Question about Exercise & Fitness
Meaning of excursion - Exercise & Fitness
    Sergeant:
  • 316 Answers
Excursion
1. a short outward and return journey, esp for relaxation, sightseeing, etc.; outing2. a group of people going on such a journey3. (Transport / Railways) (modifier) of or relating to special reduced rates offered on certain journeys by rail an excursion ticket4. a digression or deviation; diversion an excursion into politics5. (Military) (formerly) a raid or attack6. (Physics / General Physics) Physicsa. a movement from an equilibrium position, as in an oscillationb. the magnitude of this displacement7. (Life Sciences & Allied Applications / Physiology) the normal movement of a movable bodily organ or part from its resting position, such as the lateral movement of the lower jaw8. (Engineering / Mechanical Engineering) Machinery the locus of a point on a moving part, esp the deflection of a whirling shaft
Posted on Dec 05, 2012
My ford 2003 excursion is having a lot of problems error p0316 what does it mean?
when you first start it is misfiring on one or more. i would get a tunup if you havent yet. spark plugs and gas filter.
Jan 03, 2013 | 2003 Ford Excursion
Whats the fuel pressure on a ford excursion v10
Fuel pressure for your 2000 Excursion is 35-45psi with key on and engine off, with engine running the fuel pressure should be 28-45psi
Oct 14, 2012 | 2000 Ford Excursion
I need a diagram and or owners manual for a 2000 ford excursion
About the Owners Manual, I suggest vistit this links:
- 2000-Ford-Excursion-Owners-Manual
- Ford-Excursion-Owners-Manual-2000
Hope this helps (remember to rate and comment this free answer).
Sep 21, 2011 | 2000 Ford Excursion
Have a 04 excursion 6.0L diesel. have been driving it with no problems then after a rain storm it will not start. Batteries are fine, no fuses blown, but won't crank. Ideas?
When say wont crank..Do you mean it will turn over but not start,,or do you mean it wont even turn over..I work on 6.0 liters all the time,,and you really need a scanner to see if your FICM has gone bad or other electronics...Plus your high pressure oil pump could have went out..They dont really give you much warning on them engines when something goes out..
Sep 17, 2011 | 2004 Ford Excursion
What size headlights fit in a 2003 excursion
I assume you mean bulbs?
this takes a 9007 bulb type, any parts store can supply these.
Mar 23, 2010 | 2003 Ford Excursion
Brand new (3 weeks!) old camera ppost beach excursion lens stuck have tried cleaning out in case sand/grit and have recharged battery etc etc. If this is so common (as appears on this site) does it mean...
sir, u r doubt is appriciated,must be careful when u r in suchbeach excursion,and also protect from moisture,and sand. take to the kodak service,lens unit has to be replaced,serviced.
Mar 04, 2010 | Kodak Easyshare M341 12.2MP Digital Camera...
The light that says ''OFF'' on the shifter of my 2000 Diesel Excursion is blinking about one second on and one second off. I had heard certain sequences of that light means certain things but I never...
the blinking light is your over drive light, and yes it does blink a code for your trans. take to an auto parts store and have them read the codes. because of your irratic speedo it leads me to believe you have a bad speed sencor
Jan 24, 2010 | 2000 Ford Excursion
2000 Ford Excursion Diesel has check engine light of P1391
glow plugs preheat the fuel to help the engine start.....when its hot outside its not that bad...the colder it gets the harder it will be to start with bad glowplugs..
Nov 17, 2009 | 2000 Ford Excursion
My 15 & 10
On a 10 inch subwoofer ranging between 80Hz and 120Hz, the box size required should be around 20 liters, meaning that you will end up with a box of 11 inches high, x 11 inches wide, x 11 inches deep. Or 275mm high, x 275mm wide, x 275mm deep. Seal the boxes with silicone for better bass
Oct 21, 2009 | Hollywood Sound Lab Hollywood Digital...
2000 FORD EXCURSION POWER STEERING
How does the hydro boost fell "funny" - does the brake pedal go to the floor? Do the brakes lock up? engage immediatly? Does the brake light stay on, come on while brakes are applied? Have a diagnostics test done on it at a local auto parts store (usually a free service; stores may vary) and see if any codes show up. If so, the person submitting the test can tell you what the code(s) mean, and what to do to fix the problem.
Mar 31, 2009 | 2000 Ford Excursion
Exercise & Fitness Logo
79 people viewed this question
Top Exercise & Fitness Experts
Electro Med Services...
Howard
Howard
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
