poor feeding on lj5200
1, feed rollers are worn - replace
2, sep pad is worn ( cant seperate pages correctly)- replace
3, paper empty tray sensor actuator arm snapped - unable to raise cassettetray- replace arm
4. paper feed roller fail to turn- feed unit clutch assy faulty- replace feed asseembly
5.paper tray pass guide out of position (blocking feed path) - pin that holds in place has snapped- replace feed assembly
Dec 13, 2013 | HP LaserJet 5200 Printer
My HP P2015DN only prints one page at a time. If I have a 5 page document, the first page prints and then I must print the go button for each page to print.
Is the paper feeding from the manual tray or tray 2. If you are printing from tray 2 and have this problem then it is likely that your driver or software is looking for different paper types than you have loaded in the printer. For example, if you have plain paper in tray 2 and your software wants to print on letterhead, then the printer will stop after each page and by pressing the button you are telling the printer that it is ok to print on different paper. If you have the paper in the manual feed tray (tray 1) then I would check to make sure you are telling the pirnter to print to tray 1 and not manual feed when you send a print job.
May 02, 2011 | HP LaserJet P2015dn Printer
Paper goes through tray 1 the image prints landscape on portait
Try placing the business card sheet in the main paper bin instead of the manual feed or adjusting the print orientation from Portrait to Landscape or vice versa.
Sep 25, 2009 | Computers & Internet
Hp laserjet p3005dn tray1 manual feed problem
Jul 25, 2009 | HP LaserJet P3005n Printer
HP Laserjet 4700 Always Defaults to Tray 1
Your tray 1 might be open (even just partially) or your manual feed setting might be on. You can find this setting under > Configure device / Printing / Manual Feed
Jun 25, 2009 | HP LaserJet 4700 Printer
letter ,not custom
Jan 20, 2009 | HP LaserJet color laser printer
HP4050tn laser printer "Manually Feed HP Tough Letter"
Hi artroebridge:
Thsi printer is asking you to load tray 1. You need to check the paper source. Print a configuration page and see what your trays are set for,and also check your print properties for the correct tray configuration (what tray u want to print from)
Jan 09, 2009 | HP LaserJet 4050tn Printer
What does the light mean?
the ! in the triangle means manual feed or "continuable error" which means that the printer is manual mode. or there is a paper feed problem.
you need to check the HP print software, make sure all the printer setting are correct.
if so, then check the printer paper tray, make sure they are in working order, and there is no paper jam on the paper path from the tray to the output.
The manual feed use different paper path, so check the tray path.
then unplug the printer from the computer and shut down the printer.
wait 2 minutes, power up the printer and connect the printer tot he computer.
Dec 16, 2008 | HP LaserJet P2015dn Printer
Hp 4350 - Manually feed not printing on its own
from the configuration menu you most select the manual tray and keep it first
Mar 12, 2008 | HP LaserJet 4350 Printer
HP LaserJet 5200tn Printer Logo
53 people viewed this question
Seeker5211
Seeker5211
